Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Validation action failed due to attribute type is 'long'
Validation action failed due to attribute type is 'long' [message #61473] Wed, 15 November 2006 08:43 Go to next message
Hi newsgroup,
I defined an attribute invariant via OCL:
self.property>=0
If this property has the type EInt everything is fine and the Validation
action in my GMF editor works as expercted.
But if the type of the property is changed into ELong, I get a
'Validation action failed' message with the following stack trace:
java.lang.ClassCastException: java.lang.Integer
at java.lang.Long.compareTo(Unknown Source)
at org.eclipse.emf.ocl.expressions.impl.EvaluationVisitorImpl.
visitOperationCallExp(EvaluationVisitorImpl.java:1054)
at org.eclipse.emf.ocl.expressions.impl.OperationCallExpImpl.ac cept
(OperationCallExpImpl.java:274)
at org.eclipse.emf.ocl.query.impl.QueryImpl.evaluate(QueryImpl. java:242)
at org.eclipse.emf.ocl.query.impl.QueryImpl.check(QueryImpl.jav a:278)
Is that OCL expression not applicable for 'long' properties?
Thanks, Andreas
PS: I'm using version 1.01 of EMFT OCL.
Re: Validation action failed due to attribute type is 'long' [message #61497 is a reply to message #61473] Wed, 15 November 2006 10:43 Go to previous messageGo to next message
The problem is, that Long is not mapped to the primitive type OCL_INTEGER!
So, in order to compare the class attribute with a constant, the
Long.compareTo method is used, which demands a Long type to compare to.
But the given constant is declared as Integer!
A possible solution is to introduce a new attribute which is of type
long. The OCL expression uses then the new attribute instead of a given
value.
Is there another way to solve this???
Please help, because I don't want to pollute my model with such 'compare
attributes'!!!
Why is the Long type not mapped to OCL_INTEGER???
Alternatively why does OCL_INTEGER not base on Long?
Thanks, Andreas
Andreas Werner wrote:
> Hi newsgroup,
> self.property>=0
> Thanks, Andreas
Re: Validation action failed due to attribute type is 'long' [message #61520 is a reply to message #61497] Wed, 15 November 2006 11:32 Go to previous message
Hi, Andreas,
Yes, the OCL Integer type should be implemented by Long. Would you mind
opening a bug report?
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=MDT& version=1.0.1&component=UML2%20OCL&bug_severity=norm al&form_name=enter_bug
Also, as this is an OCL problem, I am replying to the MDL UML2 OCL
newsgroup, which is the new home of the OCL component.
Christian
> value.
> attributes'!!!
> Thanks, Andreas
>> Hi newsgroup,
>> self.property>=0
>> Thanks, Andreas
Re: Validation action failed due to attribute type is 'long' [message #595686 is a reply to message #61473] Wed, 15 November 2006 10:43 Go to previous message
value.
attributes'!!!
Thanks, Andreas
> Hi newsgroup,
> self.property>=0
> Thanks, Andreas
Re: Validation action failed due to attribute type is 'long' [message #595695 is a reply to message #61497] Wed, 15 November 2006 11:32 Go to previous message
Hi, Andreas,
Christian
> value.
> attributes'!!!
> Thanks, Andreas
>> Hi newsgroup,
>> self.property>=0
>> Thanks, Andreas
Previous Topic:Validation action failed due to attribute type is 'long'
Next Topic:[n] Eclipse 3.2 JET menu option
Current Time: Tue Jul 15 16:11:02 EDT 2025
Powered by FUDForum. Page generated in 0.08728 seconds
