Home » Language IDEs » C / C++ IDE (CDT) » Installation with cdt problem using win98
Installation with cdt problem using win98 [message #61673] Fri, 07 February 2003 16:08
Originally posted by: bruno.roso.t-online.de
I'am a newbie, having an installation problem with cdt.
Current configuration:
Eclipse 2.1
CDT 1.01
GCC: MINGW 2.95.2
gcc-bin path included in autoexec.
PATH contains "C:\ProgOffi\gcc\bin", which contains the gcc binaries.
Tried to compile my first program, similar to example in CDT FAQ.
Received an error message "cpp.exe: installation problem, cannot exec
`cpp': No such file or directory".
You see, my path should be correct, otherwise gcc.exe wouldn't start. But
then there seems to be a problem with the paths.
I tried to include a "set" command in the makefile. The reported
environment variables shows an undefined (empty) PATH variable.
Who can help? Thank you very much.
Bruno
Previous Topic:cdt makefile generating
Next Topic:Breakpoints?
Current Time: Sat Jul 26 20:53:56 EDT 2025
Powered by FUDForum. Page generated in 0.05265 seconds
