Home » Eclipse Projects » Plugin Development Environment (PDE) » Access information about existing Java projects in the workspace
Access information about existing Java projects in the workspace [message #60946] Mon, 11 May 2009 10:16 Go to next message
Originally posted by: cold.phusion.gmail.com
I'm trying to build a plugin which displays various informations about
Java classes for a project in the local workspace - e.g. javadocs or
class details (modifiers, fields, methods, etc..). Is there a public API
for the JDT where I can get this kind of data?
Alex
Re: Access information about existing Java projects in the workspace [message #60970 is a reply to message #60946] Mon, 11 May 2009 10:46 Go to previous messageGo to next message
JDT Core has those APIs:
http://help.eclipse.org/stable/topic/org.eclipse.jdt.doc.isv /guide/jdt_int_model.htm
- Prakash
http://blog.eclipse-tips.com
Re: Access information about existing Java projects in the workspace [message #60994 is a reply to message #60946] Mon, 11 May 2009 10:47 Go to previous messageGo to next message
I'd get the workspace from ResourcesPlugin and than you can use the
JDTCore class to get an IJavaProject from a workspace project. That
should be enough to get you started.
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Re: Access information about existing Java projects in the workspace [message #61015 is a reply to message #60946] Mon, 11 May 2009 18:57 Go to previous message
example: http://www.vogella.de/articles/EclipseJDT/article.html
Besgt regards, Lars
> Alex
Re: Access information about existing Java projects in the workspace [message #597215 is a reply to message #60946] Mon, 11 May 2009 10:46 Go to previous message
- Prakash
Re: Access information about existing Java projects in the workspace [message #597224 is a reply to message #60946] Mon, 11 May 2009 10:47 Go to previous message
Re: Access information about existing Java projects in the workspace [message #597231 is a reply to message #60946] Mon, 11 May 2009 18:57 Go to previous message
Besgt regards, Lars
> Alex
Previous Topic:Access information about existing Java projects in the workspace
Next Topic:eclipse API's to get console message
Current Time: Thu Jul 24 20:33:23 EDT 2025
Powered by FUDForum. Page generated in 0.03876 seconds
