Home » Modeling » GMF (Graphical Modeling Framework) » Creating/Updating EditParts via EMF model elements
Creating/Updating EditParts via EMF model elements [message #61067] |
Wed, 11 October 2006 18:59  |
Originally posted by: a0309169.unet.univie.ac.at
I would whether there exists some "clever" method of adding new EMF
elements into the diagram model, and simultaneously creating/updating
the corresponding EditParts.
The solution I found so far (from the tutorial), which consists of
crafting Requests, has several problems IMHO:
1. It gives little flexibility in controlling undo/redo sequences.
2. It does not enable adding existing model elements, only creating new
ones.
3. It's quite complicated, but that may be just my intuition...
Any help would be much appreciated.
Mikolaj Koziarkiewicz
Re: Creating/Updating EditParts via EMF model elements [message #61091 is a reply to message #61067] |
Wed, 11 October 2006 19:22   |
Originally posted by: vcciubot.uwaterloo.ca
Canonical policies do - I guess - exactly what you need.
Here's how it works:
You have an EMF model that gets mirrored into a notational model that uses
views (nodes and edges). The synchronization between the two models is
performed by canonical policies that listen to the model elements for
updates. When these occur, they create/remove views from the notational
side.
EditParts listen to the notational model for updates. When these changes
occur they create/remove children edit parts as necessary.
Note however, that certain edit policies in gmf create both the view and
the model element: CreationEditPolicy, GraphicalNodeEditPolicies do this.
To accommodate this, when an edit part returns a command for certain types
of requests, it wraps it into two other commands that turn off/on the
canonical edit policies sensitive to the given context so that views don't
get created twice.
Maybe somebody else can explain why not all containers should be canonical.
vlad
On Thu, 12 Oct 2006 00:59:36 +0200, Mikolaj Koziarkiewicz wrote:
> Hello,
> ones.
Re: Creating/Updating EditParts via EMF model elements [message #61702 is a reply to message #61091] |
Thu, 12 October 2006 10:11   |
Mikolaj:
Take a look at the "Canonical Containers" Tutorial for more info.
Vlad:
This tutorial answers your question why shouldn't all containers be
canonical...
"This behavior is also optionally installable since sometimes it may be
desirable to see a partial view of the semantic model. If we consider a
UML class diagram, the user will typically only be interested in a
subsection of a system rather then the whole system (or even the whole
contents of a package). In this case, the user will want to selectively
create views to construct their diagram and probably wouldn't want views
being automatically created on the diagram when added semantically."
- Cherie
> side.
> get created twice.
> vlad
>> Hello,
>> ones.
>> Regards,
Re: Creating/Updating EditParts via EMF model elements [message #67402 is a reply to message #61702] |
Sun, 22 October 2006 16:07   |
Vlad, Cherie: thank you for the very informative replies!
I have a new question 'though: what is the difference between a
SemanticEditPolicy and a CanonicalEditPolicy? They both seem to be
suited for similar roles...
Mikolaj
> Mikolaj:
> Vlad:
> canonical...
> - Cherie
>> uses
>> side.
>> types
>> don't
>> get created twice.
>> canonical.
>> vlad
>>> Hello,
>>> new ones.
>>> Regards,
Re: Creating/Updating EditParts via EMF model elements [message #67928 is a reply to message #67402] |
Mon, 23 October 2006 10:42   |
Canonical policies synchronize the view with the model. So they listen to
the model and create/remove view elements model changes occur.
The semantic policy is asked for commands that act on the model when the
user interacts with the diagram using a tool or the keyboard such as
adding/removing nodes, creating connections etc.
vlad
> Mikolaj
>> Mikolaj:
>> Vlad:
>> canonical...
>> - Cherie
>>> uses
>>> side.
>>> types
>>> don't
>>> get created twice.
>>> canonical.
>>> vlad
>>>> Hello,
>>>> new ones.
>>>> Regards,
Re: Creating/Updating EditParts via EMF model elements [message #68117 is a reply to message #67928] |
Mon, 23 October 2006 13:58  |
Vlad,
OK, I understand the difference now. Thank you for the info!
Mikolaj
> vlad
>> Regards,
>> Mikolaj
>>> Mikolaj:
>>> Vlad:
>>> canonical...
>>> - Cherie
>>>> uses
>>>> side.
>>>> types
>>>> don't
>>>> get created twice.
>>>> canonical.
>>>> vlad
>>>>> Hello,
>>>>> new ones.
>>>>> Regards,
Current Time: Thu Jul 17 21:57:39 EDT 2025
Powered by FUDForum. Page generated in 0.28570 seconds
