Home » General (non-technical) » Eclipse Foundation » BreakpointValidationException whenever attempting to set breakpoint
BreakpointValidationException whenever attempting to set breakpoint [message #5439] Tue, 19 October 2004 04:24 Go to next message
I'm using Eclipse 3.0.1 on Windows XP Professional running on top of J2SE
1.4.2_06 (the SDK component). Whenever I try to set a breakpoint in Java
source, I get "internal error: BreakpointValidationException". The
Eclipse error log says:
!ENTRY org.eclipse.core.runtime 4 2 Oct 19, 2004 09:17:12.943
!MESSAGE An internal error occurred during: "Breakpoint location
validation".
!STACK 0
java.lang.RuntimeException: J2SE 1.5 parser not implemented yet
at org.eclipse.jdt.core.dom.ASTParser.convert(ASTParser.java:71 4)
org.eclipse.jdt.core.dom.ASTParser.internalCreateAST(ASTPars er.java:681)
at org.eclipse.jdt.core.dom.ASTParser.createAST(ASTParser.java: 574)
org.eclipse.jdt.internal.debug.ui.actions.BreakpointLocation VerifierJob.run(BreakpointLocationVerifierJob.java:109)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
yet I'm not using J2SE 1.5. Anyone have any ideas?
I did have debugging working fantastically in Eclipse 3.0 - e.g. remote
debugging of building processes and Tomcat web apps - so this is a bitter
blow! I suspect that I managed to screw up configuration somewhere -
possibly around the time I tried out J2SE 5.0 on the same machine, though
I have since completely deinstalled J2SE and checked that no corresponding
folders exist, then reinstalled 1.4.2. The problem happens still if I
switch back to Eclipse 3.0 or go up to 3.1; and it was happening with J2SE
1.4.2_05 too. Everything else Eclipse-wise works fine.
Is there perhaps something cached in Eclipse history which has hung around
in the workspace? If so, what should I clear?
tia
Jon
Re: BreakpointValidationException whenever attempting to set breakpoint [message #5486 is a reply to message #5439] Thu, 21 October 2004 00:12 Go to previous message
This should be posted on the Platform newsgroup.
"Jonathan Woods" <jonathan.woods@scintillance.com> wrote in message
news:cl2j0q$q9a$1@eclipse.org...
> validation".
> !STACK 0
> at
> at
> tia
> Jon
Previous Topic:Breakpoint triggers text editor
Next Topic:anyone knows plugin workshops in Europe in english?
Current Time: Wed Jul 16 16:09:44 EDT 2025
Powered by FUDForum. Page generated in 0.03678 seconds
