Home » Newcomers » Newcomers » example plugin
example plugin [message #60804] Thu, 05 May 2005 01:57 Go to next message
Originally posted by: dangallery.seanet.com
I'm sure i'm blind, but i cannot find the location for downloading SWT
examples plug-in. Can someone please help?
Re: example plugin [message #60805 is a reply to message #60804] Thu, 05 May 2005 02:04 Go to previous messageGo to next message
Originally posted by: newsgroups.pellaton.li
IMHO the easiest way to get the examples is pulling them from CVS:
- change to the "CVS Repository Exploring" perspective
- Add a new Repository Location by right clicking in the CVS
Repositories view
- Data needed:
- Connection type: pserver
- User: anonymous
- Host: dev.eclipse.org
- Repository path: /home/eclipse
- Now open the repository (HEAD) and look forthe exmaple you want
- right click on the example project you would like to have and select
"Check Out" or "Check out as..." (if you want it to have another name
in your workspace.
(if you don't want the latest development version of the exmaples, open
"Versions" instead and check out the desired version)
Hope this helps
Michael Pellaton
Re: example plugin [message #60806 is a reply to message #60804] Thu, 05 May 2005 03:12 Go to previous messageGo to next message
Originally posted by: hcs33.egon.gyaloglo.hu
In the download page search for 'Example Plug-ins'. Afaik those contains the
SWT examples as well.
HTH,
Csaba
Re: example plugin [message #60827 is a reply to message #60805] Thu, 05 May 2005 20:46 Go to previous messageGo to next message
Originally posted by: dgallery.accessor.com
Hi Michael, thanks for the tip. That would be ideal, as i could see the
whole repository. unfortunately i'm getting 'Cannot connect to host' when
connecting to the repository.
i'm going thru a proxy connection (firewall), which i've configured under
preferences. i know that is working, becuz i was able to 'Find and
Install', and update the latest version, 3.02, from the eclipse site.
please excuse my ignorance, i'm fairly new to eclipse. is a password
required for the connection? I tried blank, and my newsgroup password,
both failed. no doubt something simple
thanks much for your time.
dan gallery
Re: example plugin [message #60837 is a reply to message #60806] Thu, 05 May 2005 20:52 Go to previous messageGo to next message
Hi Csaba, thanks for the response. i tried what you said, and can find no
search option on the downloads page. i used the seach option from the
eclipse home page, got some links to newsgroup posts requesting the same
thing, such as:
http://download.eclipse.org/downloads/drops/S-M5-20030206170 0/download.php?dropFile=eclipse-examples-M5.zip)
and
http://download.eclipse.org/downloads/drops/S-M5-20030206170 0/index.php
but got 404's on both links.
dan gallery
Re: example plugin [message #60850 is a reply to message #60827] Fri, 06 May 2005 00:38 Go to previous messageGo to next message
Make sure the port 2401 is open (from inside your network to the
internet).
Hope this helps
Michael
> dan gallery
Re: example plugin [message #60895 is a reply to message #60837] Fri, 06 May 2005 03:25 Go to previous messageGo to next message
For search I mean the search option in the browser itself :)
For example, if you want to download the examples for Eclipse 3.0.2, go to
its download page:
http://download.eclipse.org/eclipse/downloads/drops/R-3.0.2- 200503110845/index.php
(url may wrap), and in this page you can find an 'Examples Plug-ins' header
(with grey background).
Other (e.g 3.1 milestone builds) download pages contain this as well.
The pages you mentioned below does not exist any more (they are two years
old milestone pages).
HTH,
Csaba
> thing, such as:
> and
> dan gallery
Plug-in for javascript editor [message #60992 is a reply to message #60837] Fri, 06 May 2005 11:54 Go to previous messageGo to next message
Originally posted by: gaetano.savoca.atlantisworld.it
There are some good javascript editor for eclipse???
Re: example plugin [message #61357 is a reply to message #60895] Fri, 06 May 2005 20:11 Go to previous message
got it, thanks Csaba for your patience. i don't know how i missed it in
previous google searches, or from the main download page.
embarrassed :)
Previous Topic:Build Problem
Next Topic:Automaticly implement an Interface or a Subclass
Current Time: Thu Jul 17 22:05:30 EDT 2025
Powered by FUDForum. Page generated in 0.11073 seconds
