Home » Newcomers » Newcomers » Default workspace path
Default workspace path [message #60763] Tue, 03 May 2005 03:52
Originally posted by: fmauchle.zbw.ch
Hi all.
Is it possible to set the default path to the workspace direcotry, which
is used, when a user starts eclipse the first time, and without using
the "run in" property in a windows shortcut? I tried to set it in the
eclipse\configruation\org.eclipse.ui.ide\recentWorkspaces.xm l file, but
only the user, with wich i installed and configured eclipse, is prompted
for this path as default. Also, using the -data startoption makes no
sense, because it should only be the default directory, that can be
modified by the user during startup.
Thanks for your asistance
Fabian Mauchle
Previous Topic:How do I link the editor files?
Next Topic:Syntax coloring for Java type identifiers
Current Time: Sun Jul 13 07:07:29 EDT 2025
Powered by FUDForum. Page generated in 0.07825 seconds
