Home » Archived » BIRT » Extension loading error
Extension loading error [message #61482] Mon, 25 July 2005 01:01 Go to next message
Hi guys,
I managed to run the engine in RunReport.java but everytime I run I have
this exception logged in meta.log ? May I know what do they mean ? I can't
seemed to see any charts in html or pdf, but running from Eclipse is fine.
2005-07-24 11:55:19 Message [Extension loading error]
Exception [org.eclipse.birt.report.model.metadata.ExtensionException:
Message:The extension point [org.eclipse.birt.report.model.encryptionHelper]
is not found. Error code:EXTENSION_POINT_NOT_FOUND
org.eclipse.birt.report.model.metadata.ExtensionLoader.doLoa d(ExtensionLoade
r.java:103)
org.eclipse.birt.report.model.metadata.ExtensionLoader.load( ExtensionLoader.
java:63)
org.eclipse.birt.report.model.metadata.ExtensionManager.init ialize(Extension
Manager.java:40)
org.eclipse.birt.report.model.api.DesignEngine.initialize(De signEngine.java:
107)
org.eclipse.birt.report.model.api.DesignEngine.newSession(De signEngine.java:
148)
org.eclipse.birt.report.engine.parser.ReportParser.parse(Rep ortParser.java:7
9)
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(
ReportEngineHelper.java:87)
org.eclipse.birt.report.engine.api.ReportEngine.openReportDe sign(ReportEngin
e.java:216)
at RunReport.run(RunReport.java:187)
at RunReport.start(RunReport.java:137)
at RunReport.main(RunReport.java:50)
Re: Extension loading error [message #61831 is a reply to message #61482] Tue, 26 July 2005 10:10 Go to previous message
Greeting,
In RunReport.java, the Engine home is located at the the BIRT engine runtime
(config.setEngineHome(
".../org.eclipse.birt.report.viewer_1.0.0/birt/WEB-INF" );). But in
WEB-INF\plugins folder, there is no org.eclipse.birt.report.model plugin, so
the ExtensionLoader cannot load encryptionHelper extension, which belongs to
model plugin. Neverthless, the exception does not influence the output
result.
If you set the the EngineHome same with BIRT_HOME, the exception won't
appear any more.
If you cannot see any charts in preview, please add the following statements
to RunReport.java:
HTMLRenderContext renderContext = new HTMLRenderContext();
renderContext.setImageDirectory("ImageFolder");
task.setContext(renderContext);
Cheers.
Nina
"JTan" <jamestanms@hotmail.com> wrote in message
news:dc1rn3$9lv$1@news.eclipse.org...
> Hi guys,
> can't
> Thanks
> at
> r.java:103)
> at
> java:63)
> at
> Manager.java:40)
> at
> 107)
> at
> 148)
> at
> 9)
> at
> at
> e.java:216)
Previous Topic:page numbers
Next Topic:selecting a break dynamically
Current Time: Tue Jul 15 22:55:35 EDT 2025
Powered by FUDForum. Page generated in 0.09991 seconds
