Home » Modeling » OCL » Calling methods with enum-parameter
Calling methods with enum-parameter [message #60875] Wed, 20 August 2008 01:48 Go to next message
Hi...
if I define an operation on a class in my ecore-model and give this an
enum-parameter I can't call it from an OCL-expression due to the following
exception:
> java.lang.IllegalArgumentException: argument type mismatch
> at
> org.eclipse.ocl.AbstractEvaluationEnvironment.callOperation( AbstractEvaluationEnvironment.java:185)
> at
> org.eclipse.ocl.ecore.EcoreEvaluationEnvironment.callOperati on(EcoreEvaluationEnvironment.java:85)
> at
> org.eclipse.ocl.ecore.EcoreEvaluationEnvironment.callOperati on(EcoreEvaluationEnvironment.java:1)
> at
> org.eclipse.ocl.internal.evaluation.EvaluationVisitorImpl.vi sitOperationCallExp(EvaluationVisitorImpl.java:172)
> at
> org.eclipse.ocl.ecore.impl.OperationCallExpImpl.accept(Opera tionCallExpImpl.java:336)
> at
> org.eclipse.ocl.AbstractEvaluationVisitor.visitExpression(Ab stractEvaluationVisitor.java:223)
> at
> org.eclipse.ocl.internal.evaluation.QueryImpl.evaluate(Query Impl.java:120)
This exception is caused because you call the java-method with an
EEnumLiteral as parameter, but the enum-type is expected.
Steps for reproduction:
1. Use the following Ecore-model:
<ecore:EPackage xmi:version="2.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="test"
nsURI="test" nsPrefix="test">
<eClassifiers xsi:type="ecore:EClass" name="Clazz">
<eOperations name="foo">
<eParameters name="param" eType="#//TestEnum"/>
</eOperations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EEnum" name="TestEnum">
<eLiterals name="TestLiteral"/>
</eClassifiers>
</ecore:EPackage>
2. Generate the model-, edit- and editorcode. You not even have to implement
the generated method.
3. Start a new Eclipse-instance with the generated plugins.
4. Create a new Test Model.
5. Call the expression "foo(TestEnum::TestLiteral)" on the Clazz in the
Interactive OCL Interpreter.
If you change the method in the model to accept an JavaObject-parameter and
set an breakpoint in the generaetd method, you can see that an EEnumLiteral
is passed to the method.
I only tried this on OCL 1.1.2 because I don't have 1.2.x with all the
dependencies. Is it probably already fixed in 1.2.x? I couldn't find an
issue in BugZilla.
Stefan
Re: Calling methods with enum-parameter [message #60913 is a reply to message #60875] Wed, 20 August 2008 08:03 Go to previous messageGo to next message
Originally posted by: cdamus.zeligsoft.com
Hi, Stefan,
I doubt that this is fixed in the 1.2 release. I would very much like
to fix it for 1.2.2; would you mind raising a bug?
Thanks!
Stefan Schulze wrote:
> Hi...
> exception:
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
> xmlns:xmi="http://www.omg.org/XMI"
> </eOperations>
> </eClassifiers>
> </eClassifiers>
> </ecore:EPackage>
> issue in BugZilla.
> Stefan
Re: Calling methods with enum-parameter [message #61031 is a reply to message #60913] Wed, 20 August 2008 17:52 Go to previous message
Hi Christian,
I raised https://bugs.eclipse.org/bugs/show_bug.cgi?id=244755.
Stefan
Previous Topic:Re: downloading MDT-OCLTools
Next Topic:..*-associations should be Set by default?
Current Time: Sat Jul 26 16:01:09 EDT 2025
Powered by FUDForum. Page generated in 0.02755 seconds
