AGR Not able to playback on tables [message #60897] |
Tue, 28 March 2006 05:07  |
Originally posted by: mvjaibharatreddy.yahoo.com
Greetings,
I am evaluating AGR to automate testing on our plug-in. I have noticed that
AGR is not able to playback the actions (editing the content in the rows) in
the tables.
When recording the scenario it is able to identify the table and roweditor
as text field. but it is failing to playback ( Cannot locate the editor
control: org.eclipse.swt.widgets.Text#1)..
Please find the macro as a attachment, which was generated for the following
scenario: opening a tptp.datapool, editing a filed at row: 5.
Can any one provide me workaround solution for this. ( Apart from position
based recording)
Thanks for any insight.
Jai
Re: AGR Not able to playback on tables [message #61809 is a reply to message #61309] |
Wed, 29 March 2006 05:27  |
Hi ali,
Thank you for the reply and suggestion.
Cheers
Jai
"Ali Mehregani" <amehrega@ca.ibm.com> wrote in message
news:e0bp2a$ub8$1@utils.eclipse.org...
>I have opened defect https://bugs.eclipse.org/bugs/show_bug.cgi?id=133586
>to
> attempt to address this problem. A workaround really depends on your
> application. If your plug-in provides another mean of editing the row
> (e.g.
> via an edit button), then try and use that instead.
> The defect has been targeted for 4.2i3 and should be resolved within a few
> weeks.
> "Jai9999" <mvjaibharatreddy@yahoo.com> wrote in message
> news:e0b1t6$2s3$1@utils.eclipse.org...
>> Greetings,
> that
> in
>> the tables.
>> roweditor
> following
>> position
>> based recording)
>> Jai
FUDForum. Page generated in 0.04434 seconds
