Home » Language IDEs » Java Development Tools (JDT) » Running unit tests from org.eclipse.jdt.ui.tests.refactoring project
Running unit tests from org.eclipse.jdt.ui.tests.refactoring project [message #60986] Wed, 18 June 2003 10:49 Go to next message
Is it possible to run a single test case(for example, InlineMethodTests)
from org.eclipse.jdt.ui.tests.refactoring project? When I try to do it using
Eclipe JUnit launcher I get NullPointerException in
JavaProjectHelper.createJavaProject because call to
ResourcesPlugin.getWorkspace() returns null. Looks like the test case
requires some prior initialization. If it can't be executed stand alone then
how can I run all JDT unit tests?
Thank you,
Dmitry
Re: Running unit tests from org.eclipse.jdt.ui.tests.refactoring project [message #61126 is a reply to message #60986] Wed, 18 June 2003 12:22 Go to previous message
Dmitry,
You need to install the org.eclipse.jdt.pde.junit plugin
( http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/jdt- ui-home/plugins
/org.eclipse.jdt.junit/index.html) and run the test using a 'JUnit Plugin
Test' configuration.
Jerome
"Dmitry Stalnov" <dstalnov@fusionone.com> wrote in message
news:bcptr7$ql1$1@rogue.oti.com...
> Hello,
using
then
> Thank you,
> Dmitry
Previous Topic:Debug Menu not Working
Next Topic:[ANN] release 1.3 of the metrics plugin is out
Current Time: Sat Jul 26 18:40:02 EDT 2025
Powered by FUDForum. Page generated in 1.27593 seconds
