Home » Archived » Visual Editor (VE) » Externalized stings don't work anymore
Externalized stings don't work anymore [message #60676] Wed, 22 September 2004 08:45 Go to next message
Originally posted by: eifert.SPAMweb.de
since the release of the final version of VE, externalized strings in a
visual class aren't properly evaluated. Instead, the component gets
marked with an 'i' and the tooltip shows a
java.lang.InstantiationException(... to complicated to be evaluated). In
VE1.0M2 externalized string were ok (except for TitledBorders).
Is anyone else experiencing this?
Sebastian
Re: Externalized stings don't work anymore [message #60677 is a reply to message #60676] Wed, 22 September 2004 10:25 Go to previous messageGo to next message
Hi Sebastian,
Thanks for finding this. I've opened a sev 1 bugzilla 74552 for this so
please added yourself to the cc list.
Joe Winchester
Re: Externalized stings don't work anymore [message #60680 is a reply to message #60676] Wed, 22 September 2004 10:39 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Just so we know, what is the externalized string code in the file look
like? Need to see the format to see if we should be able to evaluate it
correctly. There are some we can't, even though it worked in M2.
Something probably has regressed, but the format you are using will help
us find it out.
Thanks, Rich Kulp
Re: Externalized stings don't work anymore [message #60694 is a reply to message #60680] Wed, 22 September 2004 13:08 Go to previous messageGo to next message
> us find it out.
The call is LanguageManager.getString("KEY"), where getString() is a
static method and LanguageManager has a static initializer block. But
even if you simplify getString() by returning a constant string, VE
still can't evaluate it.
In M2 it worked for things like
jLabel.setText(LanguageManager.setString("foo"));
but failed for
jPanel.setBorder(javax.swing.BorderFactory.createTitledBorde r(
null,LanguageManager.getString("Viz2DConfigPanel.31"),...));
In 1.0 final, it fails for both.
Sebastian
Re: Externalized stings don't work anymore [message #60695 is a reply to message #60694] Wed, 22 September 2004 13:22 Go to previous messageGo to next message
Just for now, change LanguageManager.getString("KEY") to be
fully-qualified. It probably can't find LanguageManager because that
section of the parser doesn't know about import stmts. That is something
that we need to address, we have a priority defect open to try find all
of the places that are like this.
Thanks, Rich Kulp
Re: Externalized stings don't work anymore [message #60696 is a reply to message #60695] Wed, 22 September 2004 14:01 Go to previous message
> fully-qualified.
Thanks, that seems to work, even for TitledBorders.
Sebastian
Re: Externalized stings don't work anymore [message #598780 is a reply to message #60676] Wed, 22 September 2004 10:25 Go to previous message
Hi Sebastian,
Joe Winchester
Re: Externalized stings don't work anymore [message #598804 is a reply to message #60676] Wed, 22 September 2004 10:39 Go to previous message
us find it out.
Thanks, Rich Kulp
Re: Externalized stings don't work anymore [message #598898 is a reply to message #60680] Wed, 22 September 2004 13:08 Go to previous message
> us find it out.
but failed for
Sebastian
Re: Externalized stings don't work anymore [message #598906 is a reply to message #60694] Wed, 22 September 2004 13:22 Go to previous message
Thanks, Rich Kulp
Re: Externalized stings don't work anymore [message #598912 is a reply to message #60695] Wed, 22 September 2004 14:01 Go to previous message
> fully-qualified.
Sebastian
Previous Topic:Problem with Visual Editor 1.0 - create new VisualClass
Next Topic:[MAC] - Main reason that VE does not support MAC
Current Time: Mon Jul 14 01:50:05 EDT 2025
Powered by FUDForum. Page generated in 0.04446 seconds
