Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » How to declare type of empty collection in OCL?
How to declare type of empty collection in OCL? [message #61231] Tue, 14 November 2006 05:25 Go to next message
How can I declare that for example a Set contains objects of some type
and then initialize it to be empty. Neither I or II below works, but III
does.
(I) Not OK
let a:Set(Integer)=Set{} in a
'Init expression type does not conform to type of variable (a).'
(II) Not OK
let a:Set(Integer)=Set(Integer){} in a
'1:20:1:31 "collectionTypeIdentifierCS" expected instead of "Set(Integer)"'
(III) OK
let a:Set(Integer)=Set{1,3,2} in a
2
1
3
Tord
Re: How to declare type of empty collection in OCL? [message #61256 is a reply to message #61231] Tue, 14 November 2006 06:21 Go to previous messageGo to next message
Tord,
I'll forward your question to the new OCL newsgroup.
> III does.
> (I) Not OK
> (II) Not OK
> "Set(Integer)"'
> (III) OK
> 2
> 1
> 3
> Regards
> Tord
Re: How to declare type of empty collection in OCL? [message #61376 is a reply to message #61256] Tue, 14 November 2006 09:12 Go to previous messageGo to next message
Hi, Tord,
The element type of a collection literal is inferred from its contents (as
the common supertype of its elements, which may be OclAny or
Collection(OclAny) in mixed cases). The inferred element type of an empty
collection literal is OclVoid, which conforms to all other types, so your
expression (I) should work.
This is a bug. Would you mind raising it? (on the MDT UML2 OCL component):
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=MDT& version=1.0.1&component=UML2%20OCL&bug_severity=norm al&form_name=enter_bug
Christian
Ed Merks wrote:
> Tord,
>> III does.
>> (I) Not OK
>> (II) Not OK
>> "Set(Integer)"'
>> (III) OK
>> 2
>> 1
>> 3
>> Regards
>> Tord
Re: How to declare type of empty collection in OCL? [message #61449 is a reply to message #61376] Wed, 15 November 2006 07:11 Go to previous message
Bug report at https://bugs.eclipse.org/bugs/show_bug.cgi?id=164614
Tord
Christian W. Damus wrote:
> Hi, Tord,
> Christian
> Ed Merks wrote:
>> Tord,
>>> III does.
>>> (I) Not OK
>>> (II) Not OK
>>> "Set(Integer)"'
>>> (III) OK
>>> 2
>>> 1
>>> 3
>>> Regards
>>> Tord
Re: How to declare type of empty collection in OCL? [message #595597 is a reply to message #61231] Tue, 14 November 2006 06:21 Go to previous message
Tord,
> III does.
> (I) Not OK
> (II) Not OK
> "Set(Integer)"'
> (III) OK
> 2
> 1
> 3
> Regards
> Tord
Re: How to declare type of empty collection in OCL? [message #595643 is a reply to message #61256] Tue, 14 November 2006 09:12 Go to previous message
Hi, Tord,
Christian
Ed Merks wrote:
> Tord,
>> III does.
>> (I) Not OK
>> (II) Not OK
>> "Set(Integer)"'
>> (III) OK
>> 2
>> 1
>> 3
>> Regards
>> Tord
Re: How to declare type of empty collection in OCL? [message #595666 is a reply to message #61376] Wed, 15 November 2006 07:11 Go to previous message
Tord
> Hi, Tord,
> Christian
> Ed Merks wrote:
>> Tord,
>>> III does.
>>> (I) Not OK
>>> (II) Not OK
>>> "Set(Integer)"'
>>> (III) OK
>>> 2
>>> 1
>>> 3
>>> Regards
>>> Tord
Previous Topic:Performance Problem with Teneo 200610261350 / Jpox 1.1.3
Next Topic:Validation action failed due to attribute type is 'long'
Current Time: Tue Jul 15 12:00:01 EDT 2025
Powered by FUDForum. Page generated in 0.04045 seconds
