Home » Archived » XML Schema Definition (XSD) » my element is declared in schema A and its type in schema B, how to get its type
my element is declared in schema A and its type in schema B, how to get its type [message #61754] |
Mon, 20 June 2005 10:49  |
Originally posted by: ediouf.genigraph.fr
i have an elemnt declared in schema A
its type is defined in schema B
when parsing the schema A, the value of the type is null!
How can i do?
here is part of the code :
<xsd:element name="IdentificationCode"
type="cnt:CountryIdentificationCodeType"/>
i have included the namespace "cnt" of schema B in the schema A.
when myElement is the XSDElementDeclaration with name : IdentificationCode
and when i try to get the type : CountryIdentificationCodeType
by doing: myElement.getTypedefinition() i have null as value of the type.
What is wrong?
Thanks for your help.
Re: my element is declared in schema A and its type in schema B, how to get its type [message #61903 is a reply to message #61827] |
Tue, 21 June 2005 08:50   |
Elhadji,
You are providing effectively no information that I can use as a basis
for helping you. You've not shown your schemas, so although you are
certain they are valid, I have no such certainty. You've not even
shown me whether you are dealing with a global element declaration or a
local one within a complex type. As far as I know, the type definition
of an element declaration can't be null for a global element
declaration, which I why I'm starting to assume you are dealing with a
reference to an element declaration <xsd:element ref="..."/> and most
likely are hitting the case where the referenced element doesn't resolve
and hence a place holder with the right namespace and name (but no type
definition) is created. The inability to resolve names is most often
caused by failure to load the schema with an absolute URI against which
relative schemaLocations can be properly resolved.
If you need a detailed answer, please provide enough information as the
basis for that, i.e., a relatively complete example and the code you are
using to load and examine the instance.
elhadji wrote:
> Hi Ed,
> it must be a basic question; but i don't know what is mean a
> unresolved element declaration. What i'm sure is i have validate the
> schema using stylus, i have tested what you say but it until returns
> null for the value of the type.
> What i'm missing?
> Thanks for your help!
Re: my element is declared in schema A and its type in schema B, how to get its type [message #61978 is a reply to message #61903] |
Tue, 21 June 2005 12:53   |
Hi Ed, you're right
here is my schemas :
the 1st and main schema :
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns="ns:Individu"
xmlns:adr="ns:Adresse"
targetNamespace="ns:Individu"
elementFormDefault="qualified"
attributeFormDefault="unqualified">
<xs:import namespace="ns:Adresse" schemaLocation="Adresse.xsd"/>
<xs:element name="Individu" type="IndividuType">
<xs:annotation>
<xs:documentation>Un petit descriptif du schéma !</xs:documentation>
</xs:annotation>
</xs:element>
<xs:complexType name="IndividuType">
<xs:sequence>
<xs:element name="Nom" type="xs:string"/>
<xs:element name="Prenoms" type="xs:string"/>
<xs:element name="Adresse" type="adr:LigneAdresseType"/>
</xs:sequence>
</xs:complexType>
</xs:schema>
the second schema:
<xs:schema xmlns="ns:Adresse"
xmlns:lat="ns:LigneAdresse"
targetNamespace="ns:Adresse"
<xs:import namespace="ns:LigneAdresse"
schemaLocation="LigneAdresse.xsd"/>
<xs:element name="Adresse" type="LigneAdresseType"/>
<xs:complexType name="LigneAdresseType">
<xs:simpleContent>
<xs:restriction base="lat:LigneAdresseType">
</xs:restriction>
</xs:simpleContent>
</xs:complexType>
</xs:schema>
the last schema:
xmlns="ns:LigneAdresse"
targetNamespace="ns:LigneAdresse"
<xs:element name="LigneAdresse" type="LigneAdresseType"/>
<xs:simpleContent>
<xs:extension base="xs:string">
<xs:attribute name="Numero" type="xs:string"/>
<xs:attribute name="Rue" type="xs:string" use="optional"/>
<xs:attribute name="CodePostal" type="xs:string" use="optional"/>
<xs:attribute name="Ville" type="xs:string"/>
<xs:attribute name="Pays" type="xs:string"/>
</xs:extension>
</xs:simpleContent>
</xs:complexType>
</xs:schema>
My problem is when parsing the main schema and when i try to get the type
of the element named "Adresse" i have null as value;
what is wrong ?
part of the code:
i put here the most important class about the question but it can't run on
standalone(it needs many other classes ), i think it may indicates you how
to help me
Thanks again for your help!
* Copyright (C) 2003 by Genigraph
* All rights reserved.
*All usage rights are governed by the applicable Genigraph agreement.
package com.ecitiz.xsd.parser;
import java.io.File;
import java.util.ArrayList;
import java.util.Iterator;
import org.eclipse.emf.common.util.EList;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.xsd.XSDComplexTypeDefinition;
import org.eclipse.xsd.XSDElementDeclaration;
import org.eclipse.xsd.XSDModelGroup;
import org.eclipse.xsd.XSDParticle;
import org.eclipse.xsd.XSDSchema;
import org.eclipse.xsd.XSDSimpleTypeDefinition;
import org.eclipse.xsd.XSDTerm;
import org.eclipse.xsd.XSDTypeDefinition;
import org.eclipse.xsd.util.XSDResourceFactoryImpl;
import org.eclipse.xsd.util.XSDResourceImpl;
import com.ecitiz.form.generator.model.Cardinality;
import com.ecitiz.form.generator.model.FieldAttribute;
import com.ecitiz.form.generator.model.Form;
import com.ecitiz.form.generator.model.Section;
* This Action logs an authenticated user off and redirect user to welcome
* screen
* @author A. AUDEVART
public class XSDFormParser
* This method process the root element
static ArrayList listSection = new ArrayList();
static ArrayList listFieldAttribute = new ArrayList();
public Form createTheRootElement(XSDElementDeclaration elementRoot)
// Begin of what i have added
XSDElementDeclaration elementRootRef =
getElementByReference(elementRoot);
//End of what i have added
//Extract the annotation which describes the form.
Annotation annotation = new Annotation();
String help = annotation.createRootAnnotation(elementRootRef);
//Extract the appInfo
AppInfo appInfo = new AppInfo();
String appInfoString = appInfo.createRootAppInfo(elementRootRef);
Cardinality cardinality = new Cardinality(1, 1);
TypeXSD xsdType = new TypeXSD();
ModifyName modifName = new ModifyName(elementRootRef.getName(),
appInfoString);
// String nameXSD = modifName.getXSDName();
String nameForm = modifName.getFormName();
Form form = new Form(nameForm, help);
XSDTypeDefinition elementType = elementRootRef.getTypeDefinition();
if (elementType instanceof XSDComplexTypeDefinition)
XSDComplexTypeDefinition aComplexType =
(XSDComplexTypeDefinition) elementType;
//Extract the annotation which describes the first root section.
String annotString = annotation.createAnnotation(elementType);
String appInfoString2 = appInfo.createAppInfo(elementType);
ModifyName modifNameSection = new
ModifyName(elementType.getName(), appInfoString2);
String sectionNameXSD = modifNameSection.getXSDName();
String sectionName = modifNameSection.getFormName();
Section section = new Section(sectionName, annotString);
section.setCardinality(cardinality);
section.setXSDText(sectionNameXSD);
section = VerifyRepeat.isRepeatSectionType(section);
form.add(section);
ComplexType complex = new ComplexType();
complex.createAttribute(aComplexType, section, cardinality);
XSDParticle particle = aComplexType.getComplexType();
XSDTerm term = particle.getTerm();
XSDModelGroup xsdModelGroup = (XSDModelGroup) term;
EList particleList = xsdModelGroup.getParticles();
for (Iterator iter = particleList.iterator(); iter.hasNext();)
XSDParticle aParticle = (XSDParticle) iter.next();
Cardinality cardinality2 =
CardinalityType.processParticle(aParticle);
XSDTerm aTerm = aParticle.getTerm();
XSDElementDeclaration element = (XSDElementDeclaration) aTerm;
XSDElementDeclaration elementRef =
getElementByReference(element);
String help3 = annotation.createAnnotationElemDec(elementRef);
String appInfoString3 = appInfo.createRootAppInfo(elementRef);
ModifyName modifName2 = new ModifyName(elementRef.getName(),
appInfoString3);
String sectionNameXSD2 = modifName2.getXSDName();
String elementName = modifName2.getFormName();
XSDTypeDefinition elementTypeRef =
elementRef.getTypeDefinition();
xsdType.processingAnElement(section, elementTypeRef,
elementName,
sectionNameXSD2 , cardinality2, help3);
else
annotation.createAnnotation(elementRoot.getType());
SimpleType simpleType = new SimpleType();
XSDSimpleTypeDefinition aSimpleType = (XSDSimpleTypeDefinition)
elementType;
aSimpleType.getComplexType();
Cardinality cardinality3;
if ( aParticle != null)
cardinality3 = CardinalityType.processParticle(aParticle);
else
cardinality3 = new Cardinality(1, 1);
FieldAttribute field = simpleType.createSimpleType(aSimpleType,
nameForm, cardinality);
if (annotString != null)
field.setHelp(annotString);
field = VerifyRepeat.isRepeatFieldAttributeType(field);
form.add(field);
return form;
// Begin of my methods
public XSDElementDeclaration rootElementDeclarationFinder(String
schemaURL)
XSDSchema schema = null;
Object component = null;
XSDElementDeclaration rootElement = null;
// XSDParticleContent particleContent = null;
try
// LoadSchema loadSchema = new LoadSchema();
// schema = loadSchema.loadSchemaUsingResourceSet(schemaURL, null);
schema = loadSchemaUsingResourceSet(schemaURL);
catch (Exception e)
e.printStackTrace();
//Browsing the schema content and searching for Element Declarations
Iterator iter = schema.getContents().iterator();
while (iter.hasNext())
component = iter.next();
if (component instanceof XSDElementDeclaration)
//Found root element decalation
rootElement = (XSDElementDeclaration) component;
break;
return rootElement;
* This method parse an XSD Schema in a Form.
public Form createForm(String filename)
rootElement = rootElementDeclarationFinder(filename);
return createTheRootElement(rootElement);
public static XSDElementDeclaration
getElementByReference(XSDElementDeclaration
elementDeclaration)
XSDElementDeclaration targetElementDeclaration = elementDeclaration;
if (elementDeclaration.isElementDeclarationReference())
elementDeclaration.getResolvedElementDeclaration();
return targetElementDeclaration;
private XSDSchema loadSchemaUsingResourceSet(String schemaURL) throws
Exception
XSDSchema returnSchema = null;
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "xsd",
new XSDResourceFactoryImpl());
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getLoadOptions().put(XSDResourceImpl.XSD_TRACK_L OCATION,
Boolean.TRUE);
URI uri;
File file = new File(schemaURL);
if (file.isFile())
uri = URI.createFileURI(file.getCanonicalFile().toString());
else
uri = URI.createURI(schemaURL);
XSDResourceImpl xsdSchemaResource = (XSDResourceImpl)
resourceSet.getResource(uri, true);
for (Iterator resources = resourceSet.getResources().iterator();
resources.hasNext(); /* no-op */)
Resource resource = (Resource) resources.next();
if (resource instanceof XSDResourceImpl)
XSDResourceImpl xsdResource = (XSDResourceImpl) resource;
returnSchema = xsdResource.getSchema();
return returnSchema;
System.err.println("loadSchemaUsingResourceSet(" + schemaURL +
") did not contain any schemas!");
return null;
Thanks again !!
Re: my element is declared in schema A and its type in schema B, how to get its type [message #62002 is a reply to message #61978] |
Tue, 21 June 2005 14:32   |
Elhadji,
Before I dive in too deeply, which version of EMF/XSD are you using?
I.e., could you be seeing the same problem as Robert in the XSD Schema
tree posting two notes up?
It looks like this code isn't quite right and should probably be using
elementRootRef:
elhadji wrote:
> Hi Ed, you're right
> xmlns="ns:Individu" xmlns:adr="ns:Adresse"
> targetNamespace="ns:Individu" elementFormDefault="qualified"
> <xs:annotation>
> </xs:annotation>
> </xs:element>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> the second schema:
> xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:lat="ns:LigneAdresse"
> targetNamespace="ns:Adresse" elementFormDefault="qualified"
> <xs:simpleContent>
> </xs:restriction>
> </xs:simpleContent>
> </xs:complexType>
> </xs:schema>
> the last schema:
> xmlns="ns:LigneAdresse" targetNamespace="ns:LigneAdresse"
> elementFormDefault="qualified" attributeFormDefault="unqualified">
> <xs:simpleContent>
> use="optional"/>
> use="optional"/>
> </xs:extension>
> </xs:simpleContent>
> </xs:complexType>
> </xs:schema>
> type of the element named "Adresse" i have null as value;
> what is wrong ?
> part of the code:
> run on standalone(it needs many other classes ), i think it may
> indicates you how to help me
> * screen
> * * @author A. AUDEVART
> appInfoString);
> form.add(section);
> ModifyName(elementRef.getName(), appInfoString3);
> elementName,
> else
> (XSDSimpleTypeDefinition) elementType;
> else
> simpleType.createSimpleType(aSimpleType, nameForm, cardinality);
> form.add(field);
> return form;
> schemaURL)
> try
> null);
> } catch (Exception e) {
> break;
> return rootElement;
> getElementByReference(XSDElementDeclaration elementDeclaration) {
> if (elementDeclaration.isElementDeclarationReference()) {
> throws Exception
> Boolean.TRUE);
> URI uri;
> if (file.isFile())
> else
> return null;
> Thanks again !!
Re: my element is declared in schema A and its type in schema B, how to get its type [message #62048 is a reply to message #62025] |
Wed, 22 June 2005 09:57  |
--------------060300000101020803080501
Elhadji,
If I try the schemas you've provided with XSDMainExample (renamed from
XSDMainTest in older drivers) it seems to work fine right now. I.e., I
add this code within the loadAndPrint method:
XSDSchema xsdSchema = xsdResource.getSchema();
XSDComplexTypeDefinition indivduType =
xsdSchema.resolveComplexTypeDefinition("IndividuType");
if (indivduType.getContainer() != null)
XSDElementDeclaration xsdElementDeclaration =
(XSDElementDeclaration)((XSDParticle)((XSDModelGroup)indivdu Type.getComplexType().getContent()).getContents().get(2)).ge tContent();
System.err.println("#1#" +
xsdElementDeclaration.getTypeDefinition());
XSDElementDeclaration adresseElement =
xsdSchema.resolveElementDeclaration("Adresse");
if (adresseElement.getContainer() != null)
System.err.println("#2#" + adresseElement.getTypeDefinition());
And that produces this result:
#1#org.eclipse.xsd.impl.XSDComplexTypeDefinitionImpl@3f9ff1e3
(element: [xs:complexType: null]) (name: LigneAdresseType,
targetNamespace: ns:Adresse) (derivationMethod: restriction, final:
[], abstract: <unset>, contentTypeCategory: simple,
prohibitedSubstitutions: [], lexicalFinal: null, block: null, mixed:
<unset>)
#2#org.eclipse.xsd.impl.XSDComplexTypeDefinitionImpl@3f9ff1e3
<unset>)
So both Adresse elements have a non-null type.
Without the ability to reproduce your problem, I'm at a loss what to
suggest. It's possible that 99227
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=99227> fixed the problem,
so trying the latest build might be good.
elhadji wrote:
> Hi Ed,
> I'm using EMF/XSD 2.1.0, here is what i have download two months ago:
> xsd-SDK-I200504070700.zip Perhaps it was not stable when i was
> download it.
> and Eclipse 3.0.1
> About this instruction :
> String annotString = annotation.createAnnotation(elementRoot.getType());
> elementRoot is the root XSDElementDeclaration of the 1st schema
> We have another model where we define many others classes we use in
> the parser; that's why i have posted the main classe of the parser, it
> would be very huge to post all classes.
> i can get element defined as ref like this:
> <xsd:element ref="cbc:Postbox" minOccurs="0" maxOccurs="1">
> where "Postbox" is defined in another schema
> but i can't get the type of elemnt defined like this :
> <xsd:element name="ID" type="udt:IdentifierType" minOccurs="0"
> maxOccurs="1">
> where "IdentifierType" is defined in another schema.
> The value of the type in this case is null!
> What is wrong!
> I hope my question is more understandable.
> Thank you a lot for your help!
<html>
<head>
http-equiv="Content-Type">
</head>
Elhadji,<br>
<br>
Re: my element is declared in schema A and its type in schema B, how to get its type [message #595734 is a reply to message #61754] |
Mon, 20 June 2005 11:49  |
Elhadji,
Doing
xsdElementDeclaration.getResolveElementDeclaration().getType Definition()
should return it. If that's null, you're most likely looking at an
unresolved element declaration reference.
elhadji wrote:
> How can i do?
> IdentificationCode
> What is wrong?
Re: my element is declared in schema A and its type in schema B, how to get its type [message #595796 is a reply to message #61827] |
Elhadji,
elhadji wrote:
> Hi Ed,
> What i'm missing?
Re: my element is declared in schema A and its type in schema B, how to get its type [message #595827 is a reply to message #61903] |
Hi Ed, you're right
xmlns="ns:Individu"
<xs:annotation>
</xs:annotation>
</xs:element>
<xs:sequence>
</xs:sequence>
</xs:complexType>
</xs:schema>
the second schema:
<xs:simpleContent>
</xs:restriction>
</xs:simpleContent>
</xs:complexType>
</xs:schema>
the last schema:
<xs:simpleContent>
</xs:extension>
</xs:simpleContent>
</xs:complexType>
</xs:schema>
what is wrong ?
part of the code:
to help me
* screen
appInfoString);
form.add(section);
appInfoString3);
elementName,
else
elementType;
else
form.add(field);
return form;
schemaURL)
try
catch (Exception e)
break;
return rootElement;
elementDeclaration)
Exception
Boolean.TRUE);
URI uri;
if (file.isFile())
else
return null;
Thanks again !!
Re: my element is declared in schema A and its type in schema B, how to get its type [message #595841 is a reply to message #61978] |
Elhadji,
elementRootRef:
elhadji wrote:
> Hi Ed, you're right
> <xs:annotation>
> </xs:annotation>
> </xs:element>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> the second schema:
> <xs:simpleContent>
> </xs:restriction>
> </xs:simpleContent>
> </xs:complexType>
> </xs:schema>
> the last schema:
> <xs:simpleContent>
> use="optional"/>
> use="optional"/>
> </xs:extension>
> </xs:simpleContent>
> </xs:complexType>
> </xs:schema>
> what is wrong ?
> part of the code:
> * screen
> appInfoString);
> form.add(section);
> elementName,
> else
> else
> form.add(field);
> return form;
> schemaURL)
> try
> null);
> break;
> return rootElement;
> throws Exception
> Boolean.TRUE);
> URI uri;
> if (file.isFile())
> else
> return null;
> Thanks again !!
Re: my element is declared in schema A and its type in schema B, how to get its type [message #595850 is a reply to message #62002] |
Wed, 22 June 2005 04:43  |
Hi Ed,
Perhaps it was not stable when i was download it.
and Eclipse 3.0.1
We have another model where we define many others classes we use in the
parser; that's why i have posted the main classe of the parser, it would
maxOccurs="1">
What is wrong!
Re: my element is declared in schema A and its type in schema B, how to get its type [message #595856 is a reply to message #62025] |
Elhadji,
<unset>)
<unset>)
elhadji wrote:
> Hi Ed,
> download it.
> and Eclipse 3.0.1
> maxOccurs="1">
> What is wrong!
<html>
<head>
</head>
Elhadji,<br>
<br>
Current Time: Wed Jul 16 10:13:18 EDT 2025
Powered by FUDForum. Page generated in 0.57335 seconds
