Home » Eclipse Projects » Equinox » general purpose server-side OSGi
general purpose server-side OSGi [message #60945] Thu, 09 February 2006 13:07 Go to next message
Originally posted by: jfallows.txesystems.com
Folks,
I've just started taking a look at the Equinox BridgeServlet and Servlet
extension point for OSGi - very cool and useful stuff!
Previously, we had to solve the problem of starting OSGi in a web-based
environment by factoring our code so as to rendezvous on public
interfaces that were loaded in the web-app classloader, with
implementations loaded as part of the bundle.
We are very enthusiastic to see the progress being made on this
important general-purpose solution that uses standard J2EE APIs, like
javax.servlet.Servlet to do the rendezvous instead - very clever!
Looking at the current implementation on 3.2 HEAD, we have a few questions.
Q1. HttpServletRequest.getContextPath()
If the BridgeServlet is running in the host Web Container under context
/bridge and a Servlet is registered via OSGi under context /osgi, then
the URL to access the OSGi Servlet is /bridge/osgi. Perhaps the OSGi
HttpServletRequest.getContextPath() should return "/bridge/osgi" in this
scenario?
Q2. ServletContext.getInitParameter(String paramName)
The OSGi ServletContext seems to be delegating back to the host
ServletContext for the BridgeServlet to lookup ServletContext
initialization parameters (specified as <context-param> in web.xml).
Perhaps each OSGi ServletContext should have independent context
initialization parameters? Otherwise, two OSGi servlet bundles could
not configure the same context initialization parameter differently.
Q3. Extension point syntax
How much of the standard J2EE web.xml syntax will eventually be
supported? If not 100%, which parts would be omitted and why?
Q4. Compiling JSPs on-demand
It seems as though JSPs must be pre-compiled because there is currently
no support for on-demand compilation. However, pre-compilation is tied
to a specified vendor implementation, because the translated Java code
extends a vendor-specific class. Are there any plans to leverage the
host container JSP Runtime to support on-demand JSP compilation for OSGi
bundles?
Finally, if you would like some help with designing and coding these
features, I'd be happy to help. :)
Kind Regards,
John Fallows.
Author: Pro JSF and Ajax: Building Rich Internet Components
http://apress.com/book/bookDisplay.html?bID=10044
Re: general purpose server-side OSGi [message #61322 is a reply to message #60945] Fri, 10 February 2006 17:53 Go to previous messageGo to next message
Originally posted by: simon.kaegi.cognos.com
Hi John,
These are all good questions.
> context /bridge and a Servlet is registered via OSGi under context /osgi,
> then the URL to access the OSGi Servlet is /bridge/osgi. Perhaps the OSGi
> scenario?
When you register a servlet the alias you use just becomes the servlet
path. The context path isn't affected in this case.
> ServletContext for the BridgeServlet to lookup ServletContext initialization
> parameters (specified as <context-param> in web.xml). Perhaps each OSGi
> ServletContext should have independent context initialization parameters?
> Otherwise, two OSGi servlet bundles could not configure the same context
The current OSGi HttpService doesn't deal with multiple ServletContexts. A
valid implementation here would be to return nothing. I left it as it is
primarily as a convenience. Depending on seeing these parameters is
definitely not portable.
> How much of the standard J2EE web.xml syntax will eventually be supported?
Eventually, I'd like to support it all, however for the time being the
syntax while similar to web.xml will only handle what's available in the
OSGi HttpService.
In terms of what "could" be added easily I think filters and listeners are
good candidates. I suspect most of the other more static declarative
elements might be very hard to add though.
> It seems as though JSPs must be pre-compiled because there is currently no
> support for on-demand compilation. However, pre-compilation is tied to a
> specified vendor implementation, because the translated Java code extends a
> vendor-specific class. Are there any plans to leverage the host container
> JSP Runtime to support on-demand JSP compilation for OSGi bundles?
For the reasons you mention (and more) I don't think leveraging the host
containers JSP runtime is feasible. I'd really like to see if we can't
house the runtime and compilation directly inside the OSGi framework. On
this one issue I could really use some help both for design and the actual
coding.
-Simon
Re: general purpose server-side OSGi [message #61470 is a reply to message #61322] Tue, 14 February 2006 13:20 Go to previous messageGo to next message
Hi Simon,
Thanks very much for your reply. I have some follow-up points below.
Simon Kaegi wrote:
> Hi John,
>> OSGi
>> scenario?
Okay. Suppose the BridgeServlet is deployed to the host Web container
with context-path "/host-webapp" and servlet-path "/equinox-bridge".
Now, a Servlet is registered using equinox at alias "/osgi-servlet".
What are the values for context-path and servlet-path in the context of
"/osgi-servlet"?
It seems to have the following configuration:
servlet-path "/osgi-servlet"
....which would lose information about "/equinox-bridge" in the path.
Many Web technologies construct absolute webapp URLs simply by prefixing
the context-path. That would seem to break in this scenario due to the
lost information, right?
In other words, a URL intended for
/host-webapp/equinox-bridge/osgi-servlet/...
would instead be written as
/host-webapp/osgi-servlet/...
resulting in a 404 Not Found.
> A valid implementation here would be to return nothing. I left it as it
> is primarily as a convenience. Depending on seeing these parameters is
I suspect that the OSGi HttpServlet should become aware of multiple
ServletContexts to properly isolate itself from the host webapp and
allow Web OSGi plugins to be introduced without the need for additional
configuration. Do you agree?
> OSGi HttpService.
What is the process for evolving the OSGi HttpService? I imagine the
goal is to be 100% portable with Servlet code originally written for
traditional J2EE containers. Is this correct?
> are good candidates. I suspect most of the other more static declarative
Filters and listeners would definitely be useful additions to the
current extension point. However, switching to a standard web.xml
syntax would be preferable over inventing something else.
Which static declarative elements are you referring to?
>> currently no support for on-demand compilation. However,
>> pre-compilation is tied to a specified vendor implementation, because
>> the translated Java code extends a vendor-specific class. Are there
>> any plans to leverage the host container JSP Runtime to support
> actual coding.
Hmmm, interesting. If we house the JSP runtime inside the OSGi
framework, and then deploy the whole thing as a traditional J2EE Web
application, would we have two Web containers running one inside the other?
If we try to let the host JSP Runtime take control of compilation, does
that introduce ClassLoader issues due to a lack of visibility from the
host Web application into the relevant OSGi Web plugin?
Kind Regards,
John Fallows.
Re: general purpose server-side OSGi [message #61592 is a reply to message #61470] Wed, 15 February 2006 09:25 Go to previous messageGo to next message
/osgi,
> >> OSGi
this
> >> scenario?
> "/osgi-servlet"?
Ok. Yes what you desribe sounds correct. This is the behaviour that is on
the HEAD.
Originally, the servlet path was not taken into consideration.
I'm not sure I understand the question.
The OSGi HttpService allows you to pass in initparams for each Servlet so
gives per bundle isolation of configuration at this level.
In addition HttpContexts provide similar scoping as individual Servlet
Contexts.
I think I agree ;)
> > OSGi HttpService.
I think the process for evolving the HttpService (if that's the right
approach) is to work with the OSGi. I think it's fair game to experiment in
the incubator and see if we can't provide some good ideas and use cases.
For the short term I'd like to be as closely aligned with OSGi HttpService
as possible.
In the future I'd like to move something resembling a java-binding of
web.xml for the service and similar for extensions.
A short list from older analysis...
ServletContext Config
Session Config
Welcome files
Error Page
JNDI integration
JSP Config
Mimetype Mappings
Security - I'd be interested in any thoughts on making this dynamic but at
least for now I think this would be tough and container dependent.
> > actual coding.
other?
I think that's the danger -- slippery slope.
As much as possible I'd like to leverage the appserver so that the servlet
bridge remains a "bridge" and not a full web container.
If we can leverge the JSP runtime of the appserver all the better however I
suspect this is difficult.
Exactly the problem.
> Kind Regards,
> John Fallows.
Re: general purpose server-side OSGi [message #61781 is a reply to message #61592] Thu, 16 February 2006 02:33 Go to previous messageGo to next message
>> Web application, would we have two Web containers running one
>> inside the other?
We solved such an issue with a solution everybody refers to as the
Tomcat Mess. It's a Tomcat running inside Tomcat/WebSphere/WebLogic.
It's ugly.
> servlet bridge remains a "bridge" and not a full web container. If we
We have OS specific fragments in Eclipse so why not having application
server specific fragments?
Cu, Gunnar
Gunnar Wagenknecht
gunnar@wagenknecht.org
http://wagenknecht.org/
Re: general purpose server-side OSGi [message #61969 is a reply to message #61781] Fri, 17 February 2006 05:55 Go to previous messageGo to next message
Originally posted by: newsreader.infonoia.com
I probably would't be religous about how the JSP compiler+renderer is
implemented. Eclipse IDE has a full-blown Tomcat running in a plug-in,
to make help work, and no-one cares that it's not Jetty, Websphere, or
whatever. Let's just say we need a JSP compiler+renderer, define that as
requirement, and see what the most straightforward,
environment-independent solution is. A plus of "one" JSP
compiler-renderer bundle is that I could also use it when running
bundles in an OSGi-native container, which is the long-term vision, I
guess.
Wolfgang
>>> inside the other?
> It's ugly.
> Cu, Gunnar
Re: general purpose server-side OSGi [message #61992 is a reply to message #61969] Fri, 17 February 2006 07:13 Go to previous messageGo to next message
In a typical JSP Container all jsp requests (*.jsp) are mapped to a
JspServlet. This servlet is really just a mini container that handles
all JSP requests, translating them when required and then directing the
request to the generated JSPServletWrapper.
The most generic JSP Container that I am aware of is Jasper which is
used in Tomcat (and Jetty I think). It should be possible to create a
Jasper Bundle that provides a servlet extension point for mapping
(*.jsp). As the Jasper JspServlet (org.apache.jasper.servlet.JspServlet)
expects to find the jsp source files on disk it would have to be
extended or replaced with one that has access to the extension registry
and is able to pull the jsp source files out of the bundles that have
specified them. It should also be possible for this Jasper Bundle to
provide other services such as JSP precompiling and validation etc.
Another potential issue would be the actual compiling of the generated
JSP servlet class. Using the standard jdk compiler found in tools.jar
would be problematic as it expects to receive a set of absolute
classpath entries. In the OSGi world access to the classpaths provided
by the bundles classloader would be pretty hard to do. However, Jasper
does support the use of the Eclipse JDT compiler which is far less
restrictive on the classpaths it expects (In fact it uses the
WebApplications classloader to get access to dependent classes instead
of using real classpaths).
Richard
> guess.
> Wolfgang
>>>> inside the other?
>> It's ugly.
>> Cu, Gunnar
Re: general purpose server-side OSGi [message #62016 is a reply to message #61992] Fri, 17 February 2006 16:54 Go to previous messageGo to next message
Agree with Richard.
Afterthought on reusing the specific container: different containers
have their own taglib implementations, as for JSTL/Standard.jar so
creating JSPs that fit "all sizes" is difficult. E.g. Resin has its own,
Tomcat doesn't come with one, etc. etc. And then there are levels: 2.3,
2.4 etc.
So should a bundle be tagged 2.3, 2.4? A 2.4 Jasper bundle feels right.
W.
Re: general purpose server-side OSGi [message #62039 is a reply to message #62016] Sat, 18 February 2006 09:04 Go to previous messageGo to next message
This brings up another issue: How to notify the JSP container of
available TLD's.
The JSP spec dictates that the JSP container will only look for TLD's in
the WEB-INF directory (and subdirs under it) and in any jars found in
the WEB-INF/lib directory.
Any taglib bundles would have to have some way of registering their
available TLD's with the JSP Container bundle (probably would have to be
more modified code in the Jasper implementation). This, of course, would
be non-spec compliant.
Richard
> Agree with Richard.
> 2.4 etc.
> W.
Re: general purpose server-side OSGi [message #62059 is a reply to message #62039] Sat, 18 February 2006 13:17 Go to previous messageGo to next message
For my understanding, why would the container need tlds? That is if we
write a jasper bundle, in osgi, separate of the container. (like a
jasper bundle for Felix).
Wolfgang
Re: general purpose server-side OSGi [message #62081 is a reply to message #62059] Sat, 18 February 2006 16:12 Go to previous messageGo to next message
To be able to translate a JSP the JSP Container would have to have the
details of the available Tag Libraries that have been installed. Without
the TLD the JSP container would not know which tag classes to generate
code to use etc.
> Wolfgang
Re: general purpose server-side OSGi [message #62198 is a reply to message #62081] Sun, 19 February 2006 12:49 Go to previous messageGo to next message
I think I had read your post the wrong way. You are saying that "if we
use the container to compile JSPs, we are non-compliant." No dispute.
I think a jasper bundle would be a solution. This is not the container
compiling, it is an osgi bundle.
W.
> code to use etc.
>> Wolfgang
Re: general purpose server-side OSGi [message #62222 is a reply to message #62198] Sun, 19 February 2006 15:53 Go to previous messageGo to next message
I think we are mixing up our terminology definitions. Here are mine.
JSP Engine/Container : Consists of two core components, a JSP runtime
and a JSP translator.
If a JSP has already been precomiled into a class then all that is
required to run it is a JSP runtime. This is what you have achieved with
your RSP demonstration. You provided a bundle that had a JSP runtime
within it, the JSP class was treated as a regular servlet defined via an
extension point.
To go to the next level of supporting the translation of a JSP source
file the bundle must also include the JSP translator component as well
as the runtime. Instead of treating the JSP as a regular servlet an
intermediary must be used to catch the request for a given JSP then
translate, compile and classload it.
Whether the translation of a JSP occurs in a regualar WebContainer or
within a bundle the JSP translator component must have access to the
TLD's for any tag library dependencies that a JSP has.
For example if a request is received for a JSP that depends on a JSTL
tag the JSP translator will process the tag library directive that
details the uri of the JSTL tab library. This uri will have to be
resolved to a real TLD file. If the JSTL support is provided within
another bundle then that bundle will somehow have to register the TLD's
it provides with the JSP Translator so it can find out what the tag
library class names are to be used in the generated JSP servlet as well
as parameters types.
Richard
> W.
>> Without the TLD the JSP container would not know which tag classes to
>> generate code to use etc.
>>> we write a jasper bundle, in osgi, separate of the container. (like a
>>> Wolfgang
Re: general purpose server-side OSGi [message #62246 is a reply to message #61322] Sun, 19 February 2006 16:08 Go to previous messageGo to next message
> actual coding.
I have started some experimentation with jasper, since it now compiles
using the jdt compiler and doesn't need ant / javac. (Excellent
suggestion by Richard Backhouse, and yes, it is used by both Tomcat and
Jetty.)
The Jasper servlet accesses JSP files and tag library descriptors
through the ServletContext.getResourceAsStream method which in the OSGi
HttpService uses the HttpContext provided when the servlet got
registered. The default HttpContext uses bundle.getResource() to obtain
the resource, which in turn calls getResource() on the bundle's classloader.
If the jasper bundle simply imports everything using some variation of
the "DynamicImport-Package: *" header, the JspServlet can be used
unchanged with only minimal code in the BundleActivator. (I have a
working prototype of this).
As an alternative, a specialized HttpContext could be provided that
checks that the requested resource ends in ".jsp" (or ".jspx" or ".tld").
The special HttpContext would also remove the servlet path from the
resource name (jasper appends servletPath and pathInfo to get the
complete path of the jsp file). The bridge servlet and the native OSGi
HttpService seem to have some differences here that would make it harder
to write bundles that work with both kinds of HttpService without the
prefix adjusting.
For discovery of tag libraries and tag files (I assume, haven't really
checked the specs) it would be necessary to implement
ServiceContext.getResourcePaths() -- but that means we need support from
the bridge servlet or HttpService implementation. So I'd rather leave
that out and tolerate having to put tag library descriptors somewhere on
the classpath.
For JSP registration, it should be possible to make the HttpContext
implementation use some JSP-registration services or extension points,
but I haven't done any work on that.
Interested?
Harald
Re: general purpose server-side OSGi [message #62294 is a reply to message #62246] Mon, 20 February 2006 11:40 Go to previous messageGo to next message
Hi Harald,
"Harald Niesche" wrote:
> I have started some experimentation with jasper...
This sounds like you've got something started and worth building on. Great!
Can you share your prototype? (warts and all is just fine with me)
I think there's considerable interest in this area and something to start
concrete implementation discussion would be excellent.
> prefix adjusting.
Hmm... I use both implementations with the same servlet bundles.
The equinox embedded HttpService won't have the servlet context path
portion, but the servletPath and pathInfo should be the same.
Can you elaborate a bit. If there's a bug here we should fix it.
> the classpath.
Lots of stuff still to work out. ;)
> Interested?
Definitely!
-Simon
Re: general purpose server-side OSGi [message #62318 is a reply to message #62294] Mon, 20 February 2006 18:47 Go to previous messageGo to next message
Simon Kaegi wrote:
> Hi Harald,
Unfortunately, I just found out that the JspRuntimeContext expects the
context class loader to be a URLClassLoader -- this didn't matter
yesterday, because I used a stripped down OSGi Framework that doesn't
have it's own class loaders (yes, it's illegal, but it allows me to do
things I can't do with real class loaders).
On first glance, it looks like it might be possible to change the class
so that it doesn't need the URLClassLoader. I'll look into that in the
next few days.
Sorry for the false alarm.
Harald
Re: general purpose server-side OSGi [message #62342 is a reply to message #62318] Tue, 21 February 2006 10:16 Go to previous messageGo to next message
Great Harald that you are working on this!
I briefly looked at this this weekend, and just one of the things I
wondered about was how to define the jsp servlet pattern, so that non-osgi
jsps would still be handled by the container, but jsps inside the osgi
platform would go to the osgi jasper.
I usually define a /platform/* subnamespace for the bridgeservlet, so that
there is room for the regular webapp outside this subnamespace. Not
related to Jasper, I wonder whether the bridgeservlet should keep a list
of its registered osgi http mappings instead of just that one pattern to
define access. And, of course bridgeservlet at some point should be able
to handle both /xx/* and *.xx url-patterns.
Wolfgang
Re: general purpose server-side OSGi [message #62366 is a reply to message #62342] Tue, 21 February 2006 11:44 Go to previous messageGo to next message
It looked simple enough when I started ... :-)
> non-osgi jsps would still be handled by the container, but jsps inside
> the osgi platform would go to the osgi jasper.
I have made no attempt to implement something that would handle *.jsp --
since I couldn't think of a way that could make this could work with the
HttpService.
What works now is that paths like
/bridge/jasper-jsp/<package>/<page>.jsp
or
/bridge/jasper-jsp/<package>/<page>.jspx
are mapped to the JSP servlet (and I have the "jasper-jsp" part hardcoded).
I'll try to package the current state sometime later today.
> that there is room for the regular webapp outside this subnamespace. Not
I have been thinking about that, too. I believe it would make the whole
contextPath / servletPath tweaking difficult or impossible. And because
the OSGi HttpService only supports dispatching based on a fixed prefix
(the alias), I don't see it's usefulness right now. Enlighten me!
Harald
Re: general purpose server-side OSGi [message #62391 is a reply to message #62294] Tue, 21 February 2006 19:44 Go to previous messageGo to next message
Here it is: http://www.osxa.org/wiki/JasperBundle
I hope it's possible to understand what I did ...
The bundle should work with stand-alone equinox and the bridge servlet,
but I have tested only with equinox and the org.eclipse.equinox.http
plugin (this made it necessary to wrap the servlet context because it
was throwing UnsupportedOperation exceptions when the JspServlet called
servletContext.getResourcePaths()).
The problem with the URLClassloader was solved by simply putting a
"wrapper" classloader as the current thread's context classloader when
the servlet is registered -- the servlet seems to remember the classloader.
And please forgive the lack of comments.
Harald
Re: general purpose server-side OSGi [message #62414 is a reply to message #62391] Wed, 22 February 2006 00:52 Go to previous messageGo to next message
Thanks Harald. This looks good and is definitely easy enough to follow.
I'll try it out and report back.
*sigh* I've hit this and a few other similar problems many times.
A servlet 2.4 compliant implementation would really be nice to have.
classloader.
Nice. Hmm... I wonder if destroy releases the context classloader.
-Simon
Re: general purpose server-side OSGi [message #62439 is a reply to message #62414] Wed, 22 February 2006 02:07 Go to previous messageGo to next message
Can't wait!
But they seem to be under the impression that it is illegal to support
2.4 (just like the Felix people were).
But for this case, it's really not that bad -- we either need to
implement it ourselves, anyway, so that we can support taglibrary
registration or we won't need it at all. Although the workaround is a
little bit ugly.
> classloader.
They don't explicitly null the field that holds the context classloader.
I tried to make sure it gets removed from the context: I call
setContextClassLoader() with the previous value after the JspServlet is
initialized).
Harald
Re: general purpose server-side OSGi [message #62509 is a reply to message #62439] Wed, 22 February 2006 18:37 Go to previous messageGo to next message
Cool Jasper Bundle!
I'll try it out with our RSP demo app.
Wolfgang
Re: general purpose server-side OSGi [message #62528 is a reply to message #62509] Wed, 22 February 2006 18:46 Go to previous message
> Cool Jasper Bundle!
Thanks!
See my other post for limitations of ServletContext.getRequestDispatcher
-- but I think in RSP forwarding should work.
And one other thing: remember to export the packages containing the JSP
pages from your bundle (or the JasperBundle won't be able to access them).
Harald
Previous Topic:HttpService: getRequestDispatcher returns null for different httpContext
Next Topic:Will the server-side stuff be out of incubation for 3.2?
Current Time: Sun Aug 31 21:03:07 EDT 2025
Powered by FUDForum. Page generated in 0.09070 seconds
