Home » Archived » Test and Performance Tools Platform (TPTP) » GUI recorder - wait until job completed
GUI recorder - wait until job completed [message #61263] |
Tue, 28 March 2006 11:32  |
Originally posted by: vladimir.au.ru
- I've tried to use GUI recorder for my test scenario, but I can't find
the way how to wait until particular job completed. For instance, during
long-run operation
" org.eclipse.ui.internal.progress.ProgressMonitorFocusJobDial og " appears
and I need to wait while when the job completed and dialog closed. I've
tried to use <command type="wait"/> but test failed with the following
exception:
A time-out occurred while waiting for the nested shell
org.eclipse.ui.internal.progress.ProgressMonitorFocusJobDial og to
complete. It is likely caused by the absence of the shell.
- I want to execute my test cases in the loop and measure time of
execution for every (or particular) step. Is it possible with TPTP?
Thanks in advance,
Vladimir.
Re: GUI recorder - wait until job completed [message #61429 is a reply to message #61378] |
Tue, 28 March 2006 12:18   |
Ali, thanks for the answer.
Ali Mehregani wrote:
> Vladimir,
> There is a time-out threshold under the behavior page that you can adjust.
> The default time-out period is 30 seconds.
> You can also define wait commands based on a wait period.
> e.g. <command type="wait" time-to-wait="5000"/> will cause a 5 second delay.
> Alternatively, <command type="wait"/> will cause a wait until all user
> Eclipse jobs are complete.
I've tried again, and TPTP not waited until job completed. I use TPTP
version 4.1.0 with eclipse 3.1.2.
Here is parts from my test script (I try to import data from CVS to
existing project):
<macro version="0.1" >
<shell id="org.eclipse.ui.internal.WorkbenchWindow" return-code="-1">
<command type="focus"
contextId="view/org.eclipse.jdt.ui.PackageExplorer"
widgetId="org.eclipse.swt.widgets.Composite#1"/>
<command type="select"
contextId=" popup/view/org.eclipse.jdt.ui.PackageExplorer/org.eclipse.sw t.widgets.Tree#{{/}}-{{1.0}} "
widgetId="contribid/import13"/>
<shell id="org.eclipse.jface.wizard.WizardDialog" return-code="0">
<command type="item-select"
contextId="wizard-page/singleWizardSelectionPage"
widgetId="org.eclipse.swt.widgets.Table#1">
<item
path=" org.eclipse.swt.widgets.TableItem#{{org.eclipse.team.cvs.ui. newProjectCheckout}}-{{1.0}} "/>
</command>
widgetId="org.eclipse.swt.widgets.Table#1"/>
<command type="select" contextId="wizard"
widgetId="org.eclipse.swt.widgets.Button#{{15}}-{{1.0}}"/>
<!--set all checkout option and finally press Finish button -->
<!--.........now press Finish -->
widgetId="org.eclipse.swt.widgets.Button#{{16}}-{{1.0}}"/>
</shell>
<!-- additional wait -->
</shell>
</macro>
I insert additional wait in the end of script but it doesnt help. Is it a
known limitation?
> You can't do profiling with AGR but if you look at the execution history
> file, a start and stop event is reported for each invocation. That's the
> only time-stamp information that is reported.
Thanks, I've seen it. I just think that there is another way for it.
Vladimir
> "Vladimir" <vladimir@au.ru> wrote in message
> news:995ad7af3aa6fb2718cee2397aeda17e$1@www.eclipse.org...
>> long-run operation
>> exception:
>> Thanks in advance,
>> Vladimir.
Re: GUI recorder - wait until job completed [message #62295 is a reply to message #61429] |
Wed, 29 March 2006 12:16   |
Did you use <command type="wait"/> or <command type="wait"
time-to-wait="..."/>?
If you used <command type="wait"/>, then keep in mind that the time-out
threshold set under the behavior page will only apply in a standard launch
(not quick mode).
If you used a time-dependent wait command, then simply try to increase the
time-to-wait value.
news:a2fd08c833cb23b37ad2da29c6dd9faf$1@www.eclipse.org...
> > Vladimir,
adjust.
delay.
> existing project):
gets.Tree#{{/}}-{{1.0}}"
> <item
Checkout}}-{{1.0}}"/>
> </command>
> </shell>
> </shell>
> </macro>
> known limitation?
the
> Vladimir
during
> >> long-run operation
appears
> >> exception:
> >> Thanks in advance,
> >> Vladimir.
Re: GUI recorder - wait until job completed [message #66117 is a reply to message #65582] |
Wed, 12 April 2006 07:42   |
> Yes, wait commands should wait until the CVS job completes, but wait command
> (just like any other commands) will time-out if the time-out threshold is
> reached.
Hi Ali,
Unfortunately wait is not working for me. I used eclipse 3.1.2 with TPTP
4.1.0. For my particular step (import from cvs) I set timeout threshold
for each command to 90000 seconds. It should be enough for cvs checkout,
but after several seconds of checkout script continue execution of the
next steps. What do you think about it?
Here is parts from my macro script:
Here I set options in CVS Checkout wizard and press finish button in the
wizard
</shell>
<!--I suggest this command should wait until checkout completed -->
</shell>
</macro>
Vladimir.
> news:79b603a6822fb0ecb27762353e221344$1@www.eclipse.org...
>> At the moment I use the following workaround: loop of wait commands.
> launch
>> > (not quick mode).
> the
>> > time-to-wait value.
>> But why wait command do not works properly? Am I correctly understand that
>> wait command should wait until all eclipse job completed, i.e. while cvs
>> chechout will completed.
>> Thanks,
>> Vladimir.
Re: GUI recorder - wait until job completed [message #66389 is a reply to message #66117] |
Thu, 13 April 2006 15:12  |
It can be because the CVS job is not being registered as a type of job that
the wait command looks for. You can open a defect if you like me to look
into the problem in more details.
news:25b4790a00355eb481f58bc1d1a5856d$1@www.eclipse.org...
command
is
> > reached.
> Hi Ali,
> wizard
> </shell>
> </shell>
> </macro>
> Vladimir.
time-out
> > launch
> >> > (not quick mode).
increase
> > the
> >> > time-to-wait value.
that
cvs
> >> Thanks,
> >> Vladimir.
Current Time: Mon Jul 14 12:55:37 EDT 2025
Powered by FUDForum. Page generated in 1.11995 seconds
