- getMapMode() has private in WrapLabel??? [message #61311] |
Thu, 12 October 2006 05:44  |
Originally posted by: nikolay.diakov.fredhopper.com
I generated a diagram editor with GMF 1.0.1 using IMapNode (checked).
In the resulting diagram editor source code I get a compiel error about
the visibility of getMapMode(). Is this a bug or a feature?
--Nikolay
Re: - getMapMode() has private in WrapLabel??? [message #61678 is a reply to message #61655] |
Thu, 12 October 2006 09:50  |
Artem Tikhomirov wrote:
> No, the reason is obvious. the private getMapMode was added in 1.0.1
> milestone without checking generated code. In 1.0.0, there was no such
> method and, getMapMode was taken from enclosing EditPart.
> Btw, what's the purpose of such a border for a label?
Absolutely no purpose, just playing around when I found this. I find
usefull setting the border of the label to some thickness > 1. Thanks, I
now know where to get the map mode from.
--N
> Artem
> "Nikolay Diakov" <nikolay.diakov@fredhopper.com> wrote in message
> news:eglggl$pls$1@utils.eclipse.org...
>>> Well, this is definitely a bug introduced in the maintenance stream.
>>> However, there should be no need for map mode in the generated label's
>>> code. Could you please post either generated code or respective part of
>>> .gmfgraph - I wonder why there's access to map mode at all.
>>> Artem
>>> news:egl2pc$66a$1@utils.eclipse.org...
>>>> --Nikolay
>> Well, in my graph model I have a Label on which I set Line Border with
>> thickness 0. (When I do not do the line border the generated code compiles
>> OK).
>> This produces the following code
>> public class ChannelLabelFigureTemplate extends
>> org.eclipse.gmf.runtime.draw2d.ui.figures.WrapLabel {
>> * @generated
>> public ChannelLabelFigureTemplate() {
>> this.setText("...");
>> this.setBorder(new org.eclipse.draw2d.LineBorder(getMapMode()
>> .DPtoLP(0)));
>> createContents();
>> * @generated
>> private void createContents() {
>> * @generated
>> private boolean myUseLocalCoordinates = false;
>> * @generated
>> protected boolean useLocalCoordinates() {
>> return myUseLocalCoordinates;
>> * @generated
>> protected void setUseLocalCoordinates(boolean useLocalCoordinates) {
>> myUseLocalCoordinates = useLocalCoordinates;
>> One can see the call to getMapMode(). I guess the visibility should
>> actually be "protected" instead of "private" as someone may have
>> hierarcical modifiers of labels in their graph model.
>> Tell me if you want my graph model file too.
>> Cheers,
>> Nikolay
FUDForum. Page generated in 0.03864 seconds
