crash when leafing the welcome to eclipse 3.1 site [message #61699] |
Sun, 08 May 2005 16:24  |
Originally posted by: martin.raschke.t-online.de
I have two eclipse 3.1M6 instaled on different machines one AMD
Sempron 2400+ 512MB and one Pentium 4 2400 1GB both with WIN2000 SP4
and j2SDK1.4.2_07. JAVA_HOME is set properly. Using eclipse on the AMD
the welcome page dosn't work fine: The items Overview, Tutorials,
Samples and What's New could not be selected, just a tooltip appears,
leaving the mousecursor an a item. Just the Workbench item in the
upper right can be selected and clicked, but then eclipse is teminated
with a vm error:
JVM terminated. Exit code=1
c:\j2sdk1.4.2_7\jre\bin\javaw.exe
-Xmx256M
-jar C:\eclipse\startup.jar
-os win32
-ws win32
-arch x86
-launcher C:\eclipse\eclipse.exe
-name Eclipse
-showsplash600
-exitdata 658_48
-vm c:\j2sdk1.4.2_7\jre\bin\javaw.exe
-vmargs
-Xmx256M
-jar c:\eclipse\startup.jar
on the pentium machine everithing works fine.
Dose anyone know this problem and knows how to fix it?
Thanks a lot
Martin Raschke
Re: crash when leafing the welcome to eclipse 3.1 site [message #61747 is a reply to message #61699] |
Sun, 08 May 2005 19:25   |
Originally posted by: xxx.ca.ibm.com
For the first problem, bad welcome images/layout, you need at least IE 6.0
(ie: IE inlcluded in Windows XP) for the Welcome to work. What version of IE
do yo uhave on these machines?
For second problem, the crash, try making any view a fast view, do you get a
crash?
you can open a bug with details to reproduce.
Mazen.
"Martin Raschke" <martin.raschke@t-online.de> wrote in message
news:pjrs71d6tj0s5mgs1haqap2gf5rd66pjf3@4ax.com...
> with a vm error:
> -Xmx256M
> -os win32
> -ws win32
> -arch x86
> -name Eclipse
> -showsplash600
> -exitdata 658_48
> -vmargs
> -Xmx256M
> Thanks a lot
> Martin Raschke
Re: crash when leafing the welcome to eclipse 3.1 site [message #61868 is a reply to message #61747] |
Mon, 09 May 2005 04:27  |
Hy Mazen,
thank you very much that was the right hint. I'm not using IE and so I
never updatede on this machine. Now eclips works fine on both
machines. There is also no more crash when leaving the welcom to
eclipse site by clicking the upper right workbench icon.
regards
Martin Raschke
>crash?
>Mazen.
>> with a vm error:
>> -Xmx256M
>> -os win32
>> -ws win32
>> -arch x86
>> -name Eclipse
>> -showsplash600
>> -exitdata 658_48
>> -vmargs
>> -Xmx256M
>> Thanks a lot
>> Martin Raschke
FUDForum. Page generated in 0.10369 seconds
