Home » Eclipse Projects » Equinox » general purpose server-side OSGi
general purpose server-side OSGi [message #60945] |
Thu, 09 February 2006 13:07  |
Originally posted by: jfallows.txesystems.com
Folks,
I've just started taking a look at the Equinox BridgeServlet and Servlet
extension point for OSGi - very cool and useful stuff!
Previously, we had to solve the problem of starting OSGi in a web-based
environment by factoring our code so as to rendezvous on public
interfaces that were loaded in the web-app classloader, with
implementations loaded as part of the bundle.
We are very enthusiastic to see the progress being made on this
important general-purpose solution that uses standard J2EE APIs, like
javax.servlet.Servlet to do the rendezvous instead - very clever!
Looking at the current implementation on 3.2 HEAD, we have a few questions.
Q1. HttpServletRequest.getContextPath()
If the BridgeServlet is running in the host Web Container under context
/bridge and a Servlet is registered via OSGi under context /osgi, then
the URL to access the OSGi Servlet is /bridge/osgi. Perhaps the OSGi
HttpServletRequest.getContextPath() should return "/bridge/osgi" in this
scenario?
Q2. ServletContext.getInitParameter(String paramName)
The OSGi ServletContext seems to be delegating back to the host
ServletContext for the BridgeServlet to lookup ServletContext
initialization parameters (specified as <context-param> in web.xml).
Perhaps each OSGi ServletContext should have independent context
initialization parameters? Otherwise, two OSGi servlet bundles could
not configure the same context initialization parameter differently.
Q3. Extension point syntax
How much of the standard J2EE web.xml syntax will eventually be
supported? If not 100%, which parts would be omitted and why?
Q4. Compiling JSPs on-demand
It seems as though JSPs must be pre-compiled because there is currently
no support for on-demand compilation. However, pre-compilation is tied
to a specified vendor implementation, because the translated Java code
extends a vendor-specific class. Are there any plans to leverage the
host container JSP Runtime to support on-demand JSP compilation for OSGi
bundles?
Finally, if you would like some help with designing and coding these
features, I'd be happy to help. :)
Kind Regards,
John Fallows.
Author: Pro JSF and Ajax: Building Rich Internet Components
http://apress.com/book/bookDisplay.html?bID=10044
Re: general purpose server-side OSGi [message #61470 is a reply to message #61322] |
Tue, 14 February 2006 13:20   |
Hi Simon,
Thanks very much for your reply. I have some follow-up points below.
Simon Kaegi wrote:
> Hi John,
> These are all good questions.
>> context /bridge and a Servlet is registered via OSGi under context /osgi,
>> then the URL to access the OSGi Servlet is /bridge/osgi. Perhaps the
>> OSGi
>> scenario?
> When you register a servlet the alias you use just becomes the servlet
> path. The context path isn't affected in this case.
Okay. Suppose the BridgeServlet is deployed to the host Web container
with context-path "/host-webapp" and servlet-path "/equinox-bridge".
Now, a Servlet is registered using equinox at alias "/osgi-servlet".
What are the values for context-path and servlet-path in the context of
"/osgi-servlet"?
It seems to have the following configuration:
servlet-path "/osgi-servlet"
....which would lose information about "/equinox-bridge" in the path.
Many Web technologies construct absolute webapp URLs simply by prefixing
the context-path. That would seem to break in this scenario due to the
lost information, right?
In other words, a URL intended for
/host-webapp/equinox-bridge/osgi-servlet/...
would instead be written as
/host-webapp/osgi-servlet/...
resulting in a 404 Not Found.
> The current OSGi HttpService doesn't deal with multiple ServletContexts.
> A valid implementation here would be to return nothing. I left it as it
> is primarily as a convenience. Depending on seeing these parameters is
> definitely not portable.
I suspect that the OSGi HttpServlet should become aware of multiple
ServletContexts to properly isolate itself from the host webapp and
allow Web OSGi plugins to be introduced without the need for additional
configuration. Do you agree?
> Eventually, I'd like to support it all, however for the time being the
> syntax while similar to web.xml will only handle what's available in the
> OSGi HttpService.
What is the process for evolving the OSGi HttpService? I imagine the
goal is to be 100% portable with Servlet code originally written for
traditional J2EE containers. Is this correct?
> In terms of what "could" be added easily I think filters and listeners
> are good candidates. I suspect most of the other more static declarative
> elements might be very hard to add though.
Filters and listeners would definitely be useful additions to the
current extension point. However, switching to a standard web.xml
syntax would be preferable over inventing something else.
Which static declarative elements are you referring to?
>> currently no support for on-demand compilation. However,
>> pre-compilation is tied to a specified vendor implementation, because
>> the translated Java code extends a vendor-specific class. Are there
>> any plans to leverage the host container JSP Runtime to support
>> on-demand JSP compilation for OSGi bundles?
> For the reasons you mention (and more) I don't think leveraging the host
> containers JSP runtime is feasible. I'd really like to see if we can't
> house the runtime and compilation directly inside the OSGi framework. On
> this one issue I could really use some help both for design and the
> actual coding.
Hmmm, interesting. If we house the JSP runtime inside the OSGi
framework, and then deploy the whole thing as a traditional J2EE Web
application, would we have two Web containers running one inside the other?
If we try to let the host JSP Runtime take control of compilation, does
that introduce ClassLoader issues due to a lack of visibility from the
host Web application into the relevant OSGi Web plugin?
Kind Regards,
John Fallows.
Re: general purpose server-side OSGi [message #61592 is a reply to message #61470] |
Wed, 15 February 2006 09:25   |
/osgi,
> >> OSGi
this
> >> scenario?
> "/osgi-servlet"?
Ok. Yes what you desribe sounds correct. This is the behaviour that is on
the HEAD.
Originally, the servlet path was not taken into consideration.
I'm not sure I understand the question.
The OSGi HttpService allows you to pass in initparams for each Servlet so
gives per bundle isolation of configuration at this level.
In addition HttpContexts provide similar scoping as individual Servlet
Contexts.
I think I agree ;)
> > OSGi HttpService.
I think the process for evolving the HttpService (if that's the right
approach) is to work with the OSGi. I think it's fair game to experiment in
the incubator and see if we can't provide some good ideas and use cases.
For the short term I'd like to be as closely aligned with OSGi HttpService
as possible.
In the future I'd like to move something resembling a java-binding of
web.xml for the service and similar for extensions.
A short list from older analysis...
ServletContext Config
Session Config
Welcome files
Error Page
JNDI integration
JSP Config
Mimetype Mappings
Security - I'd be interested in any thoughts on making this dynamic but at
least for now I think this would be tough and container dependent.
> > actual coding.
other?
I think that's the danger -- slippery slope.
As much as possible I'd like to leverage the appserver so that the servlet
bridge remains a "bridge" and not a full web container.
If we can leverge the JSP runtime of the appserver all the better however I
suspect this is difficult.
Exactly the problem.
> Kind Regards,
> John Fallows.
Re: general purpose server-side OSGi [message #61969 is a reply to message #61781] |
Fri, 17 February 2006 05:55   |
Originally posted by: newsreader.infonoia.com
I probably would't be religous about how the JSP compiler+renderer is
implemented. Eclipse IDE has a full-blown Tomcat running in a plug-in,
to make help work, and no-one cares that it's not Jetty, Websphere, or
whatever. Let's just say we need a JSP compiler+renderer, define that as
requirement, and see what the most straightforward,
environment-independent solution is. A plus of "one" JSP
compiler-renderer bundle is that I could also use it when running
bundles in an OSGi-native container, which is the long-term vision, I
guess.
Wolfgang
>>> Web application, would we have two Web containers running one
>>> inside the other?
> We solved such an issue with a solution everybody refers to as the
> Tomcat Mess. It's a Tomcat running inside Tomcat/WebSphere/WebLogic.
> It's ugly.
>> servlet bridge remains a "bridge" and not a full web container. If we
> We have OS specific fragments in Eclipse so why not having application
> server specific fragments?
> Cu, Gunnar
Re: general purpose server-side OSGi [message #61992 is a reply to message #61969] |
Fri, 17 February 2006 07:13   |
In a typical JSP Container all jsp requests (*.jsp) are mapped to a
JspServlet. This servlet is really just a mini container that handles
all JSP requests, translating them when required and then directing the
request to the generated JSPServletWrapper.
The most generic JSP Container that I am aware of is Jasper which is
used in Tomcat (and Jetty I think). It should be possible to create a
Jasper Bundle that provides a servlet extension point for mapping
(*.jsp). As the Jasper JspServlet (org.apache.jasper.servlet.JspServlet)
expects to find the jsp source files on disk it would have to be
extended or replaced with one that has access to the extension registry
and is able to pull the jsp source files out of the bundles that have
specified them. It should also be possible for this Jasper Bundle to
provide other services such as JSP precompiling and validation etc.
Another potential issue would be the actual compiling of the generated
JSP servlet class. Using the standard jdk compiler found in tools.jar
would be problematic as it expects to receive a set of absolute
classpath entries. In the OSGi world access to the classpaths provided
by the bundles classloader would be pretty hard to do. However, Jasper
does support the use of the Eclipse JDT compiler which is far less
restrictive on the classpaths it expects (In fact it uses the
WebApplications classloader to get access to dependent classes instead
of using real classpaths).
Richard
> guess.
> Wolfgang
>>>> inside the other?
>> It's ugly.
>> Cu, Gunnar
Re: general purpose server-side OSGi [message #62246 is a reply to message #61322] |
Sun, 19 February 2006 16:08   |
> actual coding.
I have started some experimentation with jasper, since it now compiles
using the jdt compiler and doesn't need ant / javac. (Excellent
suggestion by Richard Backhouse, and yes, it is used by both Tomcat and
Jetty.)
The Jasper servlet accesses JSP files and tag library descriptors
through the ServletContext.getResourceAsStream method which in the OSGi
HttpService uses the HttpContext provided when the servlet got
registered. The default HttpContext uses bundle.getResource() to obtain
the resource, which in turn calls getResource() on the bundle's classloader.
If the jasper bundle simply imports everything using some variation of
the "DynamicImport-Package: *" header, the JspServlet can be used
unchanged with only minimal code in the BundleActivator. (I have a
working prototype of this).
As an alternative, a specialized HttpContext could be provided that
checks that the requested resource ends in ".jsp" (or ".jspx" or ".tld").
The special HttpContext would also remove the servlet path from the
resource name (jasper appends servletPath and pathInfo to get the
complete path of the jsp file). The bridge servlet and the native OSGi
HttpService seem to have some differences here that would make it harder
to write bundles that work with both kinds of HttpService without the
prefix adjusting.
For discovery of tag libraries and tag files (I assume, haven't really
checked the specs) it would be necessary to implement
ServiceContext.getResourcePaths() -- but that means we need support from
the bridge servlet or HttpService implementation. So I'd rather leave
that out and tolerate having to put tag library descriptors somewhere on
the classpath.
For JSP registration, it should be possible to make the HttpContext
implementation use some JSP-registration services or extension points,
but I haven't done any work on that.
Interested?
Harald
Re: general purpose server-side OSGi [message #62528 is a reply to message #62509] |
Wed, 22 February 2006 18:46  |
> Cool Jasper Bundle!
> I'll try it out with our RSP demo app.
Thanks!
See my other post for limitations of ServletContext.getRequestDispatcher
-- but I think in RSP forwarding should work.
And one other thing: remember to export the packages containing the JSP
pages from your bundle (or the JasperBundle won't be able to access them).
Harald
Current Time: Mon Sep 01 00:29:42 EDT 2025
Powered by FUDForum. Page generated in 0.05770 seconds
