Home » Modeling » M2T (model-to-text transformation) » organize imports beautifier?
organize imports beautifier? [message #61148] Tue, 12 May 2009 18:56 Go to next message
Will M2T include a java beautifier that cleans up imports ala the
hybrid labs beautifier? I'm asking because I want to find out if an
Eclipse external dependency would be neccessary to achieve this.
cheers,
Miles
Re: organize imports beautifier? [message #61245 is a reply to message #61148] Fri, 15 May 2009 09:06 Go to previous messageGo to next message
Miles:
I'm not aware of any plans within the various M2T components.
As for implementing such a thing in Eclipse, the easiest approach would
be to make use of the Java Development Tools (JDT) that currently
implements the Organize Imports command. I haven't looked, but I'd guess
you'd end up with a dependency on JDT.
Paul
Re: organize imports beautifier? [message #61318 is a reply to message #61245] Fri, 15 May 2009 18:30 Go to previous messageGo to next message
Thanks Paul,
I heard from Karsten on oAW list that they're working to try to get it over.
FWIW: The hybridlabs functionality is actually a bit different from
that in JDT -- it takes fully qualified inline package names and makes
them into import statements. One could strip all qualifications and
then do the import but this wouldn't handle the many cases where class
names are shared, or for example where some one uses java.awt.List and
java.util.List in the same class. :)
In practice what I have been doing is using the oAW M2T beautifier
which uses the JDT settings IIRC, and then using the hybrid labs
beauifier with formatting turned off just to get the import qualified
package names.
Miles
On 2009-05-15 06:06:10 -0700, Paul Elder <pelder@ca.ibm.com> said:
> Miles:
> guess you'd end up with a dependency on JDT.
> Paul
Re: organize imports beautifier? [message #61341 is a reply to message #61318] Sun, 17 May 2009 14:25 Go to previous messageGo to next message
I have agreement from Karsten Klein to migrate the Hybridlabs beautifier
to Google Code. It cannot be itself hosted at M2T since it has a
dependency to Jalopy for code formatting. It might be that I take over
the import organizing feature to M2T, depending on IP approval and time.
For a first approach I have enough to do just to found the project at
Google and add a component for M2T compliance.
~Karsten
On 16.05.09 00:30, Miles Parker wrote:
> Thanks Paul,
> over.
> FWIW: The hybridlabs functionality is actually a bit different from that
> in JDT -- it takes fully qualified inline package names and makes them
> into import statements. One could strip all qualifications and then do
> the import but this wouldn't handle the many cases where class names are
> In practice what I have been doing is using the oAW M2T beautifier which
> uses the JDT settings IIRC, and then using the hybrid labs beauifier
> with formatting turned off just to get the import qualified package names.
> Miles
>> Miles:
>> would be to make use of the Java Development Tools (JDT) that
>> currently implements the Organize Imports command. I haven't looked,
>> but I'd guess you'd end up with a dependency on JDT.
>> Paul
Re: organize imports beautifier? [message #61387 is a reply to message #61341] Mon, 18 May 2009 18:00 Go to previous message
Hi Miles!
I have founded the Google Code project for the Hybridlabs Beautifier -
and made it ready for M2T. The JavaImportBeautifier class now implements
both PostProcessor interfaces, from oAW4 and M2T. This way it is
backward compatible.
We won't be able to migrate the import organizing feature to M2T, it is
dependend on Antlr. So the component will stay standalone, and we should
discuss therefore further issues outside this list.
A first distribution of the beautifier is available:
http://code.google.com/p/hybridlabs-beautifier/downloads/lis t
Best wishes,
~Karsten
> ~Karsten
>> Thanks Paul,
>> over.
>> names.
>> Miles
>>> Miles:
>>> Paul
Previous Topic:<c:iterate> over elements
Next Topic:[Announce] M2T XPAND 0.7.0RC1 is available
Current Time: Mon Jul 21 22:17:49 EDT 2025
Powered by FUDForum. Page generated in 0.05737 seconds
