Home » Eclipse Projects » GEF » GDI+. Logic example with antialiasing (big)
GDI+. Logic example with antialiasing (big) [message #61310] Mon, 03 February 2003 03:57 Go to next message
Originally posted by: kosta.empproject.com
To use antialiasing in Draw2D copy directory "plugins"
from archive in your Eclipse installation. Plus you will
need to set USE_GDI+ jvm property in "true". For example
you can start eclipse using following line:
eclipse.exe -vmargs -DUSE_GDI+=true
You should have DLL gdiplus.dll (GDI+ support) in PATH,
for example in System32.
In directory examples there are two pictures:
1. example.jpg - simple example of using GDI+ wrapper with SWT.
2. logic.jpg - how logic example looks with antialiasing.
Please notice, that this is only preliminary version, developed
only for Draw2D antialiasing. If you think, that some features needed,
you can freely ask for them.
section 1 of uuencode 5.25 of file gdiplus.zip by R.E.M.
sum -r/size 9590/366630 section (from "begin" to "end")
sum -r/size 14041/266082 entire input file
  • Attachment: gdiplus.zip
    (Size: 259.85KB, Downloaded 136 times)
Re: GDI+. Logic example with antialiasing (big) [message #61435 is a reply to message #61310] Mon, 03 February 2003 10:00 Go to previous messageGo to next message
Originally posted by: g.wagenknecht.intershop.de
"Konstantin Scheglov" <kosta@empproject.com> schrieb im Newsbeitrag
news:b1lasg$ce3$1@rogue.oti.com...
Great Job! Thanks very much for your efforts. I will try it ASAP.
Cu, Gunnar
Re: GDI+. Logic example with antialiasing (big) [message #64923 is a reply to message #61310] Tue, 04 February 2003 06:32 Go to previous messageGo to next message
This looks very promising...
But I object to the name GDIPlusGraphics because on other plattforms (like
QNX/Photon or Linux/GTK) one could implement the same and this wouldn't be
GDI+, of course...
Joern
Re: GDI+. Logic example with antialiasing (big) [message #65203 is a reply to message #64923] Mon, 17 February 2003 15:33 Go to previous messageGo to next message
You mean name in preferences? Any suggestions?
By the way, all code (including native source and compiled dll) avaliable
from cvs (empproject.com, pserver, anonymous):
com.empproject.draw2d.gdiplus
gdiplus
All code CPLed.
"J
Re: GDI+. Logic example with antialiasing (big) [message #65223 is a reply to message #65203] Mon, 17 February 2003 17:37 Go to previous messageGo to next message
BTW, any code you post to the newsgroup is also CPL once you post it.
"Alex Selkov" <as@empproject.com> wrote in message
news:b2rfbc$fr2$1@rogue.oti.com...
> gdiplus
> All code CPLed.
> "J
Re: GDI+. Logic example with antialiasing (big) [message #109897 is a reply to message #61310] Tue, 23 December 2003 06:34 Go to previous messageGo to next message
Originally posted by: brian.fernandes.codito.com
I followed these instructions exactly; but I didn't manage to get the
antialiasing working.
I do have gdiplus.dll in my system path, I'm using Windows 2000 and I used
the suggested command line.
I tried this out with eclipse 2.1.1, 2.1.2 and 3M2.
I used the zip file that was posted, I did not use the CVS version (has any
work been done on this since then ?)
I would really really love to see my GEF plugin anti-aliased; we have a non
GEF version (using Win32 API) which my plugin has replaced; but the dated
application still looks much better because it antialiases the figures.
Any ideas ?
Brian.
Re: GDI+. Logic example with antialiasing (big) [message #109976 is a reply to message #109897] Tue, 23 December 2003 21:43 Go to previous message
Please add your comments and requirements to the SWT bugzilla I mentioned on
a recent post about this subject. (Search for "rendering hints" in
bugzilla)
"Brian Fernandes" <brian.fernandes@codito.com> wrote in message
news:bs98bb$i3a$1@eclipse.org...
any
non
> Any ideas ?
> Brian.
Previous Topic:Anti-alaising
Next Topic:editable figure
Current Time: Thu Jul 24 04:55:25 EDT 2025
Powered by FUDForum. Page generated in 0.87235 seconds
