Home » Newcomers » Newcomers » Opening an already existing workspace
Opening an already existing workspace [message #60780] Tue, 03 May 2005 15:52 Go to next message
Originally posted by: boehmeNOSPAM.NOSPAM.eyemaginations.com
I have a workspace checked into source control (VSS) on my computer. My co-worker checked it out on his computer and was unable to open it with
Eclipse. He downloaded 3.0.2 and he has also tried with a copy of my Eclipse directory. However, when he created a new project, it worked fine. I am
running:
Version: 3.0.2
Build id: 200503110845
with the VSS plugin and the viPlugin. The viPlugin is not installed on his machine.
The error log is below.
Thanks for the help.
Richard Boehme
!SESSION Mar 18, 2005 11:52:19.804
eclipse.buildId=M200409161125
java.version=1.5.0
!ENTRY org.eclipse.ui 4 4 Mar 18, 2005 11:52:19.804
!MESSAGE Referenced part does not exist yet:
org.eclipse.ui.views.TaskList.
!SESSION Mar 21, 2005 14:16:35.446
java.version=1.5.0
!ENTRY org.eclipse.osgi Mar 21, 2005 14:16:35.446
!MESSAGE The class "org.vssplugin.core.olecommand.VSSDatabase" cannot be
loaded because the system is shutting down and the plug-in
"org.vssplugin" has already been stopped.
!STACK 0
java.lang.ClassNotFoundException: The class
"org.vssplugin.core.olecommand.VSSDatabase" cannot be loaded because the
system is shutting down and the plug-in "org.vssplugin" has already been
stopped.
org.eclipse.core.runtime.adaptor.EclipseClassLoader.shouldAc tivateFor(Ec
lipseClassLoader.java:147)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(Eclip
seClassLoader.java:62)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(Bun
dleLoader.java:371)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLo
ader.java:402)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(Ab
stractClassLoader.java:93)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
org.vssplugin.core.ExecutorThread$ExecutorFinalizer.run(Exec utorThread.j
ava:51)
org.vssplugin.core.ExecutorThread.run(ExecutorThread.java:11 0)
!SESSION Mar 23, 2005 13:40:05.490
java.version=1.5.0
!ENTRY org.eclipse.osgi Mar 23, 2005 13:40:05.490
!STACK 0
stopped.
dleLoader.java:371)
ader.java:402)
ava:51)
!SESSION Mar 23, 2005 18:25:23.705
java.version=1.5.0
!ENTRY org.eclipse.osgi Mar 23, 2005 18:25:23.705
!STACK 0
stopped.
dleLoader.java:371)
ader.java:402)
ava:51)
!SESSION Mar 28, 2005 16:02:11.41
java.version=1.5.0_02
!ENTRY org.eclipse.osgi Mar 28, 2005 16:02:11.101
!STACK 0
stopped.
dleLoader.java:371)
ader.java:402)
ava:51)
!SESSION Mar 31, 2005 15:35:33.728
!ENTRY org.eclipse.osgi Mar 31, 2005 15:35:33.728
!STACK 0
stopped.
dleLoader.java:371)
ader.java:402)
ava:51)
!SESSION Apr 01, 2005 15:52:45.851
!ENTRY org.eclipse.osgi Apr 01, 2005 15:52:45.851
!STACK 0
stopped.
dleLoader.java:371)
ader.java:402)
ava:51)
!SESSION Apr 01, 2005 17:50:03.40
!ENTRY org.eclipse.osgi Apr 01, 2005 17:50:03.40
!STACK 0
stopped.
dleLoader.java:371)
ader.java:402)
ava:51)
!SESSION Apr 04, 2005 11:21:51.560
!ENTRY org.eclipse.osgi Apr 04, 2005 11:21:51.560
!STACK 0
stopped.
dleLoader.java:371)
ader.java:402)
ava:51)
!SESSION Apr 04, 2005 18:45:12.450
!ENTRY org.eclipse.osgi Apr 04, 2005 18:45:12.450
!STACK 0
stopped.
dleLoader.java:371)
ader.java:402)
ava:51)
!SESSION Apr 07, 2005 15:07:55.108
!ENTRY org.eclipse.debug.ui 4 120 Apr 07, 2005 15:07:55.108
!MESSAGE Variable references non-existent resource :
${workspace_loc:run}
!ENTRY org.eclipse.osgi Apr 07, 2005 18:36:54.408
!STACK 0
stopped.
dleLoader.java:371)
ader.java:402)
ava:51)
!SESSION Apr 08, 2005 18:17:25.132
!ENTRY org.eclipse.osgi Apr 08, 2005 18:17:25.132
!STACK 0
stopped.
dleLoader.java:371)
ader.java:402)
ava:51)
!SESSION Apr 19, 2005 13:20:03.75
!ENTRY org.eclipse.osgi Apr 19, 2005 13:20:03.75
!STACK 0
stopped.
dleLoader.java:371)
ader.java:402)
ava:51)
!SESSION Apr 19, 2005 15:01:57.787
!ENTRY org.eclipse.ltk.ui.refactoring 4 10000 Apr 19, 2005 15:01:57.787
!MESSAGE Internal Error
!STACK 1
org.eclipse.core.runtime.CoreException: Problems encountered while
deleting resources.
org.eclipse.ltk.internal.ui.refactoring.UIPerformChangeOpera tion.execute
Change(UIPerformChangeOperation.java:80)
org.eclipse.ltk.core.refactoring.PerformChangeOperation.run( PerformChang
eOperation.java:191)
org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1673)
org.eclipse.ltk.internal.ui.refactoring.WorkbenchRunnableAda pter.run(Wor
kbenchRunnableAdapter.java:58)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalCon
text.java:101)
!SUBENTRY 1 org.eclipse.core.resources 4 4 Apr 19, 2005 15:01:57.787
!MESSAGE Problems encountered while deleting resources.
!SUBENTRY 2 org.eclipse.core.resources 4 273 Apr 19, 2005 15:01:57.787
!MESSAGE Could not delete: d:\data\working\Software\EM
Java\EclipseWorkspace\EM Class Driver\run\emx.log.
!ENTRY org.eclipse.core.resources 4 4 Apr 19, 2005 15:01:57.787
!SUBENTRY 1 org.eclipse.core.resources 4 273 Apr 19, 2005 15:01:57.787
!ENTRY org.eclipse.ltk.ui.refactoring 4 10000 Apr 19, 2005 15:02:17.726
!STACK 1
deleting resources.
text.java:101)
!SUBENTRY 1 org.eclipse.core.resources 4 4 Apr 19, 2005 15:02:17.726
!SUBENTRY 2 org.eclipse.core.resources 4 273 Apr 19, 2005 15:02:17.726
!ENTRY org.eclipse.core.resources 4 4 Apr 19, 2005 15:02:17.726
!SUBENTRY 1 org.eclipse.core.resources 4 273 Apr 19, 2005 15:02:17.726
!ENTRY org.eclipse.osgi Apr 19, 2005 16:19:47.472
!STACK 0
stopped.
dleLoader.java:371)
ader.java:402)
ava:51)
!SESSION Apr 19, 2005 18:10:45.846
!ENTRY org.eclipse.osgi Apr 19, 2005 18:10:45.846
!STACK 0
stopped.
dleLoader.java:371)
ader.java:402)
ava:51)
!SESSION Apr 20, 2005 15:25:05.776
!ENTRY org.eclipse.osgi Apr 20, 2005 15:25:05.776
!STACK 0
stopped.
dleLoader.java:371)
ader.java:402)
ava:51)
!SESSION Apr 20, 2005 15:26:46.271
!ENTRY org.eclipse.osgi Apr 20, 2005 15:26:46.271
!MESSAGE An error occured while automatically activating bundle
org.vssplugin (177).
!STACK 0
org.osgi.framework.BundleException: State change in progress for bundle
"update@/d:/data/Apps/eclipse/plugins/org.vssplugin_1.6.0/" by thread
"System Bundle Shutdown".
org.eclipse.osgi.framework.internal.core.AbstractBundle.begi nStateChange
(AbstractBundle.java:1176)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBu
ndle.java:291)
seClassLoader.java:110)
dleLoader.java:371)
ader.java:402)
ava:51)
!SESSION Apr 26, 2005 11:08:52.520
!ENTRY org.eclipse.jdt.core 4 4 Apr 26, 2005 11:08:52.520
!MESSAGE JavaBuilder handling CoreException
!STACK 1
org.eclipse.core.internal.resources.ResourceException: File /EM New
Platform
Backend/bin/com/eyemaginations/emx/basicobj/EMAnimResourceGr oup.class is
read-only.
org.eclipse.core.internal.resources.Workspace.validateSave(W orkspace.jav
a:2243)
org.eclipse.core.internal.resources.File.setContents(File.ja va:332)
org.eclipse.core.internal.resources.File.setContents(File.ja va:439)
org.eclipse.jdt.internal.core.builder.IncrementalImageBuilde r.writeClass
FileBytes(IncrementalImageBuilder.java:603)
org.eclipse.jdt.internal.core.builder.AbstractImageBuilder.w riteClassFil
e(AbstractImageBuilder.java:455)
org.eclipse.jdt.internal.core.builder.AbstractImageBuilder.a cceptResult(
AbstractImageBuilder.java:115)
org.eclipse.jdt.internal.compiler.Compiler.compile(Compiler. java:341)
org.eclipse.jdt.internal.core.builder.AbstractImageBuilder.c ompile(Abstr
actImageBuilder.java:203)
actImageBuilder.java:153)
org.eclipse.jdt.internal.core.builder.IncrementalImageBuilde r.build(Incr
ementalImageBuilder.java:113)
org.eclipse.jdt.internal.core.builder.JavaBuilder.buildDelta s(JavaBuilde
r.java:224)
org.eclipse.jdt.internal.core.builder.JavaBuilder.build(Java Builder.java
:152)
org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:57
0)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.
java:616)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.ja
va:159)
va:251)
va:204)
org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:23
1)
java:616)
va:234)
org.eclipse.core.internal.events.BuildManager.basicBuildLoop (BuildManage
r.java:270)
org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:29
9)
org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBu ildJob.java:
155)
org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJ ob.java:212)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
!SUBENTRY 1 org.eclipse.team.core 4 279 Apr 26, 2005 11:08:52.520
!MESSAGE File /EM New Platform
read-only.
!ENTRY org.eclipse.jdt.core 4 4 Apr 26, 2005 11:08:52.691
!STACK 1
Platform Backend/bin/com/eyemaginations/emx/xml/AnimXMLReader.class is
read-only.
a:2243)
r.java:224)
:152)
0)
java:616)
va:159)
va:251)
va:204)
1)
java:616)
va:234)
r.java:270)
9)
155)
!SUBENTRY 1 org.eclipse.team.core 4 279 Apr 26, 2005 11:08:52.691
Backend/bin/com/eyemaginations/emx/xml/AnimXMLReader.class is read-only.
!ENTRY org.eclipse.jdt.core 4 4 Apr 26, 2005 11:08:52.871
!STACK 1
org.eclipse.core.internal.resources.ResourceException: File /EM Class
Driver/bin/com/eyemaginations/test/EMXTest/ClassDriver.class is
read-only.
a:2243)
r.java:224)
:152)
0)
java:616)
va:159)
va:251)
va:204)
1)
java:616)
va:234)
r.java:270)
9)
155)
!SUBENTRY 1 org.eclipse.team.core 4 279 Apr 26, 2005 11:08:52.871
!MESSAGE File /EM Class
read-only.
!ENTRY org.eclipse.team.core 4 279 Apr 26, 2005 11:57:58.556
!MESSAGE File /EM Class Driver/.classpath is read-only.
!SESSION Apr 26, 2005 16:12:38.07
!ENTRY org.eclipse.osgi Apr 26, 2005 16:12:38.07
!STACK 0
stopped.
dleLoader.java:371)
ader.java:402)
ava:51)
!SESSION Apr 26, 2005 19:08:51.461
!ENTRY org.eclipse.osgi Apr 26, 2005 19:08:51.461
!STACK 0
stopped.
dleLoader.java:371)
ader.java:402)
ava:51)
!SESSION Apr 27, 2005 20:21:04.526
!ENTRY org.eclipse.osgi Apr 27, 2005 20:21:04.526
!STACK 0
stopped.
dleLoader.java:371)
ader.java:402)
ava:51)
!SESSION Apr 28, 2005 18:37:24.618
!ENTRY org.eclipse.osgi Apr 28, 2005 18:37:24.618
!STACK 0
stopped.
dleLoader.java:371)
ader.java:402)
ava:51)
!SESSION Apr 29, 2005 18:22:44.449
!ENTRY org.eclipse.osgi Apr 29, 2005 18:22:44.459
!STACK 0
stopped.
dleLoader.java:371)
ader.java:402)
ava:51)
!SESSION May 02, 2005 16:27:37.595
!ENTRY org.eclipse.jdt.core 4 4 May 02, 2005 16:27:37.595
!STACK 1
Platform Backend/bin/com/eyemaginations/emx/fsdb/FileSystemDB.class is
read-only.
a:2243)
r.java:224)
:152)
0)
java:616)
va:159)
va:251)
va:204)
1)
java:616)
va:234)
r.java:270)
9)
155)
!SUBENTRY 1 org.eclipse.team.core 4 279 May 02, 2005 16:27:37.595
Backend/bin/com/eyemaginations/emx/fsdb/FileSystemDB.class is read-only.
!ENTRY org.eclipse.osgi May 02, 2005 16:32:34.943
!STACK 0
stopped.
dleLoader.java:371)
ader.java:402)
ava:51)
!SESSION May 02, 2005 16:42:58.409
!ENTRY org.eclipse.osgi May 02, 2005 16:42:58.409
!STACK 0
stopped.
dleLoader.java:371)
ader.java:402)
ava:51)
!SESSION May 02, 2005 18:31:09.163
!ENTRY org.eclipse.osgi May 02, 2005 18:31:09.163
!STACK 0
stopped.
dleLoader.java:371)
ader.java:402)
ava:51)
!SESSION May 03, 2005 10:08:34.194
!ENTRY org.eclipse.osgi May 03, 2005 10:08:34.204
!STACK 0
stopped.
dleLoader.java:371)
ader.java:402)
ava:51)
!SESSION May 03, 2005 11:22:59.725
!ENTRY org.eclipse.osgi May 03, 2005 11:22:59.725
!STACK 0
stopped.
dleLoader.java:371)
ader.java:402)
ava:51)
!SESSION May 03, 2005 11:53:13.921
java.version=1.4.2_04
!ENTRY org.eclipse.osgi May 03, 2005 11:53:13.921
!STACK 0
stopped.
dleLoader.java:371)
ader.java:402)
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:302 )
ava:51)
!SESSION May 03, 2005 11:54:54.984
java.vendor=Sun Mic
Re: Opening an already existing workspace [message #60784 is a reply to message #60780] Tue, 03 May 2005 17:45 Go to previous message
Originally posted by: wegener.cboenospam.com
Don't check workspaces into your source code managment system. You should
only check in the source files, the .classpath file, and the .project
file. You may also want to check in any shared launch configs.
Previous Topic:HELP: java.lang.IllegalStateException: Workspace is closed.
Next Topic:How to load plugin at eclipse startup
Current Time: Thu Jul 17 22:21:37 EDT 2025
Powered by FUDForum. Page generated in 0.13117 seconds
