Home » Archived » M2M (model-to-model transformation) » Working with Dates
Working with Dates [message #61315] Sun, 09 September 2007 21:05 Go to next message
Originally posted by: jconlon.apache.org
I'm a ATL newbee still trying to come up to speed. Having problems with
models that contain java.util.Date attributes.
To simplify and reproduce the problem, I modified the Author2Person
examples to include an Author birthDate attribute and a Person birthday
attribute. (By Adding each attribute as a EDate EType in the
Author.ecore and Person.ecore metamodels.)
After those metamodel changes I was able to use the Sample ECore Model
Editor to edit the authors.ecore model and add the values to the
birthDate attributes.
My authors.ecore model now looks like this...
<?xml version="1.0" encoding="ISO-8859-1"?>
<xmi:XMI xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns="Author">
<Author name="David" surname="Touzet"
birthDate="2000-11-11T00:00:00.000-0600"/>
<Author name="Freddy" surname="Allilaire"
birthDate="2001-08-22T01:00:00.000-0500"/>
</xmi:XMI>
Here is my modified Author2Person.atl ...
module Author2Person; -- Module Template
create OUT : Person from IN : Author;
rule Author {
from
a: Author!Author
to
p: Person!Person (
name <- a.name,
surname <- a.surname,
birthday <- a.birthDate
When I run the atl I get the following console errors:
SEVERE: ****** BEGIN Stack Trace
SEVERE: message: ERROR: cannot convert Sat Nov 11 00:00:00 CST 2000 :
class java.util.Date from EMF.
SEVERE: A.main() : ??#24 null
SEVERE: local variables = {self=Author2Person : ASMModule}
SEVERE: local stack = []
SEVERE: A.__exec__() : ??#8 null
SEVERE: local variables = {self=Author2Person : ASMModule,
e=TransientLink {rule = 'Author', sourceElements = {a = IN!David},
targetElements = {p = OUT!David}, variables = {}}}
SEVERE: A.__applyAuthor(1 : NTransientLink;) : ??#24 12:20-12:31
SEVERE: local variables = {p=OUT!David, a=IN!David, self=Author2Person
: ASMModule, link=TransientLink {rule = 'Author', sourceElements = {a =
IN!David}, targetElements = {p = OUT!David}, variables = {}}}
SEVERE: local stack = [OUT!David, OUT!David, Author2Person : ASMModule]
SEVERE: ****** END Stack Trace
INFO: Execution terminated due to error (see launch configuration to
allow continuation after errors).
SEVERE: ERROR: cannot convert Sat Nov 11 00:00:00 CST 2000 : class
java.lang.RuntimeException: ERROR: cannot convert Sat Nov 11 00:00:00
CST 2000 : class java.util.Date from EMF.
org.eclipse.m2m.atl.engine.vm.SimpleDebugger.error(SimpleDeb ugger.java:185)
org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:85)
org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:81)
org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModelElement.emf2A SM(ASMEMFModelElement.java:186)
org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModelElement.get(A SMEMFModelElement.java:134)
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:288)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.exec(ASMOperation .java:161)
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:133)
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:91)
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:230)
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:325)
org.eclipse.m2m.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:289)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:155)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:105)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:81)
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:351)
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:453)
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.launch(AtlReg ularVM.java:425)
org.eclipse.m2m.atl.adt.launching.AtlLaunchConfigurationDele gate.launch(AtlLaunchConfigurationDelegate.java:35)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:766)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:608)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:899)
org.eclipse.debug.internal.ui.DebugUIPlugin$7.run(DebugUIPlu gin.java:1102)
Any one have any ideas as to what I am doing wrong and/or what is the
proper approach when working with Date dataTypes.
thanks for any help?
John Conlon
[ATL] Re: Working with Dates [message #61367 is a reply to message #61315] Mon, 10 September 2007 04:11 Go to previous messageGo to next message
Originally posted by: mikael.barbero.gmail.com
Hi John,
First, could you please try to stick with this newsgroup rules and
prefix all of your messages about ATL with an [ATL] prefix. The reason
is explained there http://wiki.eclipse.org/M2M. Thanks in advance.
Concerning your question, the fact is that ATL does not support Date
primitive type (or any other "Java" primitive types wrapped by EMF other
than the ones detailed there
http://wiki.eclipse.org/ATL_Standard_Library#Primitive_Types).
Your next question would be why? The answer is that ATL has been
developed as a model handler (like EMF) agnostic model transformation
language and as a superset of OCL. Then, being able to use some
implementation specific primitive types would break those foundations.
I suggest you to use String for your date, or to define a meta class
Date in your metamodel.
Hope this helps.
Mikael
John E. Conlon wrote:
> </xmi:XMI>
> rule Author {
> from
> a: Author!Author
> to
> p: Person!Person (
> name <- a.name,
> self=Author2Person : ASMModule, link=TransientLink {rule = 'Author',
> sourceElements = {a = IN!David}, targetElements = {p = OUT!David},
> variables = {}}}
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> John Conlon
Mikaël Barbero - PhD Candidate
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssinière
44322 Nantes Cedex 3 - France
tel. +33 2 51 12 58 08 /\ cell.+33 6 07 63 19 00
email: Mikael.Barbero@{gmail.com, univ-nantes.fr}
http://www.sciences.univ-nantes.fr/lina/atl/
Re: [ATL] Re: Working with Dates [message #61392 is a reply to message #61367] Mon, 10 September 2007 04:24 Go to previous messageGo to next message
To complete my previous post. You could also develop your own model
handler implementation that support these primitive types. It may be
valid if one of your metamodel is defined by a third party, but try to
avoid it in other cases (especially just for a Date ;)), because it can
be costly.
Mikael
Mikaël Barbero wrote:
> Hi John,
> Hope this helps.
> Mikael
>> with models that contain java.util.Date attributes.
>> birthday attribute. (By Adding each attribute as a EDate EType in the
>> </xmi:XMI>
>> rule Author {
>> from
>> a: Author!Author
>> to
>> p: Person!Person (
>> name <- a.name,
>> variables = {}}}
>> ASMModule]
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> John Conlon
Re: [ATL] Re: Working with Dates [message #61465 is a reply to message #61392] Mon, 10 September 2007 09:04 Go to previous message
Hi Mikaël,
Thank you for your fast response. See my a replies inline...
> be costly.
> Mikael
>> Hi John,
Sorry - will do this next time.
>> other than the ones detailed there
Yes, that is a good reason.
I'll try one of your two suggestions.
thanks again for the support,
John Conlon
>> Hope this helps.
>> Regards,
>> Mikael
>>> Hi,
>>> the Author.ecore and Person.ecore metamodels.)
>>> Model Editor to edit the authors.ecore model and add the values to
>>> the birthDate attributes.
>>> </xmi:XMI>
>>> rule Author {
>>> from
>>> a: Author!Author
>>> to
>>> p: Person!Person (
>>> name <- a.name,
>>> variables = {}}}
>>> ASMModule]
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> John Conlon
Previous Topic:[ATL] UML2WSDL.
Next Topic:[ATL] getAppliedStereotypes returns emptyList
Current Time: Fri Jul 18 12:06:31 EDT 2025
Powered by FUDForum. Page generated in 0.06034 seconds
