Home » Language IDEs » AspectJ » AJCompilationUnit question.
AJCompilationUnit question. [message #60863] Thu, 12 January 2006 02:54 Go to next message
Originally posted by: zifu.yang.gmail.com
I called getAJCompilationUnit(IFile file) in AJCompilationUnitManager to
get a compilation unit.
Then called ajcompilationUnit.getBuffer().getContents() to get the contents
of this unit. However, in this contents, the keyword "aspect" was changed
to "class" silently. Is this a bug?
Re: AJCompilationUnit question. [message #60886 is a reply to message #60863] Thu, 12 January 2006 04:18 Go to previous message
No, it's working as designed, for the current implementation. The
AJCompilationUnit is "pretending" to have Java syntax, so that JDT does
not get (too) confused by its existence.
However, once you know it's an AJCompilationUnit, there is a call you can
make to obtain the real contents, but you must return it to compatible
mode afterwards. Here's an example:
AJCompilationUnit cu =
AJCompilationUnitManager.INSTANCE.getAJCompilationUnit(file) ;
cu.requestOriginalContentMode();
String contents = cu.getBuffer().getContents();
cu.discardOriginalContentMode();
Hope that helps,
Matt.
(btw the developer's mailing list is also a good place for questions like
this: http://dev.eclipse.org/mailman/listinfo/ajdt-dev)
Re: AJCompilationUnit question. [message #591800 is a reply to message #60863] Thu, 12 January 2006 04:18 Go to previous message
Hope that helps,
Matt.
Previous Topic:AJCompilationUnit question.
Next Topic:AspectJ/Java Editor does not work
Current Time: Fri Jul 18 07:31:48 EDT 2025
Powered by FUDForum. Page generated in 0.07575 seconds
