Home » Newcomers » Newcomers » Build Problem
Build Problem [message #61308] Fri, 06 May 2005 19:51 Go to next message
Originally posted by: viet.pham.sun.com
Hi All,
I am compiling eclipse for SPARC following exactly the instruction at:
http://www.eclipse.org/downloads/index.php
and using the following command:
$ build -os solaris -ws motif -arch sparc
Here is the error I got:
build: ANT_OPTS=-Xmx1000M: is not an identifier
Google "build: ANT_OPTS=-Xmx1000M: is not an identifier" does not return
even one link. Any help is greatly appreciated.
If this is not the right mailing list, please forward to the right one
or tell me which mailing list I should register for this kind of question.
Thanks.
Re: Build Problem [message #61333 is a reply to message #61308] Fri, 06 May 2005 19:58 Go to previous message
I forgot to tell you that I was building it on Solaris 10 SPARC, which has
JDK 1.5. Thanks.
Previous Topic:Which newsgroup?
Next Topic:example plugin
Current Time: Mon Jul 21 22:18:34 EDT 2025
Powered by FUDForum. Page generated in 0.09920 seconds
