| Eclipse (on Linux) is slow and freezes (doesn't repaint) 2 or 3 times a day [message #60801] | Wed, 04 May 2005 21:35  |  |
| Eclipse User  |  |  |  |  | Originally posted by: matthewficken.yahoo.com
 I am using eclipse to develop a project in Java on linux (Redhat 9 and
 Sun's JDK1.4.2_05)
 I have been using eclipse 3.0.1 for 2 or 3 months but in the last couple
 of
 weeks, I've had some real problems with it (I haven't knowingly changed
 anything).
 It is frequently slow, so it takes 2 or 3 seconds for text I was typing to
 appear.
 And worse, when I switch to another window (on another desktop) and then
 switch back to eclipse, eclipse freezes. It won't repaint, so its just a
 gray background with 3 white boxes where the editor, perspective viewer
 and console where.
 Sometimes I can click where I think the File menu should be, and a blank
 menu (without border) appears. Also, when I move my mouse cursor over
 where the divider should be, between the perspective viewer and editor,
 the cursor changes to indicate that I can move the divider. I can click on
 it and resize the white boxes that have taken the place of the perspective
 viewer and editor.
 No keyboard shortcuts work.
 This happens 2 or 3 times a day.
 My only recourse has been to kill eclipse and start over, wasting 5 or 10
 minutes (eclipse does take a while to start up too).
 I really want to fix this problem becuase I don't want to have to deal
 with problems with whatever IDE I'm using, I want to work on my project.
| Re: Eclipse (on Linux) is slow and freezes (doesn't repaint) 2 or 3 times a day [message #60819 is a reply to message #60801] | Thu, 05 May 2005 13:32   |  |
| Eclipse User  |  |  |  |  | Originally posted by: jaredburns.no.spam.acm.org
 Sounds like your CPU is getting hammered. Check your CPU monitor (or
 top). Have you recently installed any new plugins in Eclipse?
 Simple question, but have you tried a clean install of Eclipse?
 > Sun's JDK1.4.2_05)
 > of weeks, I've had some real problems with it (I haven't knowingly
 > changed anything).
 > to appear.
 > and console where.
 > on it and resize the white boxes that have taken the place of the
 > perspective viewer and editor.
 > 10 minutes (eclipse does take a while to start up too).
FUDForum. Page generated in 0.07660 seconds
