null pointer exception in VE while selecting a widget [message #607095] |
Sun, 10 April 2005 17:48 |
Originally posted by: devmike.netcabo.pt
Hi. I'm getting a null pointer exception in VE when selecting a widget
while having the Customize Layout Window open. I can't provide a
pattern, it just happens sometimes. The only thing that seems to solve
it is restarting Eclipse.
I'm using Eclipse 3.0.1, VE 1.0.2.1, EMF 2.0.2, GEF 3.0.1 and XSD 2.0.2
I don't know if someone wants to check this out, but the error log goes
like this:
!ENTRY org.eclipse.ui 4 4 Apr 10, 2005 22:29:50.75
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 Apr 10, 2005 22:29:50.95
!MESSAGE java.lang.NullPointerException
!STACK 0
org.eclipse.gef.tools.ToolUtilities.getSelectionWithoutDepen dants(ToolUtilities.java:35)
org.eclipse.gef.tools.DragEditPartsTracker.createOperationSe t(DragEditPartsTracker.java:166)
org.eclipse.gef.tools.AbstractTool.getOperationSet(AbstractT ool.java:586)
org.eclipse.gef.tools.DragEditPartsTracker.captureSourceDime nsions(DragEditPartsTracker.java:124)
org.eclipse.gef.tools.DragEditPartsTracker.setState(DragEdit PartsTracker.java:542)
org.eclipse.gef.tools.AbstractTool.stateTransition(AbstractT ool.java:1257)
org.eclipse.gef.tools.SelectEditPartTracker.handleButtonDown (SelectEditPartTracker.java:97)
at org.eclipse.gef.tools.AbstractTool.mouseDown(AbstractTool.ja va:977)
at org.eclipse.gef.tools.SelectionTool.mouseDown(SelectionTool. java:490)
at org.eclipse.gef.EditDomain.mouseDown(EditDomain.java:201)
org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchMouse Pressed(DomainEventDispatcher.java:327)
org.eclipse.draw2d.LightweightSystem$EventHandler.mouseDown( LightweightSystem.java:503)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:132)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2772)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2431)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
FUDForum. Page generated in 0.03479 seconds
