Home » Eclipse Projects » Nebula » Gallery: no SelectionEvent when selection becomes empty
Gallery: no SelectionEvent when selection becomes empty [message #60833] |
Wed, 19 November 2008 13:30  |
I noticed that some of my actions weren't getting disabled when the
gallery selection became empty - ie something was selected, then click on
a blank group area, now nothing selected.
Turns out that no SeletionEvent is fired by the Gallery in this situation.
I've made a simple change to onMouseDown() which does the trick for me, to
just call notifySelectionListeners with a null GalleryItem.
void onMouseDown(MouseEvent e) {
if (DEBUG)
System.out.println("Mouse down "); //$NON-NLS-1$
mouseClickHandled = false;
if (!_mouseDown(e)) {
mouseClickHandled = true;
return;
GalleryItem item = getItem(new Point(e.x, e.y));
if (e.button == 1) {
if (item == null) {
_deselectAll();
redraw();
lastSingleClick = null;
>>> ADD notifySelectionListeners(null, -1, false) here!!!!!!!
} else {
Justin
Re: Gallery: no SelectionEvent when selection becomes empty [message #60843 is a reply to message #60833] |
Fri, 21 November 2008 08:33   |
Hi Justin,
This one may already be fixed on the latest version (CVS).
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=228590)
Note that the nighlty build are currently broken and the version you can
download from the eclipse website is outdated.
Are you seeing this behavior with the CVS head version ?
Nicolas
Justin a écrit :
> on a blank group area, now nothing selected.
> to just call notifySelectionListeners with a null GalleryItem.
> if (DEBUG)
> return;
> if (item == null) {
> _deselectAll();
> redraw();
> } else {
> Justin
Re: Gallery: no SelectionEvent when selection becomes empty [message #60872 is a reply to message #60843] |
Wed, 26 November 2008 03:20  |
Hi Nicolas,
Yes, I'm using the head on CVS, and this does appear to be broken I'm
afraid. I used SimpleSnippet to test with DefaultGalleryGroupRenderer and
NoGroupRenderer (as mentioned in that bug). A SelectionListener added to
the Gallery receives no events on deselection.
Justin
Nicolas Richeton wrote:
> Hi Justin,
> Nicolas
> Justin a écrit :
>> if (DEBUG)
>> return;
>> if (item == null) {
>> _deselectAll();
>> redraw();
>> } else {
>> Regards,
>> Justin
Re: Gallery: no SelectionEvent when selection becomes empty [message #592779 is a reply to message #60833] |
Hi Justin,
Nicolas
Justin a écrit :
> if (DEBUG)
> return;
> if (item == null) {
> _deselectAll();
> redraw();
> } else {
> Justin
Re: Gallery: no SelectionEvent when selection becomes empty [message #592813 is a reply to message #60843] |
Hi Nicolas,
Justin
> Hi Justin,
> Nicolas
> Justin a écrit :
>> if (DEBUG)
>> return;
>> if (item == null) {
>> _deselectAll();
>> redraw();
>> } else {
>> Regards,
>> Justin
Current Time: Thu Jul 17 20:19:58 EDT 2025
Powered by FUDForum. Page generated in 0.07871 seconds
