[Teneo]Feature request to support the @Entity annotation [message #605213] |
Thu, 03 May 2007 21:14 |
Michael Kanaley Messages: 89 Registered: July 2009 |
Member |
Below is an exception encountered when I add the following annotation to an
EClass.
@Entity(name="SomeOtherNameForClass")
Perhaps Teneo could provide a EClassNameStrategy that supports this
annotation?
Is there a way to get the annotations given an EClass? - it might be easy to
augment the default EClassNameStrategy.
Using the QUALIFY_ENTITY_NAME=nsprefix is not ideal since it applies to all
models. If an application has already shipped a version and a new model is
added that tries to reuse a name then backward compatibility is broken when
this flag is set.
Attached is a test suite.
Thanks for considering this.
-mike
java.lang.IllegalArgumentException: No EClass found using
org.eclipse.emf.teneo.ecore.DefaultEClassNameStrategy.toECla ss(DefaultEClassNameStrategy.java:78)
org.eclipse.emf.teneo.hibernate.HbDataStore.setRefersToOfSup ers(HbDataStore.java:815)
org.eclipse.emf.teneo.hibernate.HbDataStore.computeReferers( HbDataStore.java:803)
org.eclipse.emf.teneo.hibernate.HbDataStore.initialize(HbDat aStore.java:163)
at test.teneo.EntitynameTests.createHbDataStore(EntitynameTests .java:71)
at test.teneo.EntitynameTests.testSaving(EntitynameTests.java:8 5)
at junit.framework.TestCase.runTest(TestCase.java:154)
at junit.framework.TestCase.runBare(TestCase.java:127)
at junit.framework.TestResult$1.protect(TestResult.java:106)
at junit.framework.TestResult.runProtected(TestResult.java:124)
at junit.framework.TestResult.run(TestResult.java:109)
at junit.framework.TestCase.run(TestCase.java:118)
at junit.framework.TestSuite.runTest(TestSuite.java:208)
at junit.framework.TestSuite.run(TestSuite.java:203)
org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestRefer ence.run(JUnit3TestReference.java:128)
org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:460)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main( RemoteTestRunner.java:196)
FUDForum. Page generated in 0.01981 seconds
