Home » Eclipse Projects » Equinox » Problems with platform I20060210-1640
Problems with platform I20060210-1640 [message #61419] |
Sun, 12 February 2006 09:56  |
Hello!
I cross-post this on eclipse.platform.
I have problems running the last I-build.
Could you help me, please. I can't work anymore... :(
Thanks. Didier.
Here is what the configuration log says:
!SESSION 2006-02-12 15:47:07.015
eclipse.buildId=I20060208-0848
java.fullversion=GNU libgcj 4.0.3 20051204 (prerelease) (Debian 4.0.2-5j2)
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86 -clean
!ENTRY org.eclipse.osgi 4 0 2006-02-12 15:47:08.978
!MESSAGE Error installing bundle:
reference:file:../eclipse/plugins/org.eclipse.core.runtime.c ompatibility.registry_3.2.0.v20060210/
!STACK 0
org.osgi.framework.BundleException: Error converting plugin at
/usr/local/eclipse/plugins/org.eclipse.core.runtime.compatib ility.registry_3.2.0.v20060210.
org.eclipse.core.runtime.internal.adaptor.EclipseStorageHook .generateManifest(java.util.Dictionary)
(Unknown Source)
org.eclipse.core.runtime.internal.adaptor.EclipseStorageHook .getGeneratedManifest()
(Unknown Source)
org.eclipse.core.runtime.internal.adaptor.EclipseStorageHook .createCachedManifest(boolean)
(Unknown Source)
org.eclipse.core.runtime.internal.adaptor.EclipseStorageHook .getManifest(boolean)
(Unknown Source)
org.eclipse.osgi.internal.baseadaptor.BaseStorage.loadManife st(org.eclipse.osgi.baseadaptor.BaseData,
boolean) (Unknown Source)
at org.eclipse.osgi.internal.baseadaptor.BundleInstall.begin()
(Unknown Source)
org.eclipse.osgi.framework.internal.core.Framework.installWo rkerPrivileged(java.lang.String,
java.net.URLConnection, java.security.AccessControlContext) (Unknown Source)
at org.eclipse.osgi.framework.internal.core.Framework$2.run()
(Unknown Source)
java.security.AccessController.doPrivileged(java.security.Pr ivilegedExceptionAction)
(/usr/lib/libgcj.so.6.0.0)
org.eclipse.osgi.framework.internal.core.Framework.installWo rker(java.lang.String,
java.security.PrivilegedExceptionAction) (Unknown Source)
org.eclipse.osgi.framework.internal.core.Framework.installBu ndle(java.lang.String,
java.io.InputStream) (Unknown Source)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.i nstallBundle(java.lang.String,
org.eclipse.core.runtime.adaptor.EclipseStarter.installBundl es(org.eclipse.core.runtime.adaptor.EclipseStarter$InitialBu ndle[],
org.osgi.framework.Bundle[], java.util.ArrayList, java.util.List)
(Unknown Source)
org.eclipse.core.runtime.adaptor.EclipseStarter.loadBasicBun dles()
(Unknown Source)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(java .lang.String[],
java.lang.Runnable) (Unknown Source)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(java.lan g.String[],
at java.lang.reflect.Method.invoke(java.lang.Object,
java.lang.Object[]) (/usr/lib/libgcj.so.6.0.0)
org.eclipse.core.launcher.Main.invokeFramework(java.lang.Str ing[],
java.net.URL[]) (Unknown Source)
at org.eclipse.core.launcher.Main.basicRun(java.lang.String[])
(Unknown Source)
at org.eclipse.core.launcher.Main.run(java.lang.String[]) (Unknown
Source)
at org.eclipse.core.launcher.Main.main(java.lang.String[]) (Unknown
Source)
at gnu.java.lang.MainThread.call_main() (/usr/lib/libgcj.so.6.0.0)
at gnu.java.lang.MainThread.run() (/usr/lib/libgcj.so.6.0.0)
Caused by:
org.eclipse.osgi.service.pluginconversion.PluginConversionEx ception:
Could not find a plugin.xml or a fragment.xml in
org.eclipse.core.runtime.internal.adaptor.PluginConverterImp l.fillPluginInfo(java.io.File)
(Unknown Source)
org.eclipse.core.runtime.internal.adaptor.PluginConverterImp l.convertManifest(java.io.File,
boolean, java.lang.String, boolean, java.util.Dictionary) (Unknown Source)
(Unknown Source)
...22 more
Root exception:
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
Source)
Source)
!ENTRY org.eclipse.update.configurator 2006-02-12 15:47:11.295
!MESSAGE Plugin does not have a valid identifier:
plugins/org.eclipse.jdt.source_3.2.0.v20060207-0800-0ye-cyhm 1y/
!ENTRY org.eclipse.update.configurator 2006-02-12 15:47:11.296
!MESSAGE Plugin does not have a valid version:
!ENTRY org.eclipse.update.configurator 2006-02-12 15:47:11.305
plugins/org.eclipse.rcp.source.linux.gtk.x86_3.2.0.v20060116 -3Ie9HFhN5X/
!ENTRY org.eclipse.update.configurator 2006-02-12 15:47:11.628
plugins/org.eclipse.team.cvs.ssh2_3.2.0.I20051219/
Re: Problems with platform I20060210-1640 [message #61492 is a reply to message #61419] |
Wed, 15 February 2006 00:59  |
Just to tell, i resolved my problem!
Thanks anyway. Didier
Ptitjes wrote:
> Hello!
> Thanks. Didier.
> !STACK 0
> at
> (Unknown Source)
> at
> (Unknown Source)
> at
> (Unknown Source)
> at
> (Unknown Source)
> at
> (Unknown Source)
> at
> Source)
> (Unknown Source)
> at
> at
> at
> at
> at
> (Unknown Source)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.loadBasicBun dles()
> (Unknown Source)
> at
> at
> at org.eclipse.core.launcher.Main.invokeFramework(java.lang.Str ing[],
> (Unknown Source)
> Source)
> Source)
> Caused by:
> at
> (Unknown Source)
> at
> at
> (Unknown Source)
> ...22 more
> Root exception:
> at
> (Unknown Source)
> at
> at
> (Unknown Source)
> at
> (Unknown Source)
> at
> (Unknown Source)
> at
> (Unknown Source)
> at
> (Unknown Source)
> at
> Source)
> (Unknown Source)
> at
> at
> at
> at
> at
> (Unknown Source)
> (Unknown Source)
> at
> at
> (Unknown Source)
> Source)
> Source)
Current Time: Sun Jun 08 00:39:07 EDT 2025
Powered by FUDForum. Page generated in 0.05047 seconds
