Home » Newcomers » Newcomers » StyledText Question
StyledText Question [message #60768] Tue, 03 May 2005 08:48 Go to next message
Originally posted by: jaschulz.wiseware.com
As I understand it the SWT StyledText widget supports only BOLD and
ITALIC styles. I need a widget that also supports UNDERLINE, SUBSCRIPT
and SUPERSCRIPT. Is it possible to modify the SWT StyledText widget to
make it handle these extra styles? Can someone point me to an example
that would get me started in this direction? Or is this a hopeless quest?
JAS
Re: StyledText Question [message #60775 is a reply to message #60768] Tue, 03 May 2005 15:17 Go to previous messageGo to next message
StyledText now supports underline. AFAIK it does not support subscript
or superscript.
to use underline, you only need to set StyleRange.underline=true on your
StyleRange.
HTH
Kevin
> JAS
Re: StyledText Question [message #60779 is a reply to message #60775] Tue, 03 May 2005 15:32 Go to previous messageGo to next message
Keven,
That doesn't work for me. If I write:
myStyleRange.underline = true;
Eclipse complains: "myStyleRange.underline cannot be resolved or is not
a field".
Ordinarily (i.e. with Bold and Italic styles) I use:
myStyleRange.fontStyle = SWT.BOLD;
but Eclipse does not recognize SWT.UNDERLINE.
Am I missing something?
JAS
> or superscript.
> StyleRange.
> HTH
> Kevin
>> SUBSCRIPT and SUPERSCRIPT. Is it possible to modify the SWT
>> StyledText widget to make it handle these extra styles? Can someone
>> point me to an example that would get me started in this direction?
>> Thanks,
>> JAS
Re: StyledText Question [message #61238 is a reply to message #60779] Fri, 06 May 2005 16:04 Go to previous message
Sounds like underline is newer than the version of Eclipse that you are
using.
The console used to underline by calling drawLine(), but that was a
pain. If using a newer version of Eclipse is an option, you may want to
consider it.
3.1 M7 will be out next week!
Kevin
> Keven,
> a field".
> JAS
>> or superscript.
>> your StyleRange.
>> HTH
>> Kevin
>>> Thanks,
>>> JAS
Previous Topic:Changing debug hotkeys
Next Topic:Moving Projects to a new Machine
Current Time: Mon Jul 21 21:30:51 EDT 2025
Powered by FUDForum. Page generated in 0.13631 seconds
