Home » Modeling » TMF (Xtext) » Importing XML schema as metamodel?
Importing XML schema as metamodel? [message #61447] Mon, 20 July 2009 11:45 Go to next message
Originally posted by: ilyas.keser.gmail.com
Hi @all,
is it possible to import a XML Schema as metamodel and use its elements
in the Xtext grammar? The generated editor should be used to generate
XML files.
ILyas
Re: Importing XML schema as metamodel? [message #61471 is a reply to message #61447] Mon, 20 July 2009 11:53 Go to previous messageGo to next message
Hi Ilyas
It is possible and documented in the Xtext User Guide:
http://www.eclipse.org/Xtext/documentation/0_7_0/xtext.html# grammarImport
Regards, Helko
Re: Importing XML schema as metamodel? [message #61493 is a reply to message #61447] Mon, 20 July 2009 12:01 Go to previous messageGo to next message
Oh sorry. I had not seen that you meant XML Schema.
With XSD Ecore Converter (Plugin available at UpdateSite Galileo -
http://download.eclipse.org/releases/galileo) you can transform a XSD into
an appropriate Ecore and vice versa.
Regards Helko
Ilyas Keser wrote:
> Hi @all,
> XML files.
> ILyas
Re: Importing XML schema as metamodel? [message #61528 is a reply to message #61493] Mon, 20 July 2009 12:21 Go to previous message
Hi Helko,
I could convert my XSD file to an Ecore file.
Thanks for your help.
ILyas
> into an appropriate Ecore and vice versa.
> Regards Helko
> Ilyas Keser wrote:
>> Hi @all,
>> elements in the Xtext grammar? The generated editor should be used to
>> generate XML files.
>> Regards,
>> ILyas
Previous Topic:[Xtext] Matching Value for a locale Rule not allowed in other Rules?
Next Topic:[Xtext] Bidirectional properties handled incorrectly?
Current Time: Fri Jul 18 07:15:27 EDT 2025
Powered by FUDForum. Page generated in 0.08931 seconds
