Home » General (non-technical) » Eclipse Foundation » Breakpoint triggers text editor
Breakpoint triggers text editor [message #5427] Mon, 18 October 2004 12:04 Go to next message
Originally posted by: szekela.towers.com
I've upgraded to Eclipse 3.0. I have a problem when I hit a breakpoint.
When Eclipse hits the breakpoint it brings up the java editor (it shows
the class name with the ".java" extenstion on the tab) instead of the
class editor. The breakpoint points to a class that is located within a
jar. The jar has both the source and the compiled version of the class.
The prior version of Eclipse (2.1) did not have this behavior.
Re: Breakpoint triggers text editor [message #5482 is a reply to message #5427] Wed, 20 October 2004 09:53 Go to previous message
I found the problem. I was using external jars in my project. As soon I
restructure my workspace/project an put the jar inside the project, it all
worked fine.
Previous Topic:Color coding the source file
Next Topic:BreakpointValidationException whenever attempting to set breakpoint
Current Time: Fri Jul 04 20:08:03 EDT 2025
Powered by FUDForum. Page generated in 0.03446 seconds
