Home » Archived » Visual Editor (VE) » SWT Class throws NULL exception
SWT Class throws NULL exception [message #60719] Thu, 23 September 2004 19:26 Go to next message
Originally posted by: bvkiran.hotmail.com
I downloaded VE 1.0 along with EMF 2.0.1 and gef 3.0.1. When I create a
visual class with SWT, I get a NULL pointer exception and the visual part
of the editor does not show up. I have include swt.jar in the class path.
Swing based one works fine.
What am I doing wrong
Re: SWT Class throws NULL exception [message #60721 is a reply to message #60719] Fri, 24 September 2004 05:33 Go to previous messageGo to next message
Hi BVK,
What platform are you on ? Can you include the .log file from the
..metadata directory of your workspace ?
Joe Winchester
Re: SWT Class throws NULL exception [message #60727 is a reply to message #60719] Fri, 24 September 2004 13:17 Go to previous messageGo to next message
If you're on Linux/GTK, I had this problem too. The problem is that you
have to make sure that the swt-pi and swt-mozilla jar files are on your
classpath too. Just right-click the project, pick properties, go to the
Java Build Path page, Libraries tab, click "Add External Jar" and add them.
You should be up and running then.
Dave
Dave Orme
Eclipse Visual Editor Project Lead
Advanced Systems Concepts' Chief Architect
http://www.swtworkbench.com http://essentialdata.sf.net
Re: SWT Class throws NULL exception [message #60732 is a reply to message #60721] Fri, 24 September 2004 16:55 Go to previous messageGo to next message
I am running on Windows. I do have SWT path set up. I can run other SWT
routines in the same app.
Kiran
Here the final part of the .metadata log.
!ENTRY org.eclipse.jem.proxy 2 0 Sep 23, 2004 16:34:05.148
!MESSAGE
!STACK 0
IWAV0073I *** RemoteVM Exception - Trace from Remote VM:
java.lang.NoClassDefFoundError: org.eclipse.swt.widgets.Control
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un(ConnectionHandler.java:143)
org.eclipse.jem.internal.proxy.vm.remote.ConnectionThread.ru n(ConnectionThread.java:47)
IWAV0074I *** Local StackTrace:
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanProxyP roxy:
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.createThrowableBeanProxy(REMThrowableBeanTypeProxy.java: 34)
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.newBeanProxy(REMThrowableBeanTypeProxy.java:65)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.getBeanProxy(REMStandardBeanProxyFactory.java:454)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.processErrorReturn(REMStandardBeanProxyFactory.java:50 5)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.getClassReturn(REMStandardBeanTypeProxyFactory.jav a:313)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.createBeanTypeProxy(REMStandardBeanTypeProxyFactor y.java:173)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.getBeanTypeProxy(REMStandardBeanTypeProxyFactory.j ava:290)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.getBeanTypeProxy(REMStandardBeanTypeProxyFactory.j ava:237)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspect(BeaninfoClassAdapter.java:444)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspectIfNecessary(BeaninfoClassAdapter.java:394)
org.eclipse.jem.java.impl.JavaClassImpl.getEAnnotations(Java ClassImpl.java:339)
org.eclipse.ve.internal.cde.emf.ClassDecoratorTypeIterator.f indDecorator(ClassDecoratorTypeIterator.java:37)
org.eclipse.ve.internal.cde.emf.ClassDecoratorIterator.initi alize(ClassDecoratorIterator.java:47)
org.eclipse.ve.internal.cde.emf.ClassDecoratorTypeIterator.<init >(ClassDecoratorTypeIterator.java:33)
org.eclipse.ve.internal.cde.emf.ClassDecoratorFeatureAccess. getDecoratorWithFeature(ClassDecoratorFeatureAccess.java:40)
org.eclipse.ve.internal.cde.emf.ClassDescriptorDecoratorPoli cy.findDecorator(ClassDescriptorDecoratorPolicy.java:128)
org.eclipse.ve.internal.cde.emf.ClassDescriptorDecoratorPoli cy.getModelAdapterClassname(ClassDescriptorDecoratorPolicy.j ava:195)
org.eclipse.ve.internal.cde.emf.DefaultModelAdapterFactory.c reateAdapter(DefaultModelAdapterFactory.java:76)
org.eclipse.ve.internal.cde.emf.DefaultModelAdapterFactory.g etAdapter(DefaultModelAdapterFactory.java:51)
org.eclipse.ve.internal.cde.emf.AbstractEMFContainerPolicy.i sParentAcceptable(AbstractEMFContainerPolicy.java:52)
org.eclipse.ve.internal.cde.emf.AbstractEMFContainerPolicy.g etCreateCommand(AbstractEMFContainerPolicy.java:65)
org.eclipse.ve.internal.java.core.JavaContainerPolicy.getCre ateCommand(JavaContainerPolicy.java:38)
org.eclipse.ve.internal.cde.core.ContainerPolicy.getCommand( ContainerPolicy.java:211)
org.eclipse.ve.internal.cde.core.VisualInfoXYLayoutEditPolic y.getCreateCommand(VisualInfoXYLayoutEditPolicy.java:100)
org.eclipse.gef.editpolicies.LayoutEditPolicy.getCommand(Lay outEditPolicy.java:205)
org.eclipse.gef.editpolicies.ConstrainedLayoutEditPolicy.get Command(ConstrainedLayoutEditPolicy.java:152)
org.eclipse.ve.internal.cde.core.XYLayoutEditPolicy.getComma nd(XYLayoutEditPolicy.java:215)
org.eclipse.ve.internal.cde.core.VisualInfoXYLayoutEditPolic y.getCommand(VisualInfoXYLayoutEditPolicy.java:231)
org.eclipse.gef.editparts.AbstractEditPart.getCommand(Abstra ctEditPart.java:501)
at org.eclipse.gef.tools.TargetingTool.getCommand(TargetingTool .java:124)
org.eclipse.ve.internal.cde.emf.EMFCreationTool.getCommand(E MFCreationTool.java:75)
at org.eclipse.gef.tools.CreationTool.handleMove(CreationTool.j ava:220)
at org.eclipse.gef.tools.AbstractTool.mouseMove(AbstractTool.ja va:1041)
at org.eclipse.gef.EditDomain.mouseMove(EditDomain.java:234)
org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchMouse Moved(DomainEventDispatcher.java:344)
org.eclipse.draw2d.LightweightSystem$EventHandler.mouseMove( LightweightSystem.java:523)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:144)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2772)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2431)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:186)
at org.eclipse.core.launcher.Main.run(Main.java:647)
at org.eclipse.core.launcher.Main.main(Main.java:631)
!ENTRY org.eclipse.jem.beaninfo 2 0 Sep 23, 2004 16:34:05.168
!MESSAGE IWAV0155E Introspection failed on class
"org.eclipse.swt.widgets.Button." msg="IWAV0135E
java.lang.NoClassDefFoundError(org.eclipse.swt.widgets.Contr ol). "
!ENTRY org.eclipse.jem.proxy 2 0 Sep 23, 2004 16:34:14.922
!MESSAGE
!STACK 0
!ENTRY org.eclipse.jem.beaninfo 2 0 Sep 23, 2004 16:34:14.942
"org.eclipse.swt.widgets.Slider." msg="IWAV0135E
!ENTRY org.eclipse.jem.proxy 2 0 Sep 23, 2004 16:34:23.84
!MESSAGE
!STACK 0
java.lang.NoClassDefFoundError: org.eclipse.swt.widgets.Scrollable
!ENTRY org.eclipse.jem.beaninfo 2 0 Sep 23, 2004 16:34:23.104
"org.eclipse.swt.widgets.List." msg="IWAV0135E
java.lang.NoClassDefFoundError(org.eclipse.swt.widgets.Scrol lable). "
Re: SWT Class throws NULL exception [message #61755 is a reply to message #60727] Mon, 27 September 2004 16:46 Go to previous messageGo to next message
> Dave
Actually, you need to use the JDT build path and do Add Library and add
SWT. Just adding jars to the classpath won't work. We don't recognize
SWT via jars, we recognize through the SWT library that we add.
Re: SWT Class throws NULL exception [message #61802 is a reply to message #61755] Mon, 27 September 2004 17:05 Go to previous messageGo to next message
That exactly what I did. Added library(under Java BuildPath/Library/Add
library) and chose SWT. It still give the NULL pointer exception
Re: SWT Class throws NULL exception [message #61920 is a reply to message #61802] Mon, 27 September 2004 17:42 Go to previous message
Well, let's try this. On the Package Explorer, expand the SWT library
and tell me what jars it says are included with it.
Rich
Re: SWT Class throws NULL exception [message #599121 is a reply to message #60719] Fri, 24 September 2004 05:33 Go to previous message
Hi BVK,
Joe Winchester
Re: SWT Class throws NULL exception [message #599171 is a reply to message #60719] Fri, 24 September 2004 13:17 Go to previous message
Dave
Dave Orme
Re: SWT Class throws NULL exception [message #599213 is a reply to message #60721] Fri, 24 September 2004 16:55 Go to previous message
Kiran
!MESSAGE
!STACK 0
!MESSAGE
!STACK 0
!MESSAGE
!STACK 0
Re: SWT Class throws NULL exception [message #599728 is a reply to message #60727] Mon, 27 September 2004 16:46 Go to previous message
> Dave
Re: SWT Class throws NULL exception [message #599739 is a reply to message #61755] Mon, 27 September 2004 17:05 Go to previous message
Re: SWT Class throws NULL exception [message #599771 is a reply to message #61802] Mon, 27 September 2004 17:42 Go to previous message
Rich
Previous Topic:IWAV0138E remote VM terminated too soon
Next Topic:Problems with SWT menus
Current Time: Sat Jul 26 09:55:06 EDT 2025
Powered by FUDForum. Page generated in 1.12214 seconds
