Home » Eclipse Projects » Plugin Development Environment (PDE) » NoClassDefFoundError on startup
NoClassDefFoundError on startup [message #61134] |
Tue, 12 May 2009 11:31  |
I recently upgarded to a new version of eclipse (3.5M6), and I was initially
able to use my existing Run/Debug configurations. But now (I have no idea
what changed between yesterday and today) I get a BundleException that says
my activator is invalid, caused by a NoClassDefFoundError. I checked the
run config by clicking "Add Required Plug-ins" and "Validate Plug-ins", and
no problems are detected. I had been trying to upgrade to 3.5M7 but ran
into issues manually dropping in the log4j plug-in, so I reverted back to
M6, and there's a chance there might be some M7 plugin(s) lingering. Could
that cause the error I'm seeing? Should I just wipe the slate clean and
start installing M6 all over again?
Thanks.
Re: NoClassDefFoundError on startup [message #61350 is a reply to message #61134] |
Wed, 13 May 2009 00:17   |
> initially able to use my existing Run/Debug configurations. But now (I
> have no idea what changed between yesterday and today) I get a
> BundleException that says my activator is invalid, caused by a
> NoClassDefFoundError. I checked the run config by clicking "Add
> Required Plug-ins" and "Validate Plug-ins", and no problems are
> detected. I had been trying to upgrade to 3.5M7 but ran into issues
> manually dropping in the log4j plug-in, so I reverted back to M6, and
> there's a chance there might be some M7 plugin(s) lingering. Could that
If you're activator is invalid, it could be a sign of some other
problems. I would use 3.5 M7 as that's a better bet than M6 imho.
Can you tell us more about the exception?
Before starting clean slate with M7, I would create a brand new launch
configuration, make sure that the workspace is cleared and the
configuration area in the launch config (check the 'Configuration' tab
for the checky box)
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Re: NoClassDefFoundError on startup [message #61444 is a reply to message #61350] |
Wed, 13 May 2009 11:45   |
Thanks Chris. I tried deleting all of my launch configurations and then
creating a new one with the Clear checkbox selected in both the Main tab and
the Configuration tab. Also, I don't know if it matters, but I tried both
"Run a product" and "Run an application" under Main > Program to Run. Under
Java Runtime Environment, I have Runtime JRE selected and pointed at jdk
1.6.0_12. Running under this configuration, I still get the error (see
below). Let me know if I can provide you with any other relevant
information about my environment.
On a semi-related note, I tried starting over with a fresh 3.5 M7, and for
some reason it doesn't load most of the eclipse plug-ins (for example, the
Plug-ins view doesn't show org.eclipse.core.runtime or org.eclipse.swt).
Oddly enough, those plug-ins do show up in the Plug-ins Registry view. I
apologize for my ignorance here. I'm not clear on exactly how plug-ins are
loaded or what the difference is between the Plug-ins view and Plug-ins
Registry view.
!SESSION 2009-05-13
11:39:55.653 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_12
Framework arguments: -application com.etm.application
Command-line arguments: -application com.etm.application -data
C:\Users\sither\workspace/../runtime-com.etm.ui.product -dev
file:C:/Users/sither/workspace/.metadata/.plugins/org.eclips e.pde.core/com.etm.ui.product/dev.properties -
debug
C:\Users\sither\workspace\.metadata\.plugins\org.eclipse.pde .core\com.etm.ui.product/.options
-os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 2 0 2009-05-13 11:40:06.471
!MESSAGE The activator com.etm.EtmUIPlugin for bundle com.etm.ui is invalid
!STACK 0
org.osgi.framework.BundleException: The activator com.etm.EtmUIPlugin for
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:157)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:750)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:352)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:280)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:408)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:238)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1193)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:874)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:189)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Caused by: java.lang.ClassNotFoundException: com.etm.EtmUIPlugin
org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:489)
org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:405)
org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:393)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:105)
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
org.eclipse.osgi.internal.loader.BundleLoader.loadClass(Bund leLoader.java:321)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:231)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:150)
... 23 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2009-05-13 11:40:06.493
!MESSAGE Application error
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in com.etm.ui was unable to
load class com.etm.rcp.EtmApplication.
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(RegistryStrategyOSGI.java:180)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:162)
Caused by: java.lang.ClassNotFoundException: com.etm.rcp.EtmApplication
... 16 more
"Chris Aniszczyk" <zx@eclipsesource.com> wrote in message
news:gudhk4$404$2@build.eclipse.org...
>> NoClassDefFoundError. I checked the run config by clicking "Add Required
>> Plug-ins" and "Validate Plug-ins", and no problems are detected. I had
>> been trying to upgrade to 3.5M7 but ran into issues manually dropping in
>> the log4j plug-in, so I reverted back to M6, and there's a chance there
>> might be some M7 plugin(s) lingering. Could that cause the error I'm
>> seeing? Should I just wipe the slate clean and start installing M6 all
>> over again?
> If you're activator is invalid, it could be a sign of some other problems.
> configuration area in the launch config (check the 'Configuration' tab for
> the checky box)
> Cheers,
Re: NoClassDefFoundError on startup [message #61737 is a reply to message #61444] |
Thu, 14 May 2009 06:49  |
Thanks again for the help, Chris. It turns out that at some point while I
was upgrading eclipse and loading my projects into it, the pojects'
build.properties were altered. I reverted build.properties, and the problem
went away.
"Sither" <sither@mit.edu> wrote in message
news:guepvh$13s$1@build.eclipse.org...
> and the Configuration tab. Also, I don't know if it matters, but I tried
> both "Run a product" and "Run an application" under Main > Program to Run.
> Under Java Runtime Environment, I have Runtime JRE selected and pointed at
> jdk 1.6.0_12. Running under this configuration, I still get the error
> (see below). Let me know if I can provide you with any other relevant
> are loaded or what the difference is between the Plug-ins view and
> !SESSION 2009-05-13
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> debug
> invalid
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> at
> at
> at
> ... 23 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 16 more
>> for the checky box)
>> Cheers,
Re: NoClassDefFoundError on startup [message #597357 is a reply to message #61134] |
for the checky box)
Re: NoClassDefFoundError on startup [message #597384 is a reply to message #61350] |
Registry view.
!SESSION 2009-05-13
debug
!STACK 0
... 23 more
Root exception:
!STACK 1
... 16 more
>> over again?
> the checky box)
> Cheers,
Re: NoClassDefFoundError on startup [message #597462 is a reply to message #61444] |
went away.
> !SESSION 2009-05-13
> debug
> invalid
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 23 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 16 more
>> for the checky box)
>> Cheers,
Current Time: Wed Jul 16 06:04:31 EDT 2025
Powered by FUDForum. Page generated in 0.09491 seconds
