Home » Language IDEs » AspectJ » compiler not copying .xml file to output folder
compiler not copying .xml file to output folder [message #61658] Sun, 05 February 2006 13:18 Go to next message
The standard java nature will copy all .xml files to the output folder (eg, my spring.xml files). But when I use the aspectj nature, these files are /not/ copied, and hence all my tests fail. Is this just a limitation/bug with ajdt or is there some setting that I cannot find?
-barry
Re: compiler not copying .xml file to output folder [message #61776 is a reply to message #61658] Wed, 08 February 2006 06:03 Go to previous message
This does sound like a bug. I see you've raised it in Bugzilla (126498) so
we'll investigate it there.
Matt.
Re: compiler not copying .xml file to output folder [message #592154 is a reply to message #61658] Wed, 08 February 2006 06:03 Go to previous message
Matt.
Previous Topic:AspectJ DOM
Next Topic:Which version for Websphere WSAD
Current Time: Fri May 09 11:49:22 EDT 2025
Powered by FUDForum. Page generated in 0.03501 seconds
