Home » Language IDEs » PHP Development Tools (PDT) » PHP script extension not found
PHP script extension not found [message #61672] Tue, 27 November 2007 12:18 Go to next message
Originally posted by: t.nuin.bath.ac.uk
Hi.,
I have Googled but drowned under the results of a search on "Eclipse,"
"PHP" and "Extensions." I think this is probably a fairly simple newbie
mistake too, so if anyone knows the answer it would be a big help.
I am able to debug PHP scripts successfully (note that I am dealing with
scripts not debugging on a server). However, it does not seem to pick up
the oci8.so extension that I have installed, failing with the message
"Call to undefined function ocilogon()". The same script when run
directly from the command line does *not* fail.
That suggests to me that I may be ignorant of some necessary step to
configure PHP in Eclipse, but I don't know what.
I am using an Ubuntu platform and I have enabled the OCI8 extension in
/etc/php5/cli/php.ini.
Is there anything special that needs to be done in Eclipse to make it
accept this?
Sorry if this is an obvious question. Am still very new to Eclipse and
trying to learn it whilst on a project.
Many thanks,
-Taliesin.
Re: PHP script extension not found [message #62426 is a reply to message #61672] Fri, 07 December 2007 14:42 Go to previous message
Originally posted by: nospam.mckenzies.net
Taliesin Nuin wrote:
> Hi.,
> accept this?
> Many thanks,
> -Taliesin.
The Zend debugger doesn't use your PHP executable or your php.ini.
In my debugger install I have the following:
/usr/local/bin/eclipse/plugins/org.zend.php.debug.debugger.l inux.x86_5.2.10.v20070905/resources/php5
/usr/local/bin/eclipse/plugins/org.zend.php.debug.debugger.l inux.x86_5.2.10.v20070905/resources/php4
Each has their own executable and php.ini. You should probably add
extensions there.
I also see in the preferences for PHP / PHP Executables that if you edit
the PHP4 or PHP5 that there is a place to add an alternate php.ini, but
my fields are all disabled. Anyone know why?
-Shawn
Previous Topic:Displaying classes
Next Topic:PDT 1.0.1 M1 - is delayed to 13-Dec
Current Time: Sat Aug 30 23:05:14 EDT 2025
Powered by FUDForum. Page generated in 0.03494 seconds
