Home » Eclipse Projects » Nebula » DateChooserCombo unit testing problem
DateChooserCombo unit testing problem [message #61441] Tue, 30 December 2008 10:40 Go to next message
The following code in DateChooserCombo breaks unit testing:
static {
buttonImage = new Image(Display.getCurrent(),
DateChooserCombo.class.getResourceAsStream(IMAGE));
I reset it in my TestCase.setUp() method by using reflection as a work
around. But in my opinion setImage(Image) should recreate the image if
image.getDevice().isDisposed() == true.
Is it a known/fixed issue or I should post a bug?
Jacek
Re: DateChooserCombo unit testing problem [message #61464 is a reply to message #61441] Tue, 30 December 2008 11:37 Go to previous message
Jacek Kolodziejczyk wrote:
> static {
I would file a bug against Nebula.
~ Chris
Re: DateChooserCombo unit testing problem [message #593071 is a reply to message #61441] Tue, 30 December 2008 11:37 Go to previous message
> static {
~ Chris
Previous Topic:DateChooserCombo unit testing problem
Next Topic:Nebula Grid + Glazed Lists
Current Time: Fri Jul 18 22:51:03 EDT 2025
Powered by FUDForum. Page generated in 0.03922 seconds
