Build problem after VE crash [message #610794] |
Sat, 17 September 2005 21:20 |
Originally posted by: kevin.atg.ca
I tried to use VE to open a view that I had started to create manually. VE didn't render it properly and when I closed the view my system blue-screened. Now I can't build the project, I get the following in the error log (3 nested errors).
Error 2005-09-16 12:34:03.788 JavaBuilder handling ImageBuilderInternalException while building: Test Web Monitor
org.eclipse.core.internal.resources.ResourceException: Problems encountered while copying resources.
at org.eclipse.core.internal.localstore.FileSystemResourceManag er.copy(FileSystemResourceManager.java:147)
at org.eclipse.core.internal.resources.Resource.copy(Resource.j ava:536)
at org.eclipse.jdt.internal.core.builder.BatchImageBuilder$4.vi sit(BatchImageBuilder.java:228)
at org.eclipse.core.internal.resources.Resource$1.visitElement( Resource.java:50)
at org.eclipse.core.internal.watson.ElementTreeIterator.doItera tion(ElementTreeIterator.java:81)
at org.eclipse.core.internal.watson.ElementTreeIterator.doItera tion(ElementTreeIterator.java:85)
at org.eclipse.core.internal.watson.ElementTreeIterator.iterate (ElementTreeIterator.java:126)
at org.eclipse.core.internal.resources.Resource.accept(Resource .java:60)
at org.eclipse.jdt.internal.core.builder.BatchImageBuilder.copy ExtraResourcesBack(BatchImageBuilder.java:198)
at org.eclipse.jdt.internal.core.builder.BatchImageBuilder.clea nOutputFolders(BatchImageBuilder.java:131)
at org.eclipse.jdt.internal.core.builder.BatchImageBuilder.buil d(BatchImageBuilder.java:36)
at org.eclipse.jdt.internal.core.builder.JavaBuilder.buildAll(J avaBuilder.java:213)
at org.eclipse.jdt.internal.core.builder.JavaBuilder.build(Java Builder.java:141)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:593)
at org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:783)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:168)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:202)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:231)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:234)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop (BuildManager.java:253)
at org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:282)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBu ildJob.java:139)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJ ob.java:200)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
Error 2005-09-16 12:34:03.788 Problems encountered while copying resources.
Error 2005-09-16 12:34:03.788 Could not read metadata for: C:\data\workspace\.metadata\.plugins\org.eclipse.core.resour ces\.projects\Test Web Monitor\.indexes\85\81\c9\86\properties.index.
java.io.EOFException
at java.io.DataInputStream.readByte(Unknown Source)
at org.eclipse.core.internal.properties.PropertyBucket.readEntr yValue(PropertyBucket.java:251)
at org.eclipse.core.internal.localstore.Bucket.load(Bucket.java :300)
at org.eclipse.core.internal.properties.PropertyBucket.load(Pro pertyBucket.java:243)
at org.eclipse.core.internal.localstore.Bucket.load(Bucket.java :267)
at org.eclipse.core.internal.localstore.BucketTree.internalAcce pt(BucketTree.java:89)
at org.eclipse.core.internal.localstore.BucketTree.accept(Bucke tTree.java:67)
at org.eclipse.core.internal.properties.PropertyManager2.copyPr operties(PropertyManager2.java:96)
at org.eclipse.core.internal.properties.PropertyManager2.copy(P ropertyManager2.java:83)
at org.eclipse.core.internal.localstore.CopyVisitor.copyPropert ies(CopyVisitor.java:104)
at org.eclipse.core.internal.localstore.CopyVisitor.copy(CopyVi sitor.java:65)
at org.eclipse.core.internal.localstore.CopyVisitor.visit(CopyV isitor.java:185)
at org.eclipse.core.internal.localstore.UnifiedTree.accept(Unif iedTree.java:83)
at org.eclipse.core.internal.localstore.FileSystemResourceManag er.copy(FileSystemResourceManager.java:144)
eclipse.buildId=I20050627-1435
Any suggestions ?
Kevin McBrearty
FUDForum. Page generated in 0.02527 seconds
