Home » Newcomers » Newcomers » c/c++-project build don't run
c/c++-project build don't run [message #60783] Tue, 03 May 2005 17:31 Go to next message
Originally posted by: ng.salomon-freising.de
Hi all,
I'm new with eclipse and installed it today on may pc (eclipse 3.0.2 CDT
2.1) I create a little manged helloWorld-Project, but the Build don't
run (not with Ctrl+B and not via the menu) . Nothing happens - even no
error-message.
Has anyone a idea?!
Every help is appreciated
Werner
Re: c/c++-project build don't run [message #60788 is a reply to message #60783] Wed, 04 May 2005 02:45 Go to previous messageGo to next message
Originally posted by: nobody.tellus.org
Werner Salomon wrote:
> Hi all,
> error-message.
> Has anyone a idea?!
> Werner
Don't you get any error even in the console?
I fiured out that since I'm running on a Windows platform I
have to install MinGW C++ compiler, and after that I have
to change the default where eclipse is using make to have it
use mingw32-make instead. Then it worked for me.
Re: c/c++-project build don't run [message #60815 is a reply to message #60788] Thu, 05 May 2005 12:45 Go to previous message
>> Hi all,
>> CDT 2.1) I create a little manged helloWorld-Project, but the Build
>> don't run (not with Ctrl+B and not via the menu) . Nothing happens -
>> even no error-message.
>> Has anyone a idea?!
>> Werner
Thank You for the hint.
Yes there was an errror message in the Console as I started eclipse the
second time. The reason was, that I have no make program and even no
compiler - I don't regognized that this is not part of the CDT-package -
of course not! :-/
Now I installed MinGC 3.2 and set my PATH-Environment to MinGC/bin.
I'm following the instructions in the "CDT Standard Make Tutorial" and
now it runs. :-)
Greetings
Werner
Previous Topic:Can't I just edit a file?
Next Topic:Can't start debugger
Current Time: Sat Jul 26 09:26:03 EDT 2025
Powered by FUDForum. Page generated in 0.09018 seconds
