Home » Eclipse Projects » Equinox » OSGi Servlet Filter Proposal
OSGi Servlet Filter Proposal [message #61517] Tue, 14 February 2006 20:32 Go to next message
Originally posted by: jfallows.txesystems.com
Folks,
After studying the equinox codebase, I've come up with the following
proposal to add support for Servlet Filters. Please let me know what
you think.
* Request flow
The processing flow for a particular request must be well defined so
that Filters are executed at the appropriate times, either inside the
OSGi Web Plugin, or in the host container, depending on where they are
registered.
o Host J2EE Filters (including BridgeFilter)
o Embedded OSGi Filters
o Host J2EE BridgeServlet
o Embedded OSGi Servlets
* Initialization
Move the FrameworkLauncher initialization code into
BridgeServletContextListener, shared as a ServletContext attribute by
both BridgeServlet and BridgeFilter. One reference to
ServletConfig.getInitParameter() in BridgeServlet can be changed to
ServletContext.getInitParameter(), used to configure the framework controls.
* BridgeFilter
Create a new class, BridgeFilter, to invoke embedded OSGi Filters.
public class BridgeFilter implements Filter
public static void registerFilterDelegate(
Filter filter)
This code follows a similar design pattern as BridgeServlet, after
refactoring the FrameworkLauncher initialization into
BridgeServletContextListener.
* Bridge Web Application
The following shows the web.xml configuration needed by the OSGi Bridge.
<filter>
<filter-name>equinox</filter-name>
<filter-class>
org.eclipse.equinox.servlet.bridge.BridgeFilter
</filter-class>
</filter>
<filter-mapping>
<servlet-name>equinox</servlet-name>
<dispatcher>REQUEST</dispatcher>
<dispatcher>FORWARD</dispatcher>
<dispatcher>INCLUDE</dispatcher>
</filter-mapping>
<listener>
org.eclipse.equinox.servlet.bridge.BridgeServletContextListe ner
</listener>
<servlet>
<servlet-class>
</servlet-class>
</servlet>
<servlet-mapping>
<url-pattern>/bridge</url-pattern>
</servlet-mapping>
Notice that the BridgeFilter is registered for REQUEST, FORWARD and
INCLUDE dispatchers, so that the OSGi HttpService can decide if any OSGi
Filters are registered for the current dispatcher. The ERROR dispatcher
is not currently necessary as that would require <web-app><error-page>
integration as well to be useful.
* FilterChainRegistration
It is legal for multiple Filter instances to be registered under the
same alias, but they all form a single FilterChain and are chained in
registration order via FilterChain.doFilter(ServletRequest,
ServletResponse).
During OSGi Web Plugin startup, a FilterChainRegistration is lazily
created for the given alias, and the registered Filter instance is
added, resulting in a well-defined FilterChain for the given alias and
dispatcher type (REQUEST, INCLUDE, FORWARD).
* ProxyFilter
An instance of the ProxyFilter class acts as the delegate for all
BridgeFilter requests.
public class ProxyFilter implements Filter
public void init(
FilterConfig config)
public void destroy()
public void doFilter(
ServletRequest request,
ServletResponse response,
FilterChain chain)
// lookup up FilterChainRegistration
// registration.handleRequest(request, response)
// chain.doFilter(request, response);
public void registerFilter(
String alias,
Filter filter,
Dictionary initParams,
int dispatcherMask,
HttpContext context) throws ServletException, NamespaceException
* Filter execution during Forward and Include
The RequestDispatcher API supports the concept of forwarding and
including other request paths, causing Filters that are registered as
FORWARD or INCLUDE dispatchers to be invoked before any Servlet
processing the request.
Such flows need to be routed through the main Web application
RequestDispatcher but directed to the BridgeFilter and BridgeServlet to
get the right processing sequence.
Therefore ServletContext.getRequestDispatcher(String
contextRelativePath) is prefixed with the URL mapping for the
BridgeServlet ("/bridge" in the above example) when retrieved from
inside an OSGi Web Plugin. Similarly, the same mapping prefix is
required when ServletRequest.getRequestDispatcher(String path) is called
with an "absolute" path (leading / char).
The returned RequestDispatcher can set the value of a Servlet attribute
to "FORWARD" or "INCLUDE" when either the forward() or include() method
is called respectively.
* Extension point configuration
A new filters extension point follows similar syntax to the servlets
extension point syntax, with additional information about the dispatcher
registration (REQUEST, INCLUDE, FORWARD).
public class FilterManager implements ExtensionPointTracker.Listener
A new FilterManager class parses the extension point syntax and
registers the Filter with the HttpService.
* HttpService
The HttpService needs to be enhanced to support Filter registration.
public interface HttpService
public final int DISPATCHER_REQUEST = 0;
public final int DISPATCHER_FORWARD = 1;
public final int DISPATCHER_INCLUDE = 2;
String alias,
Filter filter,
int dispatcherMask,
HttpContext context) throws ServletException, NamespaceException;
// existing methods
I'll be prototyping this implementation while awaiting feedback from the
group. For now, I'll leave the HttpService API unchanged and cast to
HttpServiceImpl in FilterManager to register each embedded OSGi Filter.
Let me know what you think.
Kind Regards,
John Fallows.
Author: Pro JSF and Ajax: Building Rich Internet Components
http://apress.com/book/bookDisplay.html?bID=10044
Re: OSGi Servlet Filter Proposal [message #61569 is a reply to message #61517] Wed, 15 February 2006 08:56 Go to previous messageGo to next message
Originally posted by: skaegi.sympatico.ca
Hi John,
These look good and are both worth looking at.
Could you open "two" Enhancement Requests for this.
One for the refactoring the framework launcher to a context listener.
The other for adding filter support.
Thanks.
-Simon
"John R. Fallows" <jfallows@txesystems.com> wrote in message
news:dsu0c2$o1i$1@utils.eclipse.org...
> Folks,
> you think.
> * Request flow
> registered.
> * Initialization
controls.
> * BridgeFilter
> Filter filter)
> <filter>
> <filter-class>
> </filter-class>
> </filter>
> <filter-mapping>
> </filter-mapping>
> <listener>
> </listener>
> <servlet>
> <servlet-class>
> </servlet-class>
> </servlet>
> <servlet-mapping>
> </servlet-mapping>
> ServletResponse).
> * ProxyFilter
> public void init(
> FilterChain chain)
> String alias,
> Filter filter,
> int dispatcherMask,
> * HttpService
> String alias,
> Filter filter,
> int dispatcherMask,
> // existing methods
> Kind Regards,
> John Fallows.
Re: OSGi Servlet Filter Proposal [message #61616 is a reply to message #61569] Wed, 15 February 2006 12:38 Go to previous messageGo to next message
Hi Simon,
Simon Kaegi wrote:
> Hi John,
Thanks, I'll submit a patch for each as they become functional. :)
Done.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=128067
Refactor FrameworkLauncher startup into ServletContextListener
https://bugs.eclipse.org/bugs/show_bug.cgi?id=128068
Servlet Filter support for Equinox
Kind Regards,
John Fallows.
> Thanks.
> -Simon
>> Folks,
>> you think.
>> * Request flow
>> registered.
>> * Initialization
> controls.
>> * BridgeFilter
>> Filter filter)
>> <filter>
>> <filter-class>
>> </filter-class>
>> </filter>
>> <filter-mapping>
>> </filter-mapping>
>> <listener>
>> </listener>
>> <servlet>
>> <servlet-class>
>> </servlet-class>
>> </servlet>
>> <servlet-mapping>
>> </servlet-mapping>
>> ServletResponse).
>> * ProxyFilter
>> public void init(
>> FilterChain chain)
>> String alias,
>> Filter filter,
>> int dispatcherMask,
>> * HttpService
>> String alias,
>> Filter filter,
>> int dispatcherMask,
>> // existing methods
>> Kind Regards,
>> John Fallows.
Re: OSGi Servlet Filter Proposal [message #61640 is a reply to message #61616] Wed, 15 February 2006 14:35 Go to previous message
I would agree. Just be aware that the all-important
requires servlet 2.4 (if I am not mistaken). Fine with me, but some
container folks might object?
Frameworklauncher should really be in a separate module, with privileged
security etc., cf. Tomcat manager.
Wolfgang
Previous Topic:Problems with platform I20060210-1640
Next Topic:Article: Developing Eclipse/OSGi component webapps
Current Time: Thu Jul 17 20:39:40 EDT 2025
Powered by FUDForum. Page generated in 1.68904 seconds
