Re: Papyrus 1.12: Does OCL validation on models really work? [message #601977 is a reply to message #601974] |
Wed, 12 May 2010 09:28 |
Hi Shaman,
there is a confusion. What you downloaded is Papyrus UML, an open source
solution based on Eclipse but not hosted by the Eclipse foundation.
You can submit bugs directly on the website:
http://www.papyrusuml.org/scripts/home/publigen/content/temp lates/show.asp?P=120&L=EN&ITEMID=35
This forum is dedicated to Eclipse MDT Papyrus component, which can be
considered as the new generation of Papyrus UML and integrates with
other initiatives coming from TOPCASED UML and Moskitt.
The first public release is expected for July 14th? Before you can find
information about how to download the code from SVN here :
http://wiki.eclipse.org/Papyrus_Developer_Guide
Hope things are clear now
regards
raphaël
Shaman_Mahmoudi a écrit :
> I have downloaded and installed Papyrus 1.12. I am following the OCL
> constraint tutorial, and I can not validate my stereotypes against OCL
> constraints I have defined. It says validation succesful even when that
> is not the case. Does not matter in what context the classifier is, be
> it M1 or M2. It's as if the validation is not performed at all. What
> happened? Why it not workiing? Plan to updat 1.12 to a working one? Or
> do we need to wait for version 2 of the tool?
> By the way, how did you solve the issue of which classifier (stereotype
> vs stereotype meta-class) to use in the context when validating against
> OCL constraints?
> Thanks in advance.
Re: Papyrus 1.12: Does OCL validation on models really work? [message #601983 is a reply to message #601977] |
Wed, 12 May 2010 10:02 |
Shaman_Mahmoudi Messages: 16 Registered: February 2010 |
Junior Member |
Hi Rafael,
Thanks a lot for the information! Now everything makes sense! That other project looked abandoned considering documents did not align with what the product offered and no word about progress.
I believe I am more interested in the Papyrus MDT component, and I have taken a look at the source code, in particular OCL validation. If it is ok, I want to ask a question regarding it.
I have read and tried that piece od code, and there is one issue that is confusing me. In order to validate against an OCL constraint, you need to set the classifier context and then do the validation. In the code, the validation is allways done on M1 level it seems. If the OCL constraint as a method (example self.allOwnedElements()) or attribute defined in the UML meta model, then the context is on M2. With the current code, you'll get an exception if you try to do validate against such a constraint. An easy but maybe not elegant solution is to first try to create the invariant on M1 level, if fails, try in M2 level. How are you solving this issue? i.e. how to know in what context the constraint is defined in.
Thanks in advance!
Re: Papyrus 1.12: Does OCL validation on models really work? [message #602123 is a reply to message #601983] |
Fri, 25 June 2010 12:46 |
Ed Willink Messages: 7655 Registered: July 2009 |
Hi Shaman
I'm not familiar with Papyrus; I first downloaded it an hour ago. But I
am very interested in smoothing off the rough edges that make use of OCL
much harder than it should be.
It would be very helpful to see how you are trying to use Papyrus and to
have a newbie-oriented description of the problems you are encountering.
Ed Willink (MDT/OCL committer)
On 12/05/2010 11:02, Shaman_Mahmoudi wrote:
> Hi Rafael,
> Thanks in advance!
FUDForum. Page generated in 0.03319 seconds
