Home » Eclipse Projects » Plugin Development Environment (PDE) » [target] Using a target platform definition to create an installation?
Re: [target] Using a target platform definition to create an installation? [message #65871 is a reply to message #61302] |
Fri, 26 June 2009 20:36   |
Originally posted by: jconlon.apache.org
In Ganymede I used PDE Build pointing to a Target Platform that also
included the delta pack.
baseLocation=/opt/Eclipse/tracker-eclipse_target_platform-20 0905071512/eclipse
Now in Galileo taking advantage of all the latest cool features of
target definintion files, I have initially configured a file with two
software sites, a directory with misc bundles, and a
directory with the delta pack.
Using this target the IDE can
export my product for multiple platforms (all with p2 enabled) and
create a p2 repo as well. Great - Thanks PDE team!
But from Chris's comments in this thread, to use PDE Build it looks like
I will need to go back to a physical disk based Target Platform, similar
to the one I used on Ganymede (with an eclipse configuration overlayed
with the delta pack and spiced up with any other plugins and features I
need for my app. Referenced with the baseLocaton property in the
build.properties file.
Is that correct, or are there any alternatives?
thanks for any help,
John
Chris Aniszczyk wrote:
> Eric Jain wrote:
>> Where does a target platform definition download it's bundles (those
>> listed in software sites) to? Would be useful if there was an option
>> to dump them in a specific location/installation, especially since the
>> target platform definitions can't be used in headless builds
>> [https://bugs.eclipse.org/bugs/show_bug.cgi?id=266311]...
> Why would this be useful :)?
> If your target definition is based off of 'Software Sites' and point to
> a p2 repo and IU, you can replicate this in your build.
> As of Eclipse 3.5M5, PDE Build supports fetching artifacts from p2 repos:
> http://download.eclipse.org/eclipse/downloads/drops/S-3.5M5- 200902021535/eclipse-news-M5.html#PDE
> If you listed the same IUs in your target definition and in your PDE
> Build map file... you should get the same things. In theory at least ;)
> On a side note, the reason target definitions can't be used headlessly
> yet because you can create target definitions that aren't really meant
> to be used in a headless build (ie., pointing to some absolute path or
> relative path that PDE Build can't resolve). In Eclipse 3.6/4.0, we'll
> look at trying to unify the stories for both IDE/headless environments.
> I think we're getting closer now that we have p2 and have revamped the
> target definition model.
> Thanks for your reports, it helps us to know people's use cases.
> Cheers,
> Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
> http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Re: [target] Using a target platform definition to create an installation? [message #65906 is a reply to message #65871] |
Sat, 27 June 2009 16:37  |
So, that's somewhat true. You can potentially find a way to use the PDE
Build support to fetch artifacts from p2 repositories.
" new extension has been added to PDE/Build that enables users to fetch
artifacts from p2 repositories. You can now add an entry to your map
file for build input and PDE/Build will retrieve the artifact and
include it in the build.
The map file entry needs to include the id and version of the
installable unit (IU), and the URI of the repository where the IU can be
found. The metadata and artifact repositories are assumed to be
co-located. An example is:
plugin@my.bundle.id ,1.0.0=p2IU,id=my.bundle.id,version=1.0.0,repository=http:/e xample.com/repo "
So you can fetch an IU that represents the SDK, deltapack and other
things. This would map to what you have specified in your target
definition for things that are based on 'software sites'
In Eclipse 3.6, we're looking at ways on making things more reusable
from a build point of view. It would be nice if you could reuse the
target definition at development time and build time. However, there are
some challenges that still need to be addressed.
Re: [target] Using a target platform definition to create an installation? [message #597340 is a reply to message #61203] |
Wed, 13 May 2009 00:02  |
> listed in software sites) to? Would be useful if there was an option to
Re: [target] Using a target platform definition to create an installation? [message #598669 is a reply to message #61302] |
John
> Cheers,
Re: [target] Using a target platform definition to create an installation? [message #598690 is a reply to message #65871] |
Current Time: Sun Jul 13 17:41:15 EDT 2025
Powered by FUDForum. Page generated in 0.04220 seconds
