add the aspectj nature in my plugin [message #61510] |
Tue, 31 January 2006 12:56  |
Hi, I'm developing an eclipse plugin that doesn't use aspectj on its own
classes but needs to weave the classes of the projects it is applied to
when deployed (I have a custom nature). All the aspects I need are
contained in the plugin itself.
The first thing I tried is to add the aspectj nature to the project when I
add my own one but I have to use an internal ajdt class (AspectJUtils) and
it does the job asynchronously, hence I can't do the rest of the job in
the same action.
Copy and paste the code from the internal classes of ajdt doesn't appear
to be a good idea, so any suggestion?
What exactly is a "aspectj-enabled plugin"? Doesn't seem to fit my problem
from the docs, but I can surely miss something.
Thanks a lot in advance.
Luca.
Re: add the aspectj nature in my plugin [message #61566 is a reply to message #61510] |
Wed, 01 February 2006 06:15   |
Hi Luca,
So you want to be able to programmatically convert a Java project to an
AspectJ project? It sounds like the
internal AJDTUtils.addAspectJNature(project) method is the one you want. I
suggest you try calling this, and if it is what you want then raise a
bugzilla report requesting public API for this. Our approach is to
start with everything as internal API, and then add things to
the public API as required. This method sounds like a good candidate to
make public for AJDT 1.4.
Matt.
> the same action.
> Luca.
Re: add the aspectj nature in my plugin [message #61610 is a reply to message #61566] |
Fri, 03 February 2006 05:41  |
Hi Matt,
thanks for the reply, it is exactly what I need to do. I tried to use the
AJDTUtils.addAspectjNature method despite it is internal (it's worth a
warning...) but the problem is that it just calls method
internal_addAspectJNature asynchronously. I need to add my own nature
after the aspectj nature has been added since it puts a jar file into the
aspectPath of the project, hence the call should be synchronous.
I solved my problem by copy and paste some of the code of the
internal_addAspectJNature method, it is not really a killer solution, but
it works. I will submit a new bug asking for this last method (or another
method that simply calls this one) to be public.
Thanks again,
Luca.
Re: add the aspectj nature in my plugin [message #592061 is a reply to message #61510] |
Hi Luca,
Matt.
> the same action.
> Luca.
Re: add the aspectj nature in my plugin [message #592078 is a reply to message #61566] |
Hi Matt,
Thanks again,
Luca.
FUDForum. Page generated in 0.25724 seconds
