Home » Archived » Visual Editor (VE) » Visualizing code in the Design view doesn't work
Visualizing code in the Design view doesn't work [message #60870] |
Sat, 25 September 2004 22:58  |
Originally posted by: gpawel.gmail.com
Hi All.
I can create visual class using Designer without problems, but
when I am trying to "open with" Visual Editor the created class, Designer
area is empty, no properties shown, no "gui" etc.
Any ideas?
Here are my environment:
Window 2000;
Eclipse 3.01 Build id: 200409161125;
Installed all required components with VE 1.0 (date Sept. 25, 2004)
Thanks a lot.
Pavel
Re: Visualizing code in the Design view doesn't work [message #60883 is a reply to message #60870] |
Sat, 25 September 2004 23:29   |
Originally posted by: thill.t-hill.net
Yup. Same here. I had it working earlier today, but I was prompted to
download updates (several times) and now I have not visual of the class--no
properties nor javabeans views either.
Here's the latest additions to the .log file:
!SESSION Sep 25, 2004
22:24:13.254 ---------------------------------------------
eclipse.buildId=unknown
java.version=1.4.2_04
!ENTRY org.eclipse.ve.java.core 4 0 Sep 25, 2004 22:24:13.284
!MESSAGE Exception thrown.
!STACK 0
java.lang.ClassCastException
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.createJavaIns
tances(JavaSourceTranslator.java:705)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.buildComposit
ionModel(JavaSourceTranslator.java:774)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocumen
t(JavaSourceTranslator.java:881)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(Jav
aSourceTranslator.java:656)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.r
un(JavaVisualEditorPart.java:1444)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
!STACK 0
"Pavel" <gpawel@gmail.com> wrote in message news:cj5as4$p1t$1@eclipse.org...
> Hi All.
> Any ideas?
> Window 2000;
> Thanks a lot.
> Pavel
Re: Visualizing code in the Design view doesn't work [message #60896 is a reply to message #60883] |
Sun, 26 September 2004 00:19   |
Originally posted by: myersj.nospam.gmail.com
Try running eclipse with the -clean command line option to see if that
helps.
- Jeff
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 0
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
>>Hi All.
>>Any ideas?
>>Window 2000;
>>Thanks a lot.
>>Pavel
Re: Visualizing code in the Design view doesn't work [message #60991 is a reply to message #60896] |
Sun, 26 September 2004 03:37   |
Originally posted by: ram_No.Spam_fieldlinx.com
HI!
I am facing the same problem here, I have tried number of times using
-clean option but no luck.
Please read my post "Strange Errors with Swing on VE 1.0.1"
I am sure there is something wrong somewhere.
Ram.
> helps.
> - Jeff
>> class--no
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>>> Hi All.
>>> Designer
>>> Any ideas?
>>> Window 2000;
>>> Thanks a lot.
>>> Pavel
Re: Visualizing code in the Design view doesn't work [message #61036 is a reply to message #60870] |
Sun, 26 September 2004 08:02   |
Originally posted by: rene.aldershof.freeler.nl
Hi All,
Yup, same problem I encountered. On Windows 98 SE, Eclipse 3.01. Installed
GEF, VE and Swing by means of the Eclipse build in Update Manager.
Reconstruction: create a new visual class, bring in some Swing components
by means of the Visual Editor, do save all, exit Eclipse. Then start
Eclipse IDE again and open again your visual class. Result: no Swing
components available in the canvas of Visual Editor. Source code is OK.
Greetings,
Rene
Pavel wrote:
> Hi All.
> Any ideas?
> Window 2000;
> Thanks a lot.
> Pavel
Re: Visualizing code in the Design view doesn't work [message #599364 is a reply to message #60870] |
!STACK 0
!STACK 0
> Hi All.
> Any ideas?
> Window 2000;
> Thanks a lot.
> Pavel
Re: Visualizing code in the Design view doesn't work [message #599377 is a reply to message #60883] |
helps.
- Jeff
> !STACK 0
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
>>Hi All.
>>Any ideas?
>>Window 2000;
>>Thanks a lot.
>>Pavel
Re: Visualizing code in the Design view doesn't work [message #599443 is a reply to message #60896] |
HI!
Ram.
> helps.
> - Jeff
>> class--no
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>>> Hi All.
>>> Designer
>>> Any ideas?
>>> Window 2000;
>>> Thanks a lot.
>>> Pavel
Re: Visualizing code in the Design view doesn't work [message #599458 is a reply to message #60870] |
Hi All,
Greetings,
Rene
Pavel wrote:
> Hi All.
> Any ideas?
> Window 2000;
> Thanks a lot.
> Pavel
Re: Visualizing code in the Design view doesn't work [message #599470 is a reply to message #60870] |
Sun, 26 September 2004 09:08  |
eclipse -clean didn't help.
> Hi All.
> Any ideas?
> Window 2000;
> Thanks a lot.
> Pavel
Re: Visualizing code in the Design view doesn't work [message #599503 is a reply to message #60896] |
Sun, 26 September 2004 12:18  |
"Jeff Myers" <myersj@nospam.gmail.com> wrote in message
news:cj5fo8$taq$1@eclipse.org...
BTW, I have noticed that -clean only seems to work for *some* configuration
/ plugin info caching issues. Sometimes, deleting the Eclipse
"configuration" directory (it is recreated at startup) seems to work better.
It has gotten to the point that any time I have a problem getting a newly
installed plugin working in Eclipse 3.0, deleting the "configuration"
directory is one of the first things I try. I don't know whether it would
have any effect on the problem mentioned in this thread.
-Eric
Re: Visualizing code in the Design view doesn't work [message #599512 is a reply to message #61153] |
Sun, 26 September 2004 12:54  |
Thanks, Eric --
I tried that, but it seemed to remove all knowledge of the VE from the
IDE--Visual Editor was not selectable at all, not even for new classes.
"Eric Clayberg" <clayberg@instantiations.com> wrote in message
news:cj6pt8$dsc$1@eclipse.org...
configuration
better.
> -Eric
Re: Visualizing code in the Design view doesn't work [message #599538 is a reply to message #61177] |
Sun, 26 September 2004 22:11  |
Hi!
I did try that myself, it does not seem to be working either.
Ram.
Todd Hill wrote:
> Thanks, Eric --
> configuration
> better.
>>-Eric
Re: Visualizing code in the Design view doesn't work [message #599746 is a reply to message #60883] |
Mon, 27 September 2004 17:31  |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
If you are getting this exception, please unload the EMF examples. It
conflicts with the VE. We have an open bugzilla (#71473) to fix this.
> at
Rich
Re: Visualizing code in the Design view doesn't work [message #599789 is a reply to message #61825] |
Mon, 27 September 2004 18:03  |
Thank you.
It's working just fine now.
By the way, how do uninstall:
Visual Editor 1.0.0 and Visual Editor SDK 2.1.2? I have them disabled under
as the Production Configuration dialog show, but there is no 'uninstall'
option for them as there is for others.
"Rich Kulp" <richkulp@us.NO_SPAM.ibm.com> wrote in message
news:cja0i3$ccc$1@eclipse.org...
> > at
> Rich
Re: Visualizing code in the Design view doesn't work [message #599810 is a reply to message #61825] |
Mon, 27 September 2004 19:55  |
This is working for me as well!!
Thanks a lot !!!
Pavel
> > at
> Rich
Re: Visualizing code in the Design view doesn't work [message #599845 is a reply to message #60870] |
Mon, 27 September 2004 22:30  |
I have the same issue. I tried the suggestion someone had of removing EMF
examples but that didn't help.
I can create a Visual Class of any kind and it just never shows a UI in
the design pane.
Vince
Pavel wrote:
> Hi All.
> Any ideas?
> Window 2000;
> Thanks a lot.
> Pavel
Re: Visualizing code in the Design view doesn't work [message #599934 is a reply to message #61966] |
Tue, 28 September 2004 15:38  |
Todd Hill wrote:
> Thank you.
If they weren't installed using the update manager, then you need to
physically and manually delete them from the disk and then start once
with the -clean option. The update manager only allows you to uninstall
ones that were installed through the update manager.
Rich
Current Time: Mon Jul 21 21:19:35 EDT 2025
Powered by FUDForum. Page generated in 0.08005 seconds
