Home » Language IDEs » ServerTools (WTP) » jsp editor and tag libraries
jsp editor and tag libraries [message #61224] Wed, 05 January 2005 09:00 Go to next message
Originally posted by: jesion_list.DROPIT.gazeta.pl
hi,
is there support for tag libraries (and code assist for new tags) in m2?
it seems it doesn't work at all. in ibm contribution there was the
hack known to make it work (c:/web-inf/tag - at least for windows
version)...
wojtek
Re: jsp editor and tag libraries [message #61908 is a reply to message #61224] Thu, 06 January 2005 01:21 Go to previous messageGo to next message
Hacks should not be need with M2. Short of JSP 2.0 tagdirs, it
should just work according to the specification. Do you have a case
that doesn't work?
- Nitin
Re: jsp editor and tag libraries [message #61951 is a reply to message #61908] Thu, 06 January 2005 02:20 Go to previous messageGo to next message
Nitin Dahyabhai schrieb:
> Hacks should not be need with M2. Short of JSP 2.0 tagdirs, it should
> just work according to the specification. Do you have a case that
> doesn't work?
How do I set this up?
I have the following JSP:
main.jsp -> includes /WEB-INF/jsp/includes/environment.jsp
environment.jsp -> includes /WEB-INF/jsp/includes/taglibs.jsp
taglibs.jsp -> defines taglib prefix="debug"
tagdir="/WEB-INF/tags/debug"
- Content assist doesn't work for tags defined in /WEB-INF/tags/debug
- Content assist also doesn't work for taglibs defined in jars
BTW, I can't edit ".tag" files with M2.
Cu, Gunnar
Re: jsp editor and taglibraries [message #61995 is a reply to message #61951] Thu, 06 January 2005 03:00 Go to previous messageGo to next message
Ah, there it is. Tagdirs did not work inside of the JSP editor in
any previous code revision nor do they work in M2. They should be
functional in M3.
JARs should already work without any special setup. Where are the
..jars and .jsps located and how are you referencing them in your
taglib directive?
- Nitin
Re: jsp editor and taglibraries [message #62042 is a reply to message #61995] Thu, 06 January 2005 05:40 Go to previous messageGo to next message
> functional in M3.
Ah, thanks.
> JARs should already work without any special setup. Where are the .jars
> and .jsps located and how are you referencing them in your taglib
> directive?
Jars are located in WEB-INF/lib (eg. jstl.jar) and automatically added
to the classpath by a builder.
They are referenced like the tagdirs in taglibs.jsp (which is included
by environment.jsp which is included in the main jsp file) with their URI:
<%@ taglib prefix="c" uri="http://java.sun.com/jsp/jstl/core" %>
The jsps are in the webapp root or in a subdirectory (eg. WEB-INF/jsp...)
Cu, Gunnar
Re: jsp editor and taglibraries [message #62301 is a reply to message #62042] Thu, 06 January 2005 11:41 Go to previous messageGo to next message
Ah, and that seems to be broken in M2. When the problems locating
taglibs in the IBM Initial Contribution were fixed for M2, content
model support for taglib directives in included files didn't get
updated. I've opened bug 82333 for this.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=82333
- Nitin
Re: jsp editor and taglibraries [message #62649 is a reply to message #62301] Fri, 07 January 2005 02:12 Go to previous message
> taglibs in the IBM Initial Contribution were fixed for M2, content model
> support for taglib directives in included files didn't get updated.
Thanks!
Cu, Gunnar
Previous Topic:A new try...
Next Topic:Configuration of Tomcat within Eclispe IDE
Current Time: Sun Jul 27 07:14:48 EDT 2025
Powered by FUDForum. Page generated in 0.03284 seconds
