Home » Archived » Visual Editor (VE) » Problem with Visual Editor 1.0 - create new VisualClass
Problem with Visual Editor 1.0 - create new VisualClass [message #60675] Wed, 22 September 2004 08:05 Go to next message
Originally posted by: hendriklenz.gmx.de
i will use the Visual Editor 1.0 with Eclipse 3.0.1. I have intsalled
all needed Plugins (GEF and EMF). When i create an new Java Project and
a new VisualClass i get this error:
#### begin of error ####
An internal error occurred during: "Setup Java Visual Editor".
java.lang.NoClassDefFoundError:
org/eclipse/jem/internal/plugin/JavaEMFNature
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.initializeForProject(JavaVisualEditorPart.jav a:1691)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.initialize(JavaVisualEditorPart.java:1586)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1396)
org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
#### end of error ####
What do i wrong? Has anyone some Hints for me?
Thanks Hendrik
Re: Problem with Visual Editor 1.0 - create new VisualClass [message #60679 is a reply to message #60675] Wed, 22 September 2004 10:37 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
That's weird because if you got that far, JavaEMFNature should be there.
Do you have anything else installed besides GEF and EMF?
Also, is it GEF 3.0.1 and EMF 2.0.1, the released versions that just
came out on Monday? Is the released version of VE that came out on
Monday? Is the released version of Eclipse 3.0.1 that came out on Monday?
Thanks, Rich Kulp
Re: Problem with Visual Editor 1.0 - create new VisualClass [message #60692 is a reply to message #60679] Wed, 22 September 2004 12:18 Go to previous message
thanks thants it i have use the GEF 3.0.0 and EMF 2.0.0 i install now
the x.x.1 release of both and it works.
Thank you
Hendrik
Re: Problem with Visual Editor 1.0 - create new VisualClass [message #598798 is a reply to message #60675] Wed, 22 September 2004 10:37 Go to previous message
Thanks, Rich Kulp
Re: Problem with Visual Editor 1.0 - create new VisualClass [message #598886 is a reply to message #60679] Wed, 22 September 2004 12:18 Go to previous message
Thank you
Hendrik
Previous Topic:Some SWT objects are not displayed in the design view (Release 1.0)
Next Topic:Externalized stings don't work anymore
Current Time: Tue Jul 22 01:48:54 EDT 2025
Powered by FUDForum. Page generated in 0.24643 seconds
