Home » Archived » BIRT » Binding a Data Set Parameter to Report Parameter Not Working
Binding a Data Set Parameter to Report Parameter Not Working [message #60898] Thu, 21 July 2005 23:28 Go to next message
Originally posted by: attley.gmail.com
Hi folks,
Has anyone had any luck binding a dataset parameter to a report parameter.
I have followed the documentation to a t but no luck. Basically I enter a
value in the dialog window (report param value) but this value never makes
it into my query for some reason?
Can anyone help, I noticed that one user said that this functionality was
buggy. I'm hoping this can work somehow, any ideas?
Simon
Re: Binding a Data Set Parameter to Report Parameter Not Working [message #61092 is a reply to message #60898] Fri, 22 July 2005 08:39 Go to previous messageGo to next message
Greeting,
The bug has been filed as [Bugzilla]93780. If you'd like to follow the
status of the bug or give some suggestions, please take a look at this
bugzilla entry:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=93780
Cheers.
Nina
Re: Binding a Data Set Parameter to Report Parameter Not Working [message #61212 is a reply to message #61092] Fri, 22 July 2005 13:35 Go to previous messageGo to next message
Thanks Nina.
I actually managed to get it working. My dataset parameters are:
Data Type: Integer
Default Value: 0
Allows Null: No
Optional: No
My corresponding report parameters are:
Data Type: Float
Formatting: Custom, fixed number #0
This works from eclipse when I run it in BIRT Web Viewer. And the params
are entered through the left frame in the viewer. I haven't tried passing
the params in URL string from my webpage yet though.
simon
Re: Binding a Data Set Parameter to Report Parameter Not Working [message #69367 is a reply to message #61212] Tue, 23 August 2005 15:35 Go to previous messageGo to next message
Originally posted by: John.xxxx.com
Hey guys,
i have the similar problem and here are the parameters i created
ParamMonth which is data/time datatype and in the Report table it is also
date/time but from the front end user it will come as "MAY". I dont
understand which default value to give.i tried '%' , ' MMM', 'MMM/yy', as
per my requirement.
-John
Simon Attley wrote:
> Thanks Nina.
> Data Type: Integer
> Default Value: 0
> Allows Null: No
> Optional: No
> Data Type: Float
> simon
Re: Binding a Data Set Parameter to Report Parameter Not Working [message #72157 is a reply to message #69367] Mon, 05 September 2005 19:12 Go to previous message
Please respond.
-John
John wrote:
> Hey guys,
> per my requirement.
> -John
> Simon Attley wrote:
>> Thanks Nina.
>> Data Type: Integer
>> Default Value: 0
>> Allows Null: No
>> Optional: No
>> Data Type: Float
>> simon
Previous Topic:sending a report parameter as an argument to a function
Next Topic:I have install JDBC for Oracle but....!!!
Current Time: Sun Jul 13 12:50:15 EDT 2025
Powered by FUDForum. Page generated in 0.03563 seconds
