Home » Archived » M2M (model-to-model transformation) » [ATL] getAppliedStereotypes returns emptyList
[ATL] getAppliedStereotypes returns emptyList [message #61439] Mon, 10 September 2007 08:37 Go to next message
Originally posted by: schwaban.web.de
I do have a problem with finding the applied stereotypes for an
UML!Element by calling self.getAppliedStereotypes() within an atl.file,
where self refers to an UML!Element. It always returns an empty list.
module Stundenplan; -- Module Template
create OUT : DotNetCFUsecaseProfile from IN : UML;
helper context UML!Element def : hasStereotypes() : Boolean =
not self.getAppliedStereotypes()->isEmpty();
rule ClassToTabPage {
from a : UML!Element ( if a.hasStereotypes() then true else false endif
to b : DotNetCFUsecaseProfile!systemWindowsFormsTabPage ()
My model is an UML 2.0 compliant export from MagicDraw 12.5 and looks
like the following small(!) extract.
Is there something wrong with this export format from MagicDraw?
What has to be considered in general to call methods like
getAppliedStereotypes() from an atl.file? Are their any preconditions in
configuring the ATL launch?
Thanks for all answers!
Andreas Schwab
<xmi:XMI xmi:version="2.1"
xmlns:xmi="http://schema.omg.org/spec/XMI/2.1"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:DotNetCFUsecaseProfile=" http:///schemas/DotNetCFUsecaseProfile/_mMvpMF1BEdyjeLfg7Wth KQ/0"
xmlns:MagicDrawProfile="http:///schemas/MagicDrawProfile/_mNCkIF1BEdyjeLfg7WthKQ/0"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
xmlns:uml="http://www.eclipse.org/uml2/2.0.0/UML"
xsi:schemaLocation=" http:///schemas/DotNetCFUsecaseProfile/_mMvpMF1BEdyjeLfg7Wth KQ/0
DotNetCFUsecaseProfile.profile.uml#_mk4h-11BEdyjeLfg7WthKQ
UML_Standard_Profile.MagicDraw_Profile.profile.uml#_mkurYl1B EdyjeLfg7WthKQ ">
<uml:Model xmi:id="eee_1045467100313_135436_1" name="Stundenplan">
<packageImport xmi:id="_0primitiveTypesStundenplan">
<importedPackage xmi:type="uml:Model"
href="pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#_0"/>
</packageImport>
<packageImport xmi:id="_0javaPrimitiveTypesStundenplan">
href="pathmap://UML_LIBRARIES/JavaPrimitiveTypes.library.uml#_0"/>
</packageImport>
<packagedElement xmi:type="uml:Class"
xmi:id="_12_5_1_26a50537_1188557378093_640652_266"
name="StundenplanOverview"
clientDependency="_12_5_1_26a50537_1188576498500_255468_350
_12_5_1_26a50537_1188765797468_535944_1465
_12_5_1_26a50537_1188559292593_408506_1458
_12_5_1_26a50537_1188766781171_566538_1745"/>
.... (some more packagedElements) ...
<profileApplication
xmi:id=" _12_5_1_22920507_1188474942281_730654_253profileApplicationS tundenplan ">
<eAnnotations xmi:id="_mlCPGF1BEdyjeLfg7WthKQ"
source="http://www.eclipse.org/uml2/2.0.0/UML">
<references xmi:type="ecore:EPackage"
href="DotNetCFUsecaseProfile.profile.uml#_mk4h-11BEdyjeLfg7WthKQ "/>
</eAnnotations>
<appliedProfile
href=" DotNetCFUsecaseProfile.profile.uml#_12_5_1_22920507_11884749 42281_730654_253 "/>
</profileApplication>
<profileApplication
xmi:id=" _be00301_1073394351331_445580_2profileApplicationStundenplan ">
<eAnnotations xmi:id="_mlCPHF1BEdyjeLfg7WthKQ"
href=" UML_Standard_Profile.MagicDraw_Profile.profile.uml#_mkurYl1B EdyjeLfg7WthKQ "/>
</eAnnotations>
<appliedProfile
href=" UML_Standard_Profile.MagicDraw_Profile.profile.uml#_be00301_ 1073394351331_445580_2 "/>
.... (some more profile applications that seem to be exported by default
and are of no relevance for this problem)...
</uml:Model>
<DotNetCFUsecaseProfile:systemWindowsFormsPanel
xmi:id="_p0TlwF1BEdyjeLfg7WthKQ"
base_Class="_12_5_1_26a50537_1188557378093_640652_266" bgColor="#DDDDDD"
title="Stundenplan"
base_Element="_12_5_1_26a50537_1188557378093_640652_266"/>
.... (some more applications of this Profile) ...
<MagicDrawProfile:auxiliaryResource xmi:id="_rQ11MF1BEdyjeLfg7WthKQ"
base_Package="magicdraw_uml_standard_profile_v_0001"/>
</xmi:XMI>
Re: [ATL] getAppliedStereotypes returns emptyList [message #61518 is a reply to message #61439] Mon, 10 September 2007 09:40 Go to previous messageGo to next message
Originally posted by: freddy.allilaire.univ-nantes.fr
Hello Andreas,
Does your input model contain the profile?
If your profile is defined in another UML model, you should add it in
the ATL header and the launch configuration. For example:
create OUT : DotNetCFUsecaseProfile from IN : UML, PRO : UML;
Freddy.
Andreas Schwab a écrit :
> Hello,
> Andreas Schwab
> </packageImport>
> </packageImport>
> <profileApplication
> </eAnnotations>
> <appliedProfile
> <profileApplication
> </eAnnotations>
> <appliedProfile
> </uml:Model>
> title="Stundenplan"
> </xmi:XMI>
Freddy Allilaire - ATLAS Group (INRIA & LINA)
http://www.sciences.univ-nantes.fr/lina/atl/contrib/allilair e
Re: [ATL] getAppliedStereotypes returns emptyList [message #61579 is a reply to message #61518] Mon, 10 September 2007 10:45 Go to previous message
Hello Freddy,
thanks a lot! That was indeed the solution. I included the profile.
Otherwise the references to the stereotype couldn't be resolved.
Cheers
Andreas
Freddy Allilaire schrieb:
> Hello Andreas,
> Freddy.
Previous Topic:Working with Dates
Next Topic:[ATL] ATL Port to Eclipse Linux
Current Time: Sun Jul 27 07:24:09 EDT 2025
Powered by FUDForum. Page generated in 0.03173 seconds
