Best way to extend XSD editor [message #61589] |
Tue, 14 June 2005 10:04  |
We need to build a set of plug-ins that are extensions to the built-in XSD
editor. I'm looking for advice on how best to do the following:
We want to make use of the xs:annotation/xs:appinfo feature of XML schema to
embed some extra processing information into the schema. We will use these
additional machine-readable annotations to facilitate code generation logic
that is being built into other plugins on top of JDT. For an analogy for
what we are trying to accomplish, look at how JAXB can use inline XSD
annotations to provide customization of the generated JAXB binding classes.
Here is a high level use case.
The user would open an XML Schema XSD file using the XSD editor. The editor
and associated views would offer right-click menu options to add our
annotation tags to each customType and/or element in the XSD. The
implementation of the GUI would be similar to the Refactoring and Source
pop-up windows that you see in JDT.
We also want to add a background incremental builder that would "compile"
the XSD and add problem markers to all of the customTypes and elements that
are missing annotations.
The annotations themselves are bindings to other classes in our object model
and JAXB binding layer. The ultimate goal of the metadata is to help the
developer build a EJB session bean that reads data from an EJB entity
bean-based object model and write the data to a JAXB API derived from an XML
schema. A lot of this code is boilerplate in nature and could be generated
if we could map each customType/element to it's underlying EJB and
field/relationship.
Does the XSD editor that you see in 3.0.x use EMF in the background to model
the structure of the document? Does this API fully support the annotation
features of the XML schema spec?
As an alternative approach we would use an external binding annotation
mechanism. We would design an XML schema that describes our binding
metadata. We would use EMF to build a custom editor for documents that
conform to this approach. To feed data to the editor we would run the XSD
file through a standard XSLT stylesheet to produce a derivative annotation
file that conforms to the EMF schema. This seems easier because I'm not
trying to shoehorn functionality into places where it might not fit.
So what do you think? What is the best fit for this type of problem?
Dave
Re: Best way to extend XSD editor [message #61636 is a reply to message #61589] |
Tue, 14 June 2005 12:21   |
--------------030105070701090507020601
Dave,
I've added comments below inline.
This is also just like we do for our XML Schema to Ecore conversion:
XML Schema to Ecore Mapping
< http://www.eclipse.org/emf/docs/overviews/XMLSchemaToEcoreMa pping.pdf>
Popup actions are easy to add via registered popup. There's an example
of a popup action for EClass in org.eclipse.emf.ecore.editor.plugin.xml.
This allows your popup to appear in editors you've never modified.
I don't have much experience with builders (although we do have one to
convert JET templates to Java source). We usually do stuff like this
via an explicit action.
>field/relationship.
Maybe you should consider using EMF instead of JAXB. We provide roughly
equivalent function.
Yes, the sample editor uses the XSD model to implement its support. The
XSD model does support working with annotations, but the low level
annotations contents themselves will require you to use DOM, since
annotations can be arbitrary DOM. There are examples of how to do this
in XSDPrototypicalSchema.
This is an interesting approach too. One day well want to do something
like this for our Ecore annotations so that it's easier to annotate a
schema that can't be changed.
Probably you want to start simple and get some cool stuff working
quickly. I think a registered popup action is the fastest way to get
started. Probably the popup action will even work with the nice XML
Schema editor in the WTP project (which is also based on the XSD model)
and even in the WSDL editor...
>Thanks
>Dave
<html>
<head>
</head>
Dave,<br>
<br>
I've added comments below inline.<br>
<br>
<br>
Dave Bolt wrote:
<blockquote cite="midd8mo5f$ods$1@news.eclipse.org" type="cite">
<pre wrap="">We need to build a set of plug-ins that are extensions to the built-in XSD
</pre>
</blockquote>
This is also just like we do for our XML Schema to Ecore conversion:<br>
<blockquote><a
href=" http://www.eclipse.org/emf/docs/overviews/XMLSchemaToEcoreMa pping.pdf">
XML Schema to Ecore Mapping</a><br>
</blockquote>
<pre wrap="">Here is a high level use case.
</pre>
</blockquote>
org.eclipse.emf.ecore.editor.plugin.xml. This allows your popup to
appear in editors you've never modified.<br>
<pre wrap="">We also want to add a background incremental builder that would "compile"
</pre>
</blockquote>
via an explicit action.<br>
<pre wrap="">The annotations themselves are bindings to other classes in our object model
field/relationship.
</pre>
</blockquote>
roughly equivalent function.<br>
<pre wrap="">Does the XSD editor that you see in 3.0.x use EMF in the background to model
</pre>
</blockquote>
The XSD model does support working with annotations, but the low level
in XSDPrototypicalSchema.<br>
<pre wrap="">As an alternative approach we would use an external binding annotation
</pre>
</blockquote>
schema that can't be changed.<br>
<pre wrap="">So what do you think? What is the best fit for this type of problem?
</pre>
</blockquote>
and even in the WSDL editor...<br>
<pre wrap="">Thanks
Dave
</pre>
</blockquote>
<br>
</body>
</html>
--------------030105070701090507020601--
Re: Best way to extend XSD editor [message #65920 is a reply to message #61684] |
Mon, 06 February 2006 16:39  |
Originally posted by: gennady_vanin-online.yahoo.com.br
Hello Dave,
I am eager to understand why have u moved from Castor to JAXB?
Correct me,
Guennadi Vanine
> Thanks for the quick reply.
> We've been using JAXB for quite some time. It's been working well for
> us as a Java/XML binding where the XML is governed by an XSD file. We
> started with Castor and moved to JAXB over time. Probably too much
> code to move to EMF.
> We're probably going to go with the external binding file approach.
> Tweaking the XSD to add annotations would cause many false updates (in
> our project re-release of a shared JAR file) just because an
> annotation was tweaked. So our model is similar to the metadata split
> between the base Ecore model metadata and the EMF code generator
> metadata.
> Dave
Re: Best way to extend XSD editor [message #595680 is a reply to message #61589] |
Dave,
>field/relationship.
>Thanks
>Dave
<html>
<head>
</head>
Dave,<br>
<br>
<br>
<br>
</pre>
</blockquote>
<blockquote><a
</blockquote>
</pre>
</blockquote>
</pre>
</blockquote>
field/relationship.
</pre>
</blockquote>
</pre>
</blockquote>
</pre>
</blockquote>
</pre>
</blockquote>
<pre wrap="">Thanks
Dave
</pre>
</blockquote>
<br>
</body>
</html>
Re: Best way to extend XSD editor [message #595697 is a reply to message #61636] |
Tue, 14 June 2005 16:24  |
We've been using JAXB for quite some time. It's been working well for us as
a Java/XML binding where the XML is governed by an XSD file. We started with
Castor and moved to JAXB over time. Probably too much code to move to EMF.
We're probably going to go with the external binding file approach. Tweaking
the XSD to add annotations would cause many false updates (in our project
re-release of a shared JAR file) just because an annotation was tweaked. So
our model is similar to the metadata split between the base Ecore model
metadata and the EMF code generator metadata.
Dave
Re: Best way to extend XSD editor [message #597523 is a reply to message #61684] |
Hello Dave,
Correct me,
Guennadi Vanine
> metadata.
> Dave
FUDForum. Page generated in 0.03802 seconds
